Water cooling guide for noobs
Page: 12345 > Showing page 1 of 5
hatchetrunner
  • Ribbons : 25
2011/02/11 21:07:56 (permalink)
Water Cooling Guide
By Hatchetrunner a.k.a Juggalo23451
Video explanation link as well as where to get wc parts below the tutorial, My fist attempt at water cooling is below as well
Well I have been water cooling for a lil over 2 yrs now so I would figure I would help and make a guide. So let's get started
What is water cooling.  More or less it is the same way how your car's radiator works to cool your engine except on a smaller scale .
How much is it going to cost me- Depends on what you want to cool. The average coast for a cpu only loop is generally around 200-$$$. It will cost more if you want to add graphics cards, mosfets and etc. there is no real reason to water cool your ram,hdd. I don't see the point of water cooling your north bridge/south bridge either all it does is add restriction to your loop.If you want better temps on your chipset remove the old thermal paste with 90% Isopropyl alcohol or higher. Use a q-tip for this or a micro fiber cloth. Then put on new thermal paste like the ones listed below. but if you are going for insane overclocks go for it:)
What parts are needed? I will tell you the parts and suggest some parts as well.
Do not mix Aluminum and copper this will cause galvanic corrosion. You can have copper, brass, silver, and stainless steel in the same loop
Tubing and lingo you may see(get 10ft for cpu only,15ft or more if adding more rads blocks and etc:)
The most common sizes for tubing for water cooling are
3/8 inch
7/16 inch-people use this size tubing on 1/2 barbs for a tighter fit/seal
1/2 inch
Lingo
ID= Inner diameter
OD= Outer diameter
Primochill,tygon, masterkleer (budget)
Use tub cutters, razor or scissors to cut the tubing.
Dyes
Do not use any dyes or additives. If you want color get colored tubing
Reservoir ( always higher then the pump)- holds water
For reses it is all about preference really, You have the Swiftech Micro revision res for like 20 bucks or you could spend up to 200 bucks on a res to.
Pump(always below the res)
check instructions to make sure you know where the inlet is and outlet- This is the whole heart of you water cooling loop. Pushes the water in you loop around. Getting the right pump is critical don't get the right pump may get poor flow in your loop/poor temps to. They are usually measured by gph(gallons per hour) The more gph the better.
mcp35x,MCP355,MCP655, OCZ hydro flow(budget),jingway,
Note: The mcp355(has 3/8 barbs) is slightly better than the mcp655(1/2 barbs)
Pump top
 Dont want to use 3/8 barbs on a mcp355 get a top:) and choose what ever barb or compression fitting you like. Getting a top will help maximize the efficiency of the pump.
(XSPC,EK)
Water Blocks(center is always the inlet)
There are great water blocks out there for the CPU and Gpus. If you are going for the absolute best one out there. Then the EK HF is the king right now. Ek is also the best for gpus as well.
XSPC Raystrom water block(budget) this block is behind the ek hf by 3 degrees. XSPC for gpus as well.
Thermal Paste-
 MX3, MX4, OCZ Freeze, Shin Etsu, Indigo Extreme(the best but really expensive)
Barbs-
you will see g1/4 and g3/8. That is simply the thread size. What size barbs you get will depict on what size tubing you would want.
bitspower, enzotech,koolance
Compression fittings- Makes you loop look cleaner.
Has two parts the barb and a collar. The collar goes on the tubing first. Then mount the tubing on the barb. Screw down collar all the way.(video below) make sure to get the same id and od fittings as your tubing
Angled fittings 45 degrees
This can help make you tubing look cleaner and avoid sharp bends
Radiators(removes heat from you loop)-
inlet/outlet does not mater
Depending on what you want to cool will depend on the size of rad you want
Example a 240 radiators can cool most cpus., 360 rad for cpu and a gpu
Best rad right now is the GTX series radiators by Hw labs(loud setup)
Best rad(low noise) RX series rads by XSPC or SR-1 rad by HW labs
Budget rad Xspc rs.
P.s You can use a 77 Bonneville rad I believe if you wanted to.
