AnsweredWater cooling help 1080 FTW Heat issues?
RWesteen
2016/11/13 10:17:24 (permalink)
Hello, I have two evga gtx 1080 FTW's in SLi.  I am making a water cooled system for my pc.  Having heard of all the issues with the heat, do I still need to get the thermal pads from evga?  Or should I be fine with the ones sent with my waterblock (ekwb 1080 ftw block)?
3etatester
Re: Water cooling help 1080 FTW Heat issues? 2016/11/13 11:36:22 (permalink) ☼ Best Answerby Sajin 2016/11/14 19:34:03
Nah, if youre going to use the ek blocks there is no issue.
Think of it this way, the PCB design has no issues. Concerns were with ACX cooler. Since you're going with water blocks, you'll have no issues as long as you follow the install instructions.
Everything you will need will come with the blocks...minus all the other gear you need for a custom loop.
post edited by 3etatester - 2016/11/13 11:38:25
Z97 Classified :: i5 4670k @4.2Ghz :: 2-way GTX 980 SC's :: 3440x1440
SlideRulz
Re: Water cooling help 1080 FTW Heat issues? 2016/11/13 13:27:38 (permalink)
I'm running 1080 FTW in sli, no issues at all. Running Ek blocks and backplates.
i7- 5930k w/ XSPC Raystorm cpu block
Asus Rampage V Extreme
EVGA GTX 1080 FTW SLI / Ek Blocks & Backplates
RWesteen
Re: Water cooling help 1080 FTW Heat issues? 2016/11/16 14:50:38 (permalink)
Great to know, thanks for the help!
