Re:Will a 750 Watt Power Supply Be Enough for a GTX 480 and a GTX 280 (as PPU)?
2010/04/12 07:50:38
I think it'll run that setup just fine as long as it's a quality PSU with enough current on the +12Volt rail.
The GTX480+system should probably draw about 500 Watts under load. If you do mild overclocks you will probably draw about 550 or so. Are you using a Socket 1366 or 1156 system. If you're using the lower-power 1156-based system, the power draw of the GTX480 + system will probably be closer to 450 Watts.
Add in about 150 Watts for the GTX280 under PPU load, it looks like you'll be just fine. Just don't try to run Folding@home on the system, because that would put your PSU under 90-100% load for extended periods of time.
System Specs:
Chassis: Antec 1200
Mobo: EVGA x58 FTW3
CPU: i7 950 @ 3.9GHZ
CPU Cooler: Cooler Master V8
GPU: EVGA GTX470 @ 760/1520/1720
Folding GPU: EVGA 9800GT @ 700/1744/950
RAM: 3x2GB Patriot Sector 7
PSU: Corsair 750TX
Creative Sound Blaster...The One Everybody Has
