USB 3.0 card as Power Booster
wsmeyer
2011/01/06 11:53:25 (permalink)
There's a nice spot on the EVGA USB 3.0 card for a molex connector but I don't have a Power Booster to decipher where the power should go to. Does anybody have both of these and know if it would be possible?
William.
10 Replies Related Threads
    KMoore4318
    Pistoj Doulos Unum Pluribus
    • Ribbons : 233
    Re:USB 3.0 card as Power Booster 2011/01/06 15:47:51 (permalink)
    Will this help you  any ? Actualy JacobF would bethe one to ask.
    post edited by KMoore4318 - 2011/01/06 15:50:58
    wsmeyer
    Re:USB 3.0 card as Power Booster 2011/01/10 11:59:19 (permalink)
    Thanks, that and the PowerBooster I received today were all I needed.
    The PowerBooster puts 12V onto pins A2,A3,B1,B2,B3 and Ground to A4,A12,A15,A18,B4,B7,B13,B16,B18. Basically all of them, which is what I couldn't tell from the pictures.
    The picture of the USB 3.0 card on EVGA site has been photoshopped with an EVGA logo in the upper right. The actual card looks like this:
    Which is obviously designed for a surface mount 4-pin Molex. The 2 center connections are to common ground and go to all the ground pins on the PCIE connector so that part is done for us. The left connector goes to the points I've circled in yellow which are to mount other surface mount components but weren't used. These could easilly be used but I'm going to skip the molex connector and just solder wires straight to the board. I'll post some more pics later but this is a really easy mod that will let me use my USB 3.0 card instead of wasting the PCIE slot on the PowerBooster.
    William.
    KMoore4318
    • Ribbons : 233
    Re:USB 3.0 card as Power Booster 2011/01/10 20:26:20 (permalink)
    William, I hope you don't mindI asked EVGA about your Idea, I got this from EVGA, can not tell you what or where the problem would be, but it would appear that there is one.
    EVGA "Interesting idea, but the card would have to be redesigned. "
    wsmeyer
    Re:USB 3.0 card as Power Booster 2011/01/12 10:35:03 (permalink)
    I don't mind at all. The card would have to be redesigned, if you just mounted a molex connector on it as it is it wouldn't do anything as the 12V power connector wouldn't go anywhere. Here's what I ended up with and it works perfectly:
    This side of the card is up against the video card so custom wiring can't be seen so I'm happy.
    William.
    ZachA
    • Ribbons : 29
    Re:USB 3.0 card as Power Booster 2011/01/12 12:15:56 (permalink)
    Someone give the man a BR!
    That is one of the most USEFULL and effective mods I have seen in a long time!
    And its a two for one punch, you get USB 3.0 and a power boost all in one.
    you should do some testing with the card in and out and see what the 12v reads
    Reported post for a BR You deserve it wsmeyer!
    post edited by ZachA - 2011/01/12 12:18:36
    EVGA_JacobF
    EVGA Product Manager
    • Ribbons : 22
    Re:USB 3.0 card as Power Booster 2011/01/12 13:33:59 (permalink)
    That is very cool.
       jfreeZr - [rebuilding]  4770k @ 5.2ghz || evga z87 classified || 2x evga gtx 980 acx2 || 16gb 2.6ghz ddr3 || 500gb 840 evo raid0 || evga supernova 1000 P2
       hadronGTX - 4770k @ 4.4ghz || evga z9 stinger || evga gtx780 ti acx || 16GB 2.6ghz ddr3 || 480gb vertex3 raid0 || 500w gold
    • Ribbons : 52
    Re:USB 3.0 card as Power Booster 2011/01/12 13:43:10 (permalink)
    Jacob says it's cool so I assume that means the wiring is ok. BR awarded by the way.
    wsmeyer
    Re:USB 3.0 card as Power Booster 2011/01/12 14:15:24 (permalink)
    Thanks guys,
    Here's some more pictures starting with the back of the card:
    Pins A2 and A3 (2nd and 3rd from right) need 12V but you can see the one large trace they share dead ends into those four copper holes. Those are crossover holes that connect the traces to the traces on the opposite side of the board. That means we don't need to do anything there.
    This is the front side of the card:
    Here we need 12V to pins B1, B2, and B3 (first 3 from left). This is after I used an exacto knife to scratch away the coating on the trace they share. It is important to note that pn B4 is GROUND, if you scratch the coating off of it the solder will run onto it and SHORT OUT THE CARD. That's really the only thing you have to worry about, and you absolutely should use a continuity tester to verify that you haven't created a short before you plug the card into your MB.
    William.
    gnfnr100
    • Ribbons : 7
    Re:USB 3.0 card as Power Booster 2011/01/12 14:19:17 (permalink)
    Jacob, can you give some insight to your personal thoughts on this, not just cool. lol.
    your opinion is highly valued and regarded and more of it would be nice to see!
    PSU: 1000 watt Corsair
    CPU: i7 950 @ 4.3 ghz
    CPU COOLER: Noctua nh-d14
    GPU: Galaxy 480 @ 900 core 2100 mem
    CASE: Custom Made
    RAM: Corsair Dominator GT 2000mhz 3 x 6gb
    MOBO: Evga Classified x58 760
    HARD DRIVE: 1TB WD Black
    DISK DRIVE: Blu Ray
    The word NVIDIA is a mixture of n —a mathematical variable meaning "to the highest degree"— and video —which comes from Latin videre, "to see"—, implying "the best visual experience."
    rodymcamp
    Re:USB 3.0 card as Power Booster 2011/01/12 18:29:07 (permalink)
    this is awesome
    pc1
    Evga Classified bios s22d
    Intel Core I7 920@3.7ghz (no voltage adjustments)
    Corsair Vengence 24GB @ 8-8-8-19 T2
    Evga gtx480x2 SLI
    OCZ Vertex2 120x2 raid0
    Western Digital Caviar Black WD640 x2 raid0
    HITACHI Deskstar 7K1000
    Corsair HX1000
    Corsair H50
    Thermaltake Spedo Advance Package
