dzdiode
Hi guys, im about getting two GTX 980 Ti Hydro and dont know if im ok with my power consumption. My spects: i7 4930K runs stock Corsair H100i CPU cooler ASUS P9X79 WS Ram Gskill ddr3 1600 64GB GTX 970 stock (i can remore it from the rig if necessary) ssd samsung pro 256gb x2 wd 1tb blue raid x4 case fans PSU be quiet! Dark Power Pro 10 1000W 80 plus gold thans a lot guys :)
ASUS P9X79 WS - i7 4930K - H100i - 64GB DDR3 1600 - ZOTAC GTX 970 - EVGA GTX 980 Ti HYBRID - SAMSUNG SSD Pro - BeQuiet! PSU 1000W 80+ GOLD - Fractal Design R4
MrImSoGood
Re: Will my Rig run two GTX 980 Ti Hydro? (power consumption)
2015/11/29 20:08:24
Not if you plan on overclocking
dzdiode
2015/11/29 20:14:42
MrImSoGood Not if you plan on overclocking
Hi MrImSoGood, thanks for the quick reply, no im not in overclocking since i use the rig only for 3D creation (rendering, video edition, motion graphics...), but i will leave the GTXs rendering at maximum GPU use for a long uptimes, like 4 or 5 days one shot... is it ok?
MrImSoGood
2015/11/29 20:17:54
dzdiode
I don't know much about Be Quiet! and their quality, so I can't really comment on how well it'll handle both card running max for do long
dzdiode
2015/11/29 20:28:28
MrImSoGood I don't know much about Be Quiet! and their quality, so I can't really comment on how well it'll handle both card running max for do long
Costs me more than 300$ CAD
MrImSoGood
2015/11/29 20:31:38
dzdiode
Ok......... Doesn't mean it good quality, just means it was expensive. Besides doesn't every cost more there than here?
dzdiode
2015/11/29 20:39:11
MrImSoGood Ok......... Doesn't mean it good quality, just means it was expensive. Besides doesn't every cost more there than here?
True facts :) For the more there than here, seriously, have no idea... never been in the USA and never checked US websites, how quebecor am i :P
2015/11/30 12:35:13
1000w is more than enough to run your rig 24/7.
dzdiode
2015/11/30 12:50:17
Sajin 1000w is more than enough to run your rig 24/7.
Hi Sajin, thanks for the reply, just to be shure, more than enough including the GTX 970 ?
2015/11/30 12:50:52
☄ Helpfulby dzdiode 2015/11/30 12:51:24
dzdiode
It will need to be removed.
dzdiode
2015/11/30 12:53:55
Thanks a lot :) just purchased one at full price... no deals on it for cyber monday so the second one have to wait. Maybe boxing day.
2015/11/30 12:56:21
dzdiode Hi guys, im about getting two GTX 980 Ti Hydro and dont know if im ok with my power consumption. My spects: i7 4930K runs stock Corsair H100i CPU cooler ASUS P9X79 WS Ram Gskill ddr3 1600 64GB GTX 970 stock (i can remore it from the rig if necessary) ssd samsung pro 256gb x2 wd 1tb blue raid x4 case fans PSU be quiet! Dark Power Pro 10 1000W 80 plus gold thans a lot guys :)
How many & what kind of pump do you plan on using to custom loop cool the new 980 Ti HYDRO COPPER GPUs?
dzdiode
2015/11/30 13:09:35
Cool GTX How many & what kind of pump do you plan on using to custom loop cool the new 980 Ti HYDRO COPPER GPUs?
Hi Cool GTX maybe im wrong but im talking about the Hybrid one and not the Hydro Copper
2015/11/30 16:42:44
dzdiode
OK - got it Title & post #1 said - "GTX 980 Ti Hydro"
post edited by Cool GTX - 2015/11/30 21:57:08
