leoman77
Hi, Ya sometimes (frequently) right click doesnt work :( POOPY Trying to kill Demons isnt easy you know. What can I do?
EVGA_JacobF
- Ribbons : 26
Re: Right click not working while holding left click playing Diablo 3
2014/06/17 17:10:33
TECH_DaveB
- Ribbons : 46
2014/06/18 06:23:27
leoman77 Hi, Ya sometimes (frequently) right click doesnt work :( POOPY Trying to kill Demons isnt easy you know. What can I do?
Do you have this issue in another game, for example, if you fire up any shooter game, remap jump to right click, hold down left click and try to jump, see if the issue is repeated outside of D3. I suggest this I have seen button mapping as well as macros from other brands of mice that would have issues only within certain games/engines.
Viper97
- Ribbons : 11
2014/06/18 06:32:00
I had a problem early on in one of the Batman games where the middle mouse button wouldn't work. It turned out the wrong drivers were loaded and it didn't recognize the mouse properly once I loaded the correct drivers it worked. Might want to check to see if you have more than one mouse device in the hardware panel.
TECH_DaveB
- Ribbons : 46
2014/06/18 11:32:15
Leoman77, have you had a chance to try my suggestions? Also, I left you a voicemail to see if we can get this handled asap. If this is strictly a Diablo 3 issue there are certain skills that will take precedence over others, for example, with a Wizard, personally I use Chain Lightening (generator spell) left click, and Arcane Torrent (mana spender) Right click, I can hold the trigger on Arcane Torrent until I run out of mana, if at any time I tap or hold left click Arcane Torrent stops and Chain Lightening starts as it is a spell that seems to be prioritized, and as long as I hold down left click, right will NOT work. This is due to how the games spell mechanics work. If this is the issue, there is no work around, if not, please let me know some details and I will assist, also as I suggested before, please test in a different game. Lastly after you hit 10 posts you can PM me, you can also email me directly at DaveB@evga.com as well.
leoman77
2014/06/18 15:24:38
No its not the skills It actually doesn't click like my old Razer Krait mouse that this just replaced..... It will click 50 times then it wont . I took the plate off correctly to reseat it. Didnt help Plz help
EVGATech_ChrisB
EVGA Tech Support
2014/06/18 18:24:51
Dear leoman77, I am sorry to hear that you are continuing to have a problem. I have setup a warranty request to assist you with having this mouse exchanged and I will be emailing you with further details on this process. Please do not hesitate to let me know if you should have any additional questions or concerns with your EVGA products that I can support you with. chrisb@evga.com
2014/06/18 18:27:32
My mouse better not do this or it's going straight back for a refund.
Viper97
- Ribbons : 11
2014/06/19 04:28:49
Sajin My mouse better not do this or it's going straight back for a refund.
I'm pretty sure the mouse works but just not in Diablo 3... a quirk in the game perhaps. Here's a thread by the OP asking for a macro for said mouse button in Diablo 3: http://forums.evga.com/Ho...10-I-won-m2179460.aspx
gpr1231
2014/06/22 01:47:46
I've been playing D3 with this mouse an haven't experienced any issues with it.......great mouse.
ESalgado
2016/02/04 13:22:26
I hate to resurrect a dead thread from years ago but I recently encountered this problem and I believe it is a design flaw caused by the removable cover. If you hold right click down with a good amount pressure and inadvertently slide the top cover back or forth, it can cause the left click to get stuck... This may cause me to return my mouse and look for something else. I am still a big eVGA fan but I don't like the frustration caused by this particular product.
post edited by ESalgado - 2016/02/05 10:14:01
ESalgado
2016/02/05 10:28:46
I have figured out what is causing the sticky left or right click and it seems to be due to the removable cover. If you push anywhere behind the mouse wheel on either side, when you click the other side, it will cause the button to stick until you release both sides of the mouse. I believe it is a design flaw and will probably cause me to return the mouse for a refund if at all possible.
