Required power supply
leroy94
2014/09/30 14:15:06 (permalink)
I'm trying to put a new pc together and its the first time I've to do it and I'm struggling to spec a power supply as I blew my last one up trying to do this, it was an EZCOOL 800w ambience one though and I have now found out that they are cheep and nasty units. I will list below the spec of the machine I am building and I would like to now the size and brand that you all would recommend. I was considering a EVGA supernova 1200W P2 80+ Platinum.
PC spec:
Motherboard: ASUS crosshair v formula-z
CPU: AMD FX-8320 3.5GHz 8 core
Memory: G.Skill Ripjaws 8gb (2 x 4gb) 1600
Storage: Western digital 2 TB with the possibility of expanding to a second 2 to 4 TB drive
Video: Gigabyte Windforce Radeon R9 290x 4GB
Case: Cooler Master Storm Trooper
I've been used pc part picker to try spec'ing the wattage on this pc but I'm a little sceptical of the result that it has given me as it has specified a total of 520 watts but gigabyte specify that the video card requires 600 watts minimum.
post edited by leroy94 - 2014/09/30 14:17:26
9 Replies Related Threads
    Re: Required power supply 2014/09/30 14:20:26 (permalink)
    750w.
    leroy94
    Re: Required power supply 2014/09/30 14:30:19 (permalink)
    Thanks buddy ill start looking into it now.
    • Ribbons : 115
    Re: Required power supply 2014/09/30 22:44:38 (permalink)
    I recommend minimum 850w.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    EVGATech_GabrielT
    EVGA Tech Support
    Re: Required power supply 2014/09/30 23:02:03 (permalink)
    I would also recommend at least a 850 Watt PSU for your build.
    Re: Required power supply 2014/09/30 23:18:05 (permalink)
    If you really want to know use this site: PSU Calculator
    Vlada011
    • Ribbons : 11
    Re: Required power supply 2014/10/01 03:41:23 (permalink)
    Yes 850W is enough even for OC 8350 and OC R9-290X.
    But people with Radeon cards often think on Crossfire when price of cards drop.
    Example R9-290X will cost 300$ very soon.  Than you will stuck with 850W.
    In that case best choice is your 1200 P2.
    With 850G2 you can use sleeve set and Eco Mode if need.
    750/850 G2 have that switch same as 1000/1200/1600 P2.
    http://www.evga.com
    http://www.intel.com
    http://www.nvidia.com
    https://watercool.de
    http://www.lian-li.com
    RainStryke
    The Advocate
    • Ribbons : 60
    Re: Required power supply 2014/10/04 15:10:28 (permalink)
    I'm running my set-up on a older generation HX750 without a problem. The OP would be just fine with 750w... 850w is only needed for crossfire.
    Main PC | Secondary PC
    Intel i9 10900K | Intel i7 9700K
    MSI MEG Z490 ACE | Gigabyte Aorus Z390 Master
    ASUS TUF RTX 3090 | NVIDIA RTX 2070 Super
    32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17
    SuperFlower Platinum SE 1200w | Seasonic X-1250
    Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GB
    Cougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5
    3DMark Results:Time Spy|Port Royal
    Ryujin Jakka
    Re: Required power supply 2014/10/05 03:18:05 (permalink)
    I recommend 850w firstly because there will a headroom for more and secondly psu wattage decreases with time
    RainStryke
    The Advocate
    • Ribbons : 60
    Re: Required power supply 2014/10/05 06:29:45 (permalink)
    PSU's don't lose wattage over time. The capacitors can degrade over time with heat from bad ripple suppression. If you get a quality power supply you shouldn't have to worry about that unless you are running 85%+ load most of the time. Most of the good manufacturers keep a 5 to 7 year warranty on their power supplies, so you should expect them to last at least that long.
