Water Cooling Case Suggestions
hatchetrunner
  • Ribbons : 25
2012/05/08 10:10:24 (permalink)
Water cooling case suggestions
CASE LABS
MH10 -holds 360 rads
TH10 4 480 rads put 6 480 rad in if you want to
STH10 -480 rads
Cooler Master Cases
HAF932- 360 rad top
HAFX- 360 rad top
ATCS 840- 360 rad top rad on the HDD cages
COSMOS II- 360 rad top, or 480 top modification required. 240 rad bottom
CM690- 240 rad with modification
Storm Scout -360 rad with modification
Cosmos S- 360 rad top
SILVERSTONE
TJ07- 480 rad and 240 rad bottom
TJ11
LIAN LI
PC-P80-360 rad
Tyr PC-X2000F- 360 rad front
PC-A77(B)-240 rads modification
Lian-Li PC-V2120-360 rad on top and 280 in the front
NZXT
switch 810
Tempest EVO-240 rad thin
CORSAIR
800D-360 rad top, 240 rad bottom with modification
700D- 360 rad top, 240 bottom with modification
DangerDen
Waterbox -240 rads
Tower 29- 480 rad
LDR Tower 29 Double wide-480 rads
post edited by hatchetrunner - 2012/05/08 23:01:08
9 Replies Related Threads
    boredgunner
    Over 9000!
    • Ribbons : 78
    Re:Water Cooling Case Suggestions 2012/05/08 12:09:56 (permalink)
    Nice list.  I'd say that Case Labs or Mountain Mods are some of the best choices for water cooling.  Danger Den is another great option.  Mainstream cases can't do as much, Silverstone has the lead there followed by the CM Cosmos II most likely.  You did overlook some things though - the ATCS 840 can hold a 240mm rad on the HDD cages as well, and you forgot to check out the Lian-Li PC-V2120.  It can hold a 360 rad on top and 280 in the front.
    post edited by boredgunner - 2012/05/08 12:12:08
    crazyg0od33
    Re:Water Cooling Case Suggestions 2012/05/08 13:01:07 (permalink)
    whether it matters or not, your list for NZXT should DEFINITELY have the switch 810 on it if you want to watercool
    System In Progress:
    Asus Maximus IV Extreme // i5 2500k @ 4.8GHz // 2x EVGA GTX 580 Classified Hydro Copper in SLI // 16 GB Corsair Vengeance Black LP @ 1600MHz 1.5v // Samsung 830 120GB SSD // Seagate 2TB HDD // Creative X-Fi Fatal1ty // Corsair AX1200 //  NZXT Switch 810 White
    Cooling: Black Ice SR1 360mm // XSPC EX240 Multiport 240mm // DT 5Noz CPU Block // Koolance PMP-450S Pump // Primochill Primoflex PRO 3/8" ID 5/8" OD White Tubing // FrozenQ Liquid Fusion Blood Red/White Reservoir // White Monsoon Compressions //
    http://heatware.com/eval.php?id=79239
    Delirious
    • Ribbons : 55
    Re:Water Cooling Case Suggestions 2012/05/08 13:35:25 (permalink)
    I purchased the STH10 and put it together yesterday.  Spent half the day dolling it up.  It is by far, THE BEST case I've ever seen.   Spend the money and if you don't have it, save up and then spend the money.  there is so much room in the case.  So many customizable situations. It is VERY well built and the fit and finish are pristine.   I came close, very close to purchasing the Little devil, but the company wanted an extra hundred dollars for a full size window.  I think I spent 20 dollars on the Caselabs for the full size window.   What was also a deal killer for me is that the little devil requires you to put screws in to the side to secure it and then you have to remove them to get into the case.   The case labs has a hinged door.  All the panels come off of it and they snap back in place.  There's enought for two 480 rad in the bottom with 25 mm fans and still have 4 inches to spare between the two of adequate airflow.   You then can put anothe 360 rad in the top with a power supply or two power supplies if you need that.  I can't say enought about the case labs cases.   They are phenomically well built.
    It may be the last Case I will purchase.  I've owned Lian Li including the V2000 and the STH10 puts it to shame.
    "Be quick to listen, slow to speak and slow to become angry"
    Affiliate Code XZUMV9TJW5
    if you think education is expensive wait until you get the bill for ignorance
    hatchetrunner
    • Ribbons : 25
    Re:Water Cooling Case Suggestions 2012/05/08 17:23:17 (permalink)
    Delirious
    I completly agree Case Labs is a great company and Jim is an awesome guy he suggested me that I should get the TH10 instead of getting the TX10 knowing that I would  be spending less. I have the first TH10 case and is an awesome case probably will be my last unless I get another Case Labs Case lol :)
    post edited by hatchetrunner - 2012/05/08 18:42:54
    hatchetrunner
    • Ribbons : 25
    Re:Water Cooling Case Suggestions 2012/05/08 17:28:04 (permalink)
    I will add the info as soon as I get off work 11pm. I am no case expert just know on certain cases I have seen. Have a case suggestion send me a pm :)
    post edited by hatchetrunner - 2012/05/08 18:37:43
    hatchetrunner
    • Ribbons : 25
    Re:Water Cooling Case Suggestions 2012/05/08 18:41:51 (permalink)
    Thank you for the BR
    hatchetrunner
    • Ribbons : 25
    Re:Water Cooling Case Suggestions 2012/05/08 23:01:40 (permalink)
    thread has been updated
    direraptor22
    • Ribbons : 16
    Re:Water Cooling Case Suggestions 2012/05/09 01:11:12 (permalink)
    Awwww unfortunately with a HAF X I can only have a 360 rad.
    Great list!!!!!!!
    “The fascination of flight can't be expressed with words. But it really lies beyond the capabilities of human endeavor. Once you've experienced it, you'll never be able to forget it.” - Friedrich Oblessor
    hatchetrunner
    • Ribbons : 25
    Re:Water Cooling Case Suggestions 2012/05/09 08:46:41 (permalink)
    direraptor22
    Great list!!!!!!!
    I am sure with some modding you could add another rad if you want to
