Will there will be a big difference between GTX 980 Classified ACX 2.0 vs Superclocked
koshelkov
2014/10/01 17:26:33 (permalink)
Hi everyone,
Will there will be a big difference between GTX 980 Classified ACX 2.0 vs Superclocked? I want buy 3 cards and I still debating if I should go with factory cooling system vs ACX 2.0, what will be difference between these two cards:
EVGA GeForce GTX 980 Classified ACX 2.0
VS
VGA GeForce GTX 980 Superclocked
Is there will be 15/20+ fps difference in the games or we're more talking about +-5 FPS?
Thank you!
Windows 8.1 Pro | | EVGA X99 Classified | Intel i7-5960X CPU @ 4.5 GHz (Swiftech H220-X) | 16GB DDR4 @3000 Mhz Corsair | 3x SLI EVGA GTX 980 EK Hydro | GTX 740 Physics Dedicated | EVGA X99 Classified |3x 30" HP Z30i 2560x1600 | Cosmos II Case | 3X 1TB Samsung SSD 840 Evo | PSU EVGA 1600 P2
4 Replies Related Threads
    Macto1990
    Re: Will there will be a big difference between GTX 980 Classified ACX 2.0 vs Superclocked 2014/10/02 01:19:13 (permalink)
    I think as there is "only" a difference of 50/63 MHz base/boost, wich is ~4/~4.7% and no difference in memory, it will be about ~5FPS.
    According to the game naturally. When it runs with 40 PFS it will be less then 5 and if it runs with 200 FPS it will be more.
    But this is only a rough estimate.
    Intel Core I7- 5930k || EVGA X99 FTW || ZOTAC GTX 670 AMP! || G.Skill Ripjaws 4 2666MHz 4x4Gb
    Xtremed
    Re: Will there will be a big difference between GTX 980 Classified ACX 2.0 vs Superclocked 2014/10/02 02:44:31 (permalink)
    Aslo remember that you can overclock your cards manually, it happened to me once, i had these 780 vanillas that overclocked the same or more as the 780 Classy (until you use the EVBOT)
    Intel Core I7 12700K  || Noctua D15S || ASUS TUF Z690-Plus D4
    32 GB Corsair LPX 3200  (16-18-18-36 @ 1.35V)
    EVGA 3080ti FTW3 Ultra || Acer Predator X34 GS @ 3440x1440 180hz
    Samsung 970 EVO 512GB || Adata SX8200 Pro 2TB
    3TB WD Caviar Green (Media Drive)
    Creative SB ZX Sound Card || Sennheiser HD518 + ModMic II
    Corsair K95 RGB Platinum || Logitech Proteus Core G502  || Logitech G29 + Shifter
    CM H500P Mesh White || PSU NZXT C850
    OS Windows 11 Pro
    FalconLover
    Re: Will there will be a big difference between GTX 980 Classified ACX 2.0 vs Superclocked 2014/10/02 05:04:09 (permalink)
    The superclocked is reference design with a higher binned chip.
    The classified has a higher binned chip and a custom PCB. It allows higher voltage and TDP control by using more power phases and more power connectors.
    You can feed more power to the card so it can achieve higher clocks.... so the story goes.
    In reality you don't really want to push cards that hard on a 24/7 setup. Its only necessary for the liquid nitrogen crowd.
    Still, the factory overclock between the two is hardly any difference. Not even 5 frames worth. Definitely not if you are running a 4k setup.
    post edited by FalconLover - 2014/10/02 05:16:49
    koshelkov
    Re: Will there will be a big difference between GTX 980 Classified ACX 2.0 vs Superclocked 2014/10/02 11:26:22 (permalink)
    Awesome, thanks guys. So I think I'll go with reference cooler, now I need to find these freaking cards in stocks :D Cant wait!
