Took apart Classifed NB cooler and changed LED color!
shawnoen
2010/07/01 23:12:12 (permalink)
Been wanting to try this for a while and finally got around to it. Was able to source an extra chipset cooler assembly so my warrenty wouldn't be voided.
Top portion of cooler is super easy to remove. You have to remove the entire chipset cooler assembly. Then underneath the NB cooler there are 2 small channels with phillips head screws at the end. Thats what holds the plastic top to the NB cooler itself. I was curious to see the bottom of the plastic piece as well to see where the wiring was. I have a 50mm fan on my NB cooler and always wanted to add a new screw hole but was scared I'd hit wiring or something behind it. As you can see the wiring is carefully tucked on the other side and held with hot glue from the factory.
Remove those and you see the wiring for the 2 LEDs and the LEDs themselves. Super easy to swap. Unsolder current red LEDs and resolder LED color of your choice. Re-shrink wrap connections and your done!
I went with white for mine....
12 Replies Related Threads
    Section_25
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 03:08:09 (permalink)
    haha ....NICE !!!
    I want a blue one !!!!
    CPU: Intel Core i7 CPU 920 @ 2.6 GHz (Stock)
    Motherboard: ASUS Sabertooth x58
    RAM: G.SKILL Ripjaws (6GB) DDR3
    GPU: GTX 770
    SSD: Kingston 120gb
    PSU: Corsair TX750W
    Heatsink: Corsair H50 (Push/Pull)
    Display: Acer 24" Widescreen 1920x1080
    O/S: Windows 8.1 Pro 64x
    sgtharry
    • Ribbons : 7
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 04:01:29 (permalink)
    NICE! good job.
        My Affiliate Code: JQ2TUWM6Y9
    +1 my Rig if you like it
    intergalactical
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 05:29:07 (permalink)
    Thats all? I thought you need like super duper powers. XD
    _Nite_
    • Ribbons : 46
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 07:33:35 (permalink)
    very nice :)
    Halo_003
    • Ribbons : 50
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 10:22:06 (permalink)
    NICE! I like the way that looks!
    SirJamesDTech
    • Ribbons : 46
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 10:36:09 (permalink)
    Great work!
    I wanna know if this voids the warranty, though. As it states:
    • The product is returned to EVGA in the original factory configuration and condition. All aftermarket modification must be reversed before sending in the product for replacement.
    Suppose you could just change it back to red, but has it already been voided?
    Just want total clarity.
    Asus Maximus VII Hero Z97 | i7-4790K Devil's Canyon @ 4.4GHz | Corsair H105 | 2x Asus Strix GTX 970 OC Edition SLI | Samsung 850 Pro 256GB, Samsung 840 EVO 1TB, OCZ Vertex 3 120GB SSD | 16GB Dominator GT DDR3 2000 @ 2400 | EVGA 850W G2 Full Modular | Asus 27" 3D 120hz VG278H | Creative Sound Blaster Z | Audio-Technica ATH-M50X Headphones | Razer Blackwidow Chroma RGB Mechanical Keyboard | Corsair 760T Full Tower
    shawnoen
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 11:09:53 (permalink)
    I have a complete extra chipset cooler assembly. If something happens I can re-install it and it will be back to factory condition.
    emmett
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 11:28:38 (permalink)
    that's neat! good job
    EVGA X58 classified 760
    Core I7 920 D0
    Corsair HX1000
    2 GTX 295 +'s
    CPU on water with heatkiller
    deicida
    • Ribbons : 27
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 13:27:39 (permalink)
    Nice little mod, good work!
    HAF 932
    EVGA X58 E760
    i7 920 D0 @ 4GHz
    Swiftech Apogee GTz
    G.Skill Trident 6GB @ 1900MHz
    PoV GTX 480
    2x640GB WD Caviar Black(raid-0)
    Corsair HX850
    bg8780
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/02 13:56:45 (permalink)
    I would love to do i to be different but I like red the best lol
    shawnoen
    Re:Took apart Classifed NB cooler and changed LED color! 2010/07/06 02:52:45 (permalink)
    Ya, red is nice for most but I just wanted something to match my other stuff!
    zer0byte
    Re:Took apart Classifed NB cooler and changed LED color! 2010/08/30 15:01:48 (permalink)
    it will void the warranty for sure.
    nice job losing ur warranty :)
    i7 Gaming PC
    i7 930 4.2GHz 1.244V HT enabled.
    ASUS Rampage III Extreme
    EVGA GTX 480 Superclocked + SLI
    Corsair Dominator 6GB DDR3
    Corsair HX 850W
    Coolermaster HAF X
    Corsair H70 Push/Pull Scythe Gentle Typhoon AP-15
    Crucial RealSSD C300 64GB x2
    Asus Bluray Combo
    Seagate 1TB (storage drive)
