Helpful Reply[Solved] Help with G.Skill at 2133MHz
gonsa
2012/11/21 13:11:14 (permalink)
Hi,
So I'm quite proud with my recent build, but I have a question relating my memory frequency.
I have G.SKILL RIPJAWS X DDR3 2X4GB 2133MHZ CAS11 1.5V, F3-17000CL11D-8GBXL.
I made a stable CPU OC to 4.5GHz and my memory frequency at the UEFI Bios shows 2133MHz but in the CPU-Z it shows 1066MHz..
Also in Bios the voltage shows 1.6v and I don't know where it came from and how to change it because in the box says I could have it at 1.5v.
Could someone help me explaining me this issues and tell me what am I doing wrong?
here are some screenshots that I took:
post edited by gonsa - 2012/11/22 01:22:32
Case: Lian Li OD 11 | Mobo: MSI MAG X570 Tomahawk Wifi | CPU: AMD 3700X | Memory: G.Skill Trident Z Neo 32 GB DDR4-3600 CL16 | Graphics Card: EVGA 3080 FTW3 Ultra | SSD: Samsung 970 Evo 1 TB M.2-2280 NVME | Samsung 860 Evo 500 GB | PSU: SuperNOVA G2 1000W | Sound Speakers: Creative Inspire T3100 | Mouse: Logitech G903 | Monitor: LG 34GN850-B 34.0" 3440x1440 144 Hz
doorules
  • Ribbons : 21
Re:Help with G.Skill at 2133MHz 2012/11/21 13:33:55 (permalink) ☄ Helpful
Pretty sure when you go to xmp #1 voltage will move to 1.6 for stability. Mine does the same thing for xmp #1 at 2133.
The 1066 is correct, 1066 x 2 =  your 2133 speed. Just how they show it.
boulard83
Re:Help with G.Skill at 2133MHz 2012/11/21 13:58:25 (permalink)
doorules
+1, 1066 is 2133 DDR3 ( DDR stand for double data rate 3 )
BTTB • Gigabyte Z87X-OC • WCed I7 4770k • 2x8gb Ballistix 1600mhz • Zotac GTX 780
Asus Xonar Pheobus • OS -> Toshiba Q 256gb • Games -> 2x Agility 4 256gb Raid0
Corsair HX850 • Tecnofront HWD BenchTable • Asus VE278Q 5760x1080
Serveur • Asus Z77m PRO • 2500K • NH-C12P • 4x4gb G.Skill Ares 1600mhz
Agility 4 128gb • Corsair CX430M • 1TB Black • 2TB green • 2TB Red
gonsa
Re:Help with G.Skill at 2133MHz 2012/11/22 01:21:17 (permalink)
thank you doorules and boulard83 :D
