Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ?
GODLIKE99KINGZ
2016/10/28 10:53:32 (permalink)
hello. I plan to install all those components on this mobo. Can u tell me if this motherboard can pull out performance from those components at best on set up like I did ?
I chosed pcie1 x16 & pcie3 x8 for GTX to let the air go in between them. >>> If I use pcie x16 on both GTX will I get x16 performance or just x8 ?
post edited by GODLIKE99KINGZ - 2016/10/28 16:21:57
9 Replies Related Threads
    • Ribbons : 68
    Re: Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ? 2016/10/28 11:04:01 (permalink)
    4x 960 PRO) + (3x GTX) that 7 I would say No.
    Read Page 12
    PCI-E Lane Distribution
    PE1 – x16, (x8 if PE2 or PE3 is used) lanes from CPU
    PE2 – x8, (x4 if PE3 is used) lanes from CPU
    PE3 – x4, 4 lanes from CPU
    PE4 – x4, 4 lanes from PCH
    PE5 – x1, 1 lane from PCH
    PE6 – x1, 1 lane from PCH
    Page 28
    PCIE & M.2 Slots
    All of the boards in this series have at least 1 PCIE x16 slot available, which is
    typically used for a video card, however if you use a CPU with onboard video you
    can leave it empty or place a different type of card into the slot. You will also see x4
    PCIE slots as well as 2 variants of M.2.
    post edited by bcavnaugh - 2016/10/28 11:06:27
    GODLIKE99KINGZ
    Re: Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ? 2016/10/28 11:06:03 (permalink)
    so how many M.2 can I use ? there also will be 2x SSD 950 Pro via Sata
    • Ribbons : 68
    Re: Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ? 2016/10/28 11:08:07 (permalink)
    GODLIKE99KINGZ
    The FAQs have that info. http://www.evga.com/support/knowledgebase/
    post edited by bcavnaugh - 2016/10/28 11:11:06
    GODLIKE99KINGZ
    Re: Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ? 2016/10/28 11:32:34 (permalink)
    thank you
    GODLIKE99KINGZ
    Re: Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ? 2016/10/28 11:35:54 (permalink)
    what PLX mean on PCIe ?
    • Ribbons : 68
    Re: Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ? 2016/10/28 12:08:29 (permalink)
    GODLIKE99KINGZ
    It is a Chip that Provides PCIe Lanes above the CPU.
    PLX Technology
    • Ribbons : 122
    Re: Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ? 2016/10/28 12:10:27 (permalink)
    GODLIKE99KINGZ
    http://www.anandtech.com/...te-asrock-ecs-and-evga
    GODLIKE99KINGZ
    Re: Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ? 2016/10/28 12:19:35 (permalink)
    Seems like I should put GTXs on Pcie1+Pcie4 and one M.2 on Pcie3.
    Will there be a difference in Frames if I use other Pcie slot for second GTX and make them x8 instead of x16 and if how many frmes will I loose in % ?
    post edited by GODLIKE99KINGZ - 2016/10/28 12:36:47
    • Ribbons : 68
    Re: Z170 Classified 4-Way (4x 960 PRO) + (3x GTX) will it work ? 2016/10/28 12:52:37 (permalink)
    As long as you are at x8 at Gen3 you should be fine and will not see that much of loss.
    You Must have at Least x8 to run SLI whether 2-Way or 3-Way.
    Maybe you should take a look the EVGA X99 Classified & FTW K Model Motherboards.
    You can select the two X99 on the website to compare and even add your motherboard and compare all three Motherboards.
    post edited by bcavnaugh - 2016/10/28 12:55:46
