EhCanadian
Just got my new 1070 ftw and while playing bf4 at 1080 ultra I hear coil whine. As its my first card, Im not sure if thats a normal amount or If I need to RMA. Smaller other issues include the middle led sections not being exactly the same hue as the outer portions (they're more bluish white) and the fans jolting randomly while under low usage with the fans off. Full specs Coil whine update 23/07/2016: Here is audio of the whine. The mic is set on top of my computer and the whine gets audible at around 0:15 in when I load up a level of battlefield and start playing. I get from 80-140 fps dependent on whats going on. Ive also now noticed I can hear the faint whine even while my monitors are off.
post edited by EhCanadian - 2016/07/26 21:38:46
glenn37216
- Ribbons : 9
Re: Small amount of coil whine (and a few other worries)
2016/07/19 22:12:06
Normal stuff... Coil whine may decrease after a while of hard usage. Tis normal to have a little ... Tis not normal to have a lot.
McEvga
2016/07/20 02:23:44
There shouldn't be any coil whine if the coil was manufactured correctly.
Z.PricyWolf
2016/07/20 02:40:49
Before the RMA. PSU ・Coil whine = Temperature... PSU Fan Dose not work. Mother Board ・Coil whine = Voltage
122-CK-NF68-AR / 122-CK-NF68-A1 / 132-CK-NF78-A1 / 132-YW-E178-A1 / 132-YW-E179-A1 / 151-IB-E699-KR128-A8-N303-TX / 512-P3-N973-TR*2 / 012-P3-1570-AR*2 / 012-P3-1572-AR / 03G-P4-3788-KR⊰━━━━━━━≪☆≪ ☆・.*--゚– ☆⊲・*-.-゚– ☆・⊲⊰.-・-*-゚- ☆-⊰・*-.-゚– -
EhCanadian
2016/07/20 14:41:50
ZonePricyWolf Before the RMA. PSU ・Coil whine = Temperature... PSU Fan Dose not work. Mother Board ・Coil whine = Voltage
Not sure what the Mother Board part means but Il check to see if my psu fan is spinning under load. Its a really decent evga 550watt g2 (with the fanless mode switch on) and Im running the card at stock settings though so I doubt its the issue.
post edited by EhCanadian - 2016/07/20 14:44:42
Balubish
2016/07/21 00:32:55
EhCanadian Just got my new 1070 ftw and while playing bf4 at 1080 ultra I hear coil whine when I put my head near to the computer. As its my first card, Im not sure if thats a normal amount or If I need to RMA. Smaller other issues include the middle led sections not being exactly the same hue as the outer portions (they're more bluish white) and the fans jolting randomly while under low usage with the fans off.
So how often do you play with ur head right next to ur case and no ingame sound?
Balubish Tech on Youtube, Gaming, Watercooling etc Balubish Music - Youtube, Google Store ,Electronic beats
EhCanadian
2016/07/21 01:47:16
Balubish
Well, thing is, my case is the Thermal Take V21 It isnt very quiet as a case and it sits right next to me so it is audible while playing
Balubish
2016/07/21 04:06:31
Hmm yeah then you must have a high pitching sound on that, I barely heard it on my 1080 ftw with no sidepanel unless the frames jump above like 400fps. The fans are louder compared to the sound from coilwhine on max fanspeed. Well well, i dont hear it and never had a problem with sounds like that while playing, fans annoy me more.
EhCanadian
2016/07/23 01:41:05
Updated with sound of whine
- Ribbons : 84
2016/07/23 01:50:40
What are your complete system specs to include model and make of PSU?
EhCanadian
2016/07/23 04:03:35
rjohnson11 What are your complete system specs to include model and make of PSU?
Thought I included it, but I guess I forgot. Its not that I have a shoddy power supply, I have a 550 watt evga g2. Full specs
Tech_RayH
- Ribbons : 7
2016/07/23 09:46:45
McEvga There shouldn't be any coil whine if the coil was manufactured correctly.
That is incorrect, almost every inductor coil will make whine when current passes through it, most are outside of the range of human hearing, but is not an indication of improper manufacturing. Any coil with a small heat in it will suffer from magnetostriction.
post edited by EVGATech_RayH - 2016/07/23 09:48:59
...an untrammeled flow of words in an open forum. - Adlai E. Stevenson
- Ribbons : 84
2016/07/23 09:59:08
I have a very small amount of coil whine and it only occurs when folding at home. Folding at home puts almost 100 percent demand on the GPU all of the time. During normal gaming I don't have this whine.
EhCanadian
2016/07/23 13:53:37
EVGATech_RayH
Well, given this is audible, thats rma worthy right?
