Helpful ReplySLI options not showing in NVidia control panel...
uncle poop
2016/10/29 19:02:56 (permalink)
So I was finally able to get a new motherboard to replace the latest in motherboards to fail me. I went from an EVGA Z68 to an Asus P8Z68-V LE, running GTX560 Ti's in Windows 7. Both cards are seen in both device manager and NVidia control panel. I have uninstalled and reinstalled drivers for the cards, I have checked both cards individually and switched them in the pci-e slots. I have tried two different SLI bridges and still no SLI options in NVidia control panel. I also uninstalled and reinstalled NVidia experience. (I hate NVidia experience)
Anyone have any ideas of what I am missing? According to the info I have found online and in the manual for the motherboard, it is sli ready. So I am at a loss on what to try next. I hate to think both bridges are bad but anything can happen I guess.
  • Ribbons : 68
Re: SLI options not showing in NVidia control panel... 2016/10/29 19:08:25 (permalink)
Did you try the other set of SLI Forks that are on the Cards?
This Card Only Has One Fork
post edited by bcavnaugh - 2016/10/29 20:00:45
uncle poop
Re: SLI options not showing in NVidia control panel... 2016/10/29 19:12:28 (permalink)
Yes with both bridges, I forgot to add that to my post. This is very frustrating for me. I know I am missing something but I cannot figure it out.
  • Ribbons : 68
Re: SLI options not showing in NVidia control panel... 2016/10/29 19:34:03 (permalink)
uncle poop
Only a Single Fork!
post edited by bcavnaugh - 2016/10/29 19:37:08
  • Ribbons : 68
Re: SLI options not showing in NVidia control panel... 2016/10/29 19:38:06 (permalink)
Are the BOTH Cards showing in your BIOS as x8 or x16?
  • Ribbons : 68
Re: SLI options not showing in NVidia control panel... 2016/10/29 19:40:26 (permalink) ☄ Helpfulby uncle poop 2016/10/30 15:48:47
This is why your MB realty does not support SLI https://www.asus.com/Motherboards/P8Z68V_LE/specifications/
Multi-GPU Support:  "Supports AMD Quad-GPU CrossFireX™ Technology Supports LucidLogix® Virtu™ Technology"
1 x PCIe 2.0 x16 (blue) *1
1 x PCIe 2.0 x16 (x4 mode, black) *1
2 x PCIe 2.0 x1
3 x PCI
Their is a third part tool that may work for you but I do not have a link sorry.
uncle poop
Re: SLI options not showing in NVidia control panel... 2016/10/29 19:44:09 (permalink)
2 x PCIe 2.0 x1
3 x PCI
That is one piece of info about the card I did not see. Everything else including the download manual from Asus shows it does sli. DO you know the name of the third party tool that may work? I only picked this card up because it was my cheapest option that showed sli. Just my luck for this to happen.
  • Ribbons : 68
Re: SLI options not showing in NVidia control panel... 2016/10/29 19:49:56 (permalink) ☄ Helpfulby uncle poop 2016/10/30 15:48:42
As I said above no I do not but their is a Forum Member that knows and he may post that info for you.
Are you on the Current Bios on that Motherboard?
P8Z68-V LE BIOS 4102 2014/05/22  Global
Also is the "Intel Chipset Drivers" Up to Date?
P8Z68-V LE  User's Manual (English) Global
post edited by bcavnaugh - 2016/10/29 19:54:09
uncle poop
Re: SLI options not showing in NVidia control panel... 2016/10/29 19:53:26 (permalink)
I am going to check the bios right now and see where I am at. Thank you for all your help, I really appreciate it.
  • Ribbons : 68
Re: SLI options not showing in NVidia control panel... 2016/10/29 19:54:55 (permalink)
No Problem, we are here to help anyone with anything.
post edited by bcavnaugh - 2016/10/29 19:59:39
  • Ribbons : 122
Re: SLI options not showing in NVidia control panel... 2016/10/30 01:13:10 (permalink) ☄ Helpfulby uncle poop 2016/10/30 15:48:33
Third patry tool to enable sli... https://www.techpowerup.c...ifferent-cards.158907/
uncle poop
Re: SLI options not showing in NVidia control panel... 2016/10/30 05:34:16 (permalink)
Thank you for the link. I will give this a try and see how it is. I may just try to send this motherboard back and get a refund and maybe sell the rest of the computer. This thing has been a pain in the behind for a few months now.
uncle poop
Re: SLI options not showing in NVidia control panel... 2016/10/30 05:56:13 (permalink)
So whatever trojan, virus or whatever was in the exe for the forced sli is now in my system. All I got was an error it was aborted and to contact the person who made the program. Thank you all for the help I am just going to give up on this system for a bit. I cannot find a suitable motherboard for a reasonable price. Even used people what over a $100, I guess they don't know that these boards and over 5 years old and used. Hope I can send back this one and get my money back.
  • Ribbons : 68
Re: SLI options not showing in NVidia control panel... 2016/10/30 10:56:49 (permalink)
Thanks Sajin
  • Ribbons : 122
Re: SLI options not showing in NVidia control panel... 2016/10/30 16:02:33 (permalink)
Thanks Sajin
No problem.
