Using System Restore Points (or lack thereof)
VistaHead
  • Ribbons : 131
2010/10/21 06:59:27 (permalink)
It seems that lately I have run across more threads where folks are having issues after installing an update, new hardware, or new software, and since they are not using System Restore points, they cannot revert their OS back to a good operational point prior to the installation of whatever caused the issue...and I don't understand why they do not use restore points.  I know that restore points can accumulate over time and end up hogging gigabytes of valuable hardware space, but it is very easy to only have one restore point at any given time on your OS hard drive.  In Windows 7, you simply click Start - All Programs - Accessories - System Tools - Disk Cleanup - Cleanup System Files - More Options - System Restore and Shadow Copies - Clean Up - and finally "Delete all but the most recent restore point".  IMHO, it is more than worth it to have a Restore Point that is a few gigabytes in size that I can revert to in order to correct a problem, rather than wind up having to perform a clean install or an image restoration to correct the issue.
5 Replies Related Threads
    z3r0t0l0rence
    • Ribbons : 20
    Re:Using System Restore Points (or lack thereof) 2010/10/21 08:03:51 (permalink)
    VistaHead
    +1
    I'd have to agree with you on this one.  The topic has been brought up many of times that one has to do a fresh install due to a bad update/install that is easily corrected with a Restore Point.  I personally have Acronis True Image WD Edition Software do a back up everyday on both my rigs in case of such a issue were to come up.
    Well said VistaHead!
    Z3r0t0l0rEnCe
    i7 930 OC 4.21
    EVGA E758
    GSkill 12GB
    Evga GTX 780 SC
    2x Kingston 240 Raid 0
    2x Seagate 4TB
    ShurikenTenshi
    • Ribbons : 11
    Re:Using System Restore Points (or lack thereof) 2010/10/21 08:58:27 (permalink)
    Very well said.  But sadly a good 90% of the computer users will either A reformat (if they know how) or B just trash it.
    YerBuddy
    • Ribbons : 59
    Re:Using System Restore Points (or lack thereof) 2010/10/21 09:18:18 (permalink)
    I agree.  I remember the old days when one of the only options was to format and reinstall.  Restore points, especially with Win7, have saved my butt more than a few times.  With SSDs they can be somewhat of a space hog, but easy to fix as you stated Vista.
    • Ribbons : 52
    Re:Using System Restore Points (or lack thereof) 2010/10/21 09:29:50 (permalink)
    What I recommend is that once in a while you turn off your restore points in order to clean out all of the old restore points provided, of course, that you don't need any of the old restore points. Then turn system restore back on and make a fresh restore point.
    Bkatt
    • Ribbons : 38
    Re:Using System Restore Points (or lack thereof) 2010/10/21 10:42:13 (permalink)
    I tend to do a monthly system disc image on my external. Having a E-SATA External makes it a lot quicker though.
    EVGA X58 (758)RV-1|1000W PSU|920 C0 @ 3.724 (19x196) 1.32V 200+VTT (HT on)|4GB EVGA 950 |5 250GB (raid 5)|windows 7 pro) & 1 1.5 TB|3 24" 1920x1200                          Code :X7G0Z0AY5U   CompTIA A+, Security +
