Been using HDAV1.3 for one year without incident. Have been OC'ing new motherboard (EVGA 4Way Classified) and CPU(I7 960) for last few weeks. no other changes. Had been fine before OC'ing. Now mobo does not recognize it. Actually RMA'd sound card but replacement does the same. How do I get mobo to recognize card. it powers up properly. Have tried different PCI-E slots. Disabled on board audio. Removed CMOS battery for reset. Running stock speeds on everything. Have 2EVGA GTX480's SLI'd and everything's watercooled. On board sound really sucks in comparison. Can anybody help?
Mobo...X58 4-Way Classified CPU...I7 960 GPU...EVGA GTX 780Ti X2 EK Watercooled RAM...Corsair Dominator GT DDR3 2000MHz 6Gig SSD...Intel 160 Gb HDD...WD Caviar Green 1TB PSU...Silverstone Strider 1500W Case...Mountain Mods Extended Ascension CPU waterblock...EK Supreme HF Full Copper"Gold" Radiators...Black Ice GTX360 X2 Water Pump...Swiftech MCP655 X2 OS...Windows 7 Home Premium 64bit Sound Card...ASUS Xonar HDAV1.3 Headphones...Beyerdynamic DT770 Pro Monitor...BenQ 24" 120Hz X3 NVidia 3D http://www.heatware.com/eval.php?id=72035 [url=http://www.evga.com/re[/
maniacvvv
- Ribbons : 159
Re:Sound Card Not Recognized
2011/03/23 21:12:09
Did you install SP1? The time at which this seems to have happend gives a clue... Any other changes, like video drivers? If the new card is acting the same, its either a software change that knocked it out.. or maybe something to do with the slot its in. Never hurts to unplug the front sound headers... just in case they shorted or are damaged
2011/03/24 15:11:55
Creative X-Fi titanium had a similiar issue for me I had to use the original drivers disc to get the MB to recognise the sound card. Just downloading the drivers wouldn,t do it for some reason. Have you used drive sweeper by any chance? That can clean to much sometimes who knows I reinstall a fresh OS every 7 weeks or so .I tinker alot,hope this helps good luck.
2011/03/24 17:42:14
Thanks for the ideas guys. I'll try them as soon as I get home from work.
epson800
2011/03/25 03:46:20
make sure your memory gap setting in bios is set right, otherwise some pci cards refuse to work
2011/03/25 10:31:22
Thanks for suggestions, so far they aren't working. Reluctant yet to re-install OS due to so many programs to re-install. What is correct memory gap setting? If that doesn't work will try older bios. Updated bios a few weeks before problem occured.
epson800
2011/03/25 12:54:36
i think 1.5G, after that you can try 2.5G if neither help just set it back to auto
2011/03/27 07:33:00
Neither of those settings worked and neither did rolling back drivers. Will re-install OS today.
ritaylor
2011/03/27 08:41:42
jboudwin
DON'T re install OS yet ! I had a similar situation. Try this first: remove all software for sound card. Shut down but don't restart. Take sound card out of the computer. Start computer without soundcard. Let windows fully load (so windows knows the soundcard isn't there) Shut down, put the card in and restart windows. Windows should now find the card. Reinstall the software for the soundcard and you should be all set.
EVGA Classified3 Core i7 990x 12 GB Corsair Vengeance 1600 @ 9-9-9-24 2T EVGA GTX 570 600GB Intel SSD 600GB Velociraptor Corsair AX850 psu
2011/03/30 19:52:20
When all else failed I tried that too ritaylor. Unfortunately that didn't work either. Re-installed OS....what a mess!!! I got so mad I'm ready to take a hammer to the sound card. It's 2 days now re-installing all the software...so much for Windows backup. All major programs and games lost. At least I was smart enough to always buy on disc and avoid online downloads...it's much easier especially when passwords are locked up in a program that's not working. I finally gave up trying and bought the newest Xonar Essence card...on-board sound is that much different. Thanks for everyone's help.
2011/04/03 15:59:50
OOOOOOOHHHHHh My God!!! I got it...found my fix. I'll detail it especially since my problem has occured to others. Hopefully my deadends and errors will help someone else. Tried to play an online game and had no sound...hadn't played in a few days. In that interval I had updated BIOS and Win 7 SP1 loaded (automatically). Tried many options as noted including RMA'ing card, two OS installations, and new sound card (it's going back). Apparently sound cards (not just Xonar) have had problems of randomly failing to be recognized. The driver refuses to load or install. This is due to overwriting of the EEPROM. This website has the fix: http://www.alsa-project.org/main/index.php/Xonar_EEPROM_Failure On first OS install I neglected to disable automatic updating (so it updated) and could not tell if SP1 was the cause. Reinstalled again but this time remembered to disable updating and all I connected was the sound card to ensure no other conflicts. Found in Device Manager a yellow triangle with exclamation point at PCI Standard PCI to PCI Bridge. Double clicking it says "This device cannot find enough free resources that it can use". Disabling various devices did not free up any resources. Some fixes online suggested changing IRQ's or disabling COM ports. This lead me to...an EVGA posting... about updating the EVGA 758 BIOS. In BIOS under "PnP/PCI Configurations" is "Reserved RC for Bridge". On that BIOS it is "Enabled" but not on the BIOS that I just updated on my 762 mobo. I enabled it and HALLELUJAH!!!! XONAR HDAV IS RECOGNIZED. Took a lot of pissing and fuming to get this. Hope others don't have to. And thanks to everyone that offered advice.
2011/04/03 16:28:15
^ Congrats! Nice to read a happy ending! :)
NOTE: I will be offline from 11/21/16 to 12/15/16. If you have a problem please PM another Mod, as I won't be available to answer you back. Thanks. My Affiliate Code: 8WEQVXMCJL
2011/04/03 16:41:20
Thanks. No hair left but it'll grow back.
jsammer
2011/05/10 19:52:32
jboudwin In BIOS under "PnP/PCI Configurations" is "Reserved RC for Bridge". On that BIOS it is "Enabled" but not on the BIOS that I just updated on my 762 mobo. I enabled it and HALLELUJAH!!!! Thanks, you are now my hero. You saved me from raging.
