Re:Need help with what mobo I should get???
2011/03/26 08:19:36
Because you can't overclock on a P55V.
i7-4770K @ 4.0 / Gigabyte Z87X-UD4H / 8GB DDR3-1600 G.SKILL Ripjaws X EVGA GTX 780 Ti SC / Silverstone Strider Plus 1000W Corsair H110 / CM Storm Stryker CM Storm Trigger / CM Sentinel Advanced --- AMD Sempron 145 / ECS A990FXM-A / 8GB DDR3-1600 G.SKILL Ripjaws X (3) ASUS R9-280X DirectCUII / EVGA SuperNOVA 1000P2 Red Milk Crate --- Epiphone Sheraton R62 / Vox AC15C1 MXR Carbon Copy / ZVEX Vextron
D.M.W.T
2011/03/26 08:50:56
He said he wants a cheap mobo for folding and his kids, I did not think OCing was a priority. I personally would rather have a brand new one thats never been OCed with a 2 year warranty than a Bstock with a 90 day.
2011/03/26 09:43:14
Well, the numbers that you can push with an SMP CPU client scales very well with how much you're overclocking. Bear's an overclocker too, so I'd think it almost a sin to give him a board that'll keep him at stock!
2011/03/26 10:22:25
@Sleepee-Thank you so much for this info cause this is the info I been looking for your a life saver & I think you should get a BR for it too! @D.M.W.T.-I'm getting this mobo because of my EVGA bucks!
RainStryke
- Ribbons : 40
2011/03/26 11:09:50
That deal on eBay for the kingston memory is still better than anything on newegg at the moment.
Intel i7 4790K - Corsair H90 - MSI Z87 MPOWER MAX AC - MSI GTX 980 (81.7% ASIC) - 16GB G.Skill 2400MHz - Seasonic X-1250 - Crucial MX100 512GB - Corsair Carbide 500R EVGA Affiliate Code: S27QNQME0X
2011/03/26 11:12:43
2011/03/26 11:59:41
No probs Bear! I guess this is what I get for having had ample opportunity to play with lots of hardware.
2011/03/26 12:26:58
I have had the chave to run both the p55 FTW mobo and an x58 mobo (758 not 757) and i will have to say for price/ prefromance the p55 is going to win. if you spend some time browsing the evga forums you can find an i7 860 for $150-$200 and prolly a nice 4gb ram kit for $30-$50. rather then spending about double that on an x58 setup when they both preform about the same.
2011/03/26 12:31:49
seabigbear RainStryke That deal on eBay for the kingston memory is still better than anything on newegg at the moment. I got a bid on this G.Skill right now: http://cgi.ebay.com/ws/eB...e=STRK:MEBIDX:IT Same ram i had running in mine and is now running in my x58 while i rma my doms lol Great Ram :) Some pics of the FTW in a Haf 932
2011/03/26 12:50:07
my X58 LE has been running like a champ since july 09, cant say anything bad about it....hell i even grounded the mobo and the only thing that broke were my fan headers
[11:11:11] trust_me: I had a hamburger once... [20:32:06] moose517: ROFL i got my fro stuck on a sprinkler at work one time [20:32:09] moose517: that sucked
2011/03/26 12:56:35
2011/03/26 13:04:11
2011/03/26 13:17:25
seabigbear Hypn0t1q79 http://forums.evga.com/tm.aspx?m=893798 If that auction falls through heres some ram allbiet a little pricey Thanks H! No problem ill be on the lookout for more 4gb ram in market place
2011/03/26 15:59:53
2011/03/26 16:14:08
2011/03/26 16:55:56
2011/03/26 17:02:55
Hypn0t1q79 seabigbear Hypn0t1q79 http://forums.evga.com/tm.aspx?m=914753 cheap ddr3 1600 not to bad looking eaither Thank you but I already PM him! Ahh faster then me :P btw you still have the 465 you won? No I step it up to the 470!
2011/03/26 17:16:36
So what you gonna run for gpus in this comp?
2011/03/26 17:20:11
Hypn0t1q79 So what you gonna run for gpus in this comp? For now my old 260 till I get more money!
2011/03/26 17:20:57
2011/03/27 17:05:04
Well I can get a i5 655k CPU Manuf. link & a P55 Classified 200 Manuf. Link for a steel so I'm going for it my Big "?" is will this Extended ATX mobo fit my Cooler Master storm sniper case It says up to a ATX but if there's a way I want to do it! Thank you!
2011/03/27 17:36:52
Added to my 1st post still need to know if it will work!
2011/03/27 17:46:09
☄ Helpful
It will. The P55 Classified 200 has mounting holes for a regular ATX case. The only difference that you'll notice is that the board will be closer to your hard drive cages by about an inch. Bear, I also hope that you know that the i5-655K is only a dual core.
2011/03/27 17:50:50
Sleepee It will. The P55 Classified 200 has mounting holes for a regular ATX case. The only difference that you'll notice is that the board will be closer to your hard drive cages by about an inch. Bear, I also hope that you know that the i5-655K is only a dual core. I know but I'm getting a deal that I can't pass up & the i5 has 4 Threads so maybe it can do SMP folding!
2011/03/27 17:52:18
It'll be able to do SMP, yeah, but its performance will be fairly similar to an i3's folding. It's 2 cores, 4 threads; 4 cores 4 threads will always out perform it.
2011/03/27 17:55:25
Sleepee It'll be able to do SMP, yeah, but its performance will be fairly similar to an i3's folding. It's 2 cores, 4 threads; 4 cores 4 threads will always out perform it. Yea, I know BTW, I know I can always upgrade to a i7 down the road!
bucyrus5000
- Ribbons : 8
2011/03/27 18:30:20
what happened here? New subject to the thread? @Will CM Sniper fit EATX=no It isn't made to fit, but may have enough space, although it depends on what you have in your 5.25" bays and how much modifying your are willing to do.
Rant about what Grinds Your Gears HERE! Need help finding places to shop for computer goods? Find stores HERE and review them. Help me with my rig build HERE.
bucyrus5000
- Ribbons : 8
2011/03/27 19:22:03
from the edge of the motherboard, do you have 3.4" of space to the 5.25" bay fans? How much space do you have? The EATX is 13" whereas the ATX is 9.6" wide.
2011/03/27 19:27:43
bucyrus5000 from the edge of the motherboard, do you have 3.4" of space to the 5.25" bay fans? How much space do you have? The EATX is 13" whereas the ATX is 9.6" wide. Where are you getting you info at cause EVGA site says this for both E-ATX & ATX: Form Factor EATX Form Factor Length: 12in – 304.8mm Width: 10.375in – 263.5mm Form Factor ATX Form Factor Length: 12in - 304.8mm Width: 9.6in - 243.84mm
post edited by seabigbear - 2011/03/27 19:30:51