Fans(removes heat from the rad) and static pressure
What is static pressure. It is the measurement of air to be push through a restrictive object. So the better the static pressure the better the fan for your radiator.
Panaflo,delata, Kazes 120x120x38 are great for rads like the GTX
Gentle typhoons (AP-15) are great for rad like the Sr-1 and RX series rads. Why you ask the noise to cfm is great and it has good static pressure as well.
Yate Loons are a great budget fan. XSPC 1650rpm fans are one above the yates
Fan Controller
(controls the rpms of a fan)
Want to quiet down your set up getting a fan controller can help with that:)
Clamps (secure them in the center of the barb)-
 use clamps, zips, or worm clamps to secure your tubing
Coolant- Distilled water is all you need.
Pt nuke as well to prevent growth in your loop or silver coil
I have all the parts now what?
1. Loop order, I usually do res-pump-rad-cpu-res for example, but you do not have to do that order just make sure you have the res before the pump
2. Bust out a scratch piece of paper and pen. Draw a rectangle representing you case then. Draw another rectangle representing your mb. Location is key for a water cooling loop.
Draw some sketches on how you want your loop to go.
3. Mount everything up.
4. Start from one point in your wc loop.with the tubing attached to a barb,
take the excess and move it to the next point to your loop then cut.(Attach tubing)Repeat the process until you are done.
5. Take out loop of you case(up to you)
6. Hook the pump to your power supply(make sure nothing else is
hooked up to the psu)
7. Take a paper clip and put it in the green wire and connect any black wire. this will create a load to turn on your psu. Make sure the psu unplugged before doing this.
8. Fill up the res with distilled water all the way to the top with a funnel
9.  Turn on the psu let the water go to about have way then refill the res.
10. repeat the process again until you do not need to fill the res up any more
Bubbles- To get rid of bubbles tilt your case side to side, back and forward
Leak testing- I say a good 8-12hrs should be enough. You can do more if you would like.
Hook up everything/install wc loop if outside of case and enjoy your temps
Vids
Water cooling basics
How to set up and install a water cooling loop 4 parts
Compression fitting
How to make a terminal block
Water Cooling Cases
Where to get wc parts
http://www.overclock.net/...watercooling-gear.html
Dont feel like going custom get a XSPC Rasa Kit
http://www.overclock.net/...rasa-750-rs-rx120.html
Credit goes to martin
If any additional help is need please feel free to pm me or ask a question here:)
post edited by hatchetrunner - 2015/02/12 14:42:52
121 Replies Related Threads
    Alucard666
    • Ribbons : 12
    Re:Water cooling guide for noobs 2011/02/12 08:32:43 (permalink)
    Fantastic thread man, totally BR worthy!
    Thanks for all the assistance, this is a very informative guide which I will be following.
    i7 2600k @ 4.2 Ghz || H70 || Maximus 4 Extreme || eVGA GTX 680 {2-Way SLi} || 16GB Vengeance || F120GB x2 [RAID 0] || 1 4TB WD Green  || Creative Sound Blaster Z || AX1200 PSU || HAF 932 || Samsung 46" 1080p 240hz 3D LED || z5500 + G930 || K800 + Performance MX ||
    • Ribbons : 52
    Re:Water cooling guide for noobs 2011/02/12 08:38:41 (permalink)
    BR awarded
    Alucard666
    • Ribbons : 12
    Re:Water cooling guide for noobs 2011/02/12 08:41:57 (permalink)
    Thank you again RJ XD
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/02/12 09:03:11 (permalink)
    Thanks bro,
    If there is anything I could add let me know. I tried to explain everything about water cooling. Also I think my vids correspond with the tutorial I made very well.
    post edited by hatchetrunner - 2012/04/14 17:10:43
    mikotan
    • Ribbons : 10
    Re:Water cooling guide for noobs 2011/02/12 09:44:57 (permalink)
    Good guide and the videos will help people a lot.
    One thing I would like to add though.
    Rotaries and angles if overstressed are more prone to leaks.
    the more rotaries in a fitting, the higher the possibility of it leaking
    if overstressed (i.e. moving it around too much, pulling, etc..).
    Oh and that adding a T-block to create a Drain port will help ALOT in future.
    Aside from that your videos pretty much sums em all up.
    post edited by mikotan - 2011/02/12 09:48:42
    Alucard666
    • Ribbons : 12
    Re:Water cooling guide for noobs 2011/02/12 10:02:18 (permalink)
    hatchetrunner
    Thanks bro,
    You did a very good job man.
    Gratz
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/02/12 10:25:31 (permalink)
    i forgot to add you could use a t line instead of a res.
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/02/12 10:56:22 (permalink)
    BR awarded
    Thank you for the BR.
    My goal is to educate everyone who want to water cool
    Also if any one needs help feel free to contact me via pm, skype,yahoo, or msn:)
    post edited by hatchetrunner - 2011/02/12 11:06:05
    Alucard666
    • Ribbons : 12
    Re:Water cooling guide for noobs 2011/02/12 10:58:02 (permalink)
    hatchetrunner
    BR awarded
    My goal is to educates everyone who want to water cool
    Oh trust me I will be in contact with you in the future bud. my next system for sure is gonna have a full water loop
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/02/12 11:11:42 (permalink)
    Alucard666
    hatchetrunner
    BR awarded
    Nice, hopefully I showed water cooling is not that hard. Just take the time and research on parts and all that fun stuff.
    Oh yes This is a video of my first water cooling rig. My biggest mistake is getting feser on coolant(noob)
    flasher4q
    Re:Water cooling guide for noobs 2011/02/12 11:53:54 (permalink)
    Outstanding post.....should make it easier for those starting out.....Now all they have to do go for it....
    EVGA X99 FTW K |i7 5820K 4.3 @ 1.25v| GSkill Ripjaw 32Gig DDR4 3000 | CoolMaster HAF 932
    XSPC D5 Dual Bay with Swiftech 655 variable pump| Koolance 380i CPU Cooler
    XSPC RX240 Dual 120mm Radiator | Lamptron FC5-V2 Fan Controller  | GTX 770 SC w/ACX Cooler
    1 Samsung 950 M2 256 Gig.
    1x Crucial M-500 CT240G| 1 Crucial M4 128 Gig
    Corsair RM 850x PSU| LG Blueray BH10 Rewriter
    Win 7 PRO 64 Bit
    46" Samsung F 6300 | Samsung S27B550
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/02/12 12:32:38 (permalink)
    flasher4q
    Thank you, once again if you feel like i need to add anything let me know:)
    Oddball99
    Re:Water cooling guide for noobs 2011/02/12 13:35:29 (permalink)
    Great guide, you explained it very well
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/02/12 14:53:33 (permalink)
    Oddball99
    Great to hear, helping people out is what I like to do:)
    owcraftsman
    • Ribbons : 57
    Re:Water cooling guide for noobs 2011/02/12 15:27:05 (permalink)
    Thanks for the contribution it is nicely done up.
    Phanteks Eclipse P400: | MSI Z170A G7 | 6700k 4.7x 1.345v H110iGTX | G.Skill F4-3000C15D-16GVR |2x EVGA 980 TI SC ACX in SLI | Samsung 950 Pro M.2 OS | WD2003FZEX Data | Corsair RM750i
    Phanteks Enthoo Luxe: MSI Z87-G45 Gaming v1.9 bios | 4770k 43x1.24v XSPC Raystorm | G.Skill TridentX2133C9 2x8-16GB | MSI R9-290x Kyrographics Hawaii w/Active Backplate | 2x 250gb 840 EVO Raid-0 OS | WD20003FZEX (data) | Corsair HX850
    Phanteks Enthoo Primo: | MSI Z97 Gaming 7 | 4790k 48x 1.254v EK-EVO | G.Skill TridentX2400C9 2x8-16GB | 2x Sapphire R9-290x ref (hynix) CF EK block Backplate & serial bridge | 2x 840 Pro Raid-0 OS | WD20003FZEX (data) | EVGA SuperNova 1000 G2
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/02/12 20:34:20 (permalink)
    Glad to of done it:)
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/02/13 18:42:29 (permalink)
    Feel free to suggest what vids I should do next about water cooling
    Alucard666
    • Ribbons : 12
    Re:Water cooling guide for noobs 2011/02/14 07:51:07 (permalink)
    hatchetrunner
    Should anything come to mind then I will definitely let you know.
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/02/16 11:35:12 (permalink)
    Alucard666
    hatchetrunner
    thank you:)
    pbhound
    Re:Water cooling guide for noobs 2011/03/02 15:53:49 (permalink)
    i know hatchetrunner probably said this but are blocks for the mosfets and NB/SB needed or recommended?
    MOBO: 790i ultra SLI
    Intel Core 2 Quad Q9300
    GPU: EVGA 9800 GTX+
    8Gb RAM
    Windows 7 x64
    Halo_003
    • Ribbons : 50
    Re:Water cooling guide for noobs 2011/03/02 17:35:12 (permalink)
    pbhound
    Just by what I read into this..
    He said basically that CPU/GPU/Mosfets are recommended, but that HDD/NB SB/RAM aren't.
    Now, HDD cooling has it's uses I'm sure but I don't really see much point in it.
    NB/SB I sort of agree. It depends one whether you want lower case temps. If you have high ambients year round I would recommend it. Or if you think it looks good, do it. Or, if you have a board that has either 1 or 2 NF200 chips, definitely do it. The boards with these chips can idle NB/SB temps at 70C. Even with a fan attached.
    RAM blocks are just mostly for looks really.
    Alucard666
    • Ribbons : 12
    Re:Water cooling guide for noobs 2011/03/02 18:29:11 (permalink)
    This should really be a sticky...
    #23
    nvasilkov@email.com
    Re:Water cooling guide for noobs 2011/11/29 18:49:03 (permalink)
    Excellent guide hatchetrunner! Any suggestions on water block for NB and SB of 790i chipset? Thanks.
    #24
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/11/30 07:31:39 (permalink)
    nvasilkov@email.com
    ek nb/sb
    http://www.frozencpu.com/..._EK-NBSB_5_Acetal.html
    #25
    prometheus_32
    Re:Water cooling guide for noobs 2011/12/06 20:38:09 (permalink)
    nice posts !!!
    will definitely help me out on my first WC buld as a total nub lol
    #26
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2011/12/13 11:29:48 (permalink)
    prometheus_32
    nice posts !!!
    glad to hear
    #27
    Rachnar
    Re:Water cooling guide for noobs 2012/04/04 13:52:47 (permalink)
    Hello, so i'm completly new to all this and as much as i look for the answer to this question, i can't find it and can't figure it by myself.
    So basicly can the waterblocks go on any gpu? As long as it is compatible with the card? You just take off the cooling system and replace it?
    #28
    hatchetrunner
    • Ribbons : 25
    Re:Water cooling guide for noobs 2012/04/12 09:58:47 (permalink)
    more info added:)
    post edited by hatchetrunner - 2012/04/12 10:23:53
    #29
    DarkOwnage_
    Re:Water cooling guide for noobs 2012/04/12 20:56:09 (permalink)
    Awesome guide! This is EXACTLY what I was looking for too!
    I am really, REALLY tempted about giving water cooling a go lol. I have been looking at pictures around the forums and water cooling just makes a computer dead sexy to me lol.
    And as a added bonus you are still here and active so I can ask you questions :D. First question, are the products you mentioned in the guide still accurate? Example, EK still makes the best CPU/GPU blocks? Swiftech MCP355 is still the best pump, etc? If so, might I suggest putting at the very bottom of the first post in bold something like:
    Information Accurate As Of 04/12/2012!
    That way noobs like me can trust we are indeed looking at accurate information still and don't have to go searching or asking around for product suggestions :).
    DarkOwnage_
    RiChess
    You need to unplug the ethernet cables every month and let the clogged internet packets drain out.
    #30
