Replacement for northbridge fan on an old X58 SLI motherboard?
yorktronic
2016/10/15 16:19:10 (permalink)
Howdy,
The small Northbridge fan on my X58 motherboard basically sounds like an old prop plane at this point -- I've tried to tighten the screws, put a little padding in as I thought it was the housing vibrating, but I think the fan itself is just super loud. The board performs fine, and has for years, but if possible I'd like a replacement for the fan, if you guys even have any left! Otherwise, I've read that you can MacGuyver it with a 40mm fan and some zip ties... or something.
Thanks!
/ty
6 Replies Related Threads
    EVGATech_BrandonS
    EVGA Tech Support
    Re: Replacement for northbridge fan on an old X58 SLI motherboard? 2016/10/15 16:32:03 (permalink)
    I'm very sorry to hear about the fan on your motherboard. I'll be sending you an e-mail regarding this problem.
    • Ribbons : 57
    Re: Replacement for northbridge fan on an old X58 SLI motherboard? 2016/10/15 19:13:12 (permalink)
    EVGATech_BrandonS
    I've got the same problem on both E758 boards I have. I just removed the fan and housing and have a side panel fan blowing across the bare heatsink. So, I'd be interested if you have some sort of solution.
    12GB Corsair Dominator 2000C9
    ILikeBeans
    Re: Replacement for northbridge fan on an old X58 SLI motherboard? 2016/10/16 02:09:23 (permalink)
    My fan died I hacked an old 970i fan onto it.
    W7 64, EVGA X58 4-way SLI, I7 980x , EVGA GTX 780SC 2x, Corsair Dominator DDR3 2000 12GB, Samsung 840 Pro 256GB SSD, WD Velociraptor 1TB, HT Omega eClaro, Corsair AX1200W, Asus VG248QE-Glossy (thanks to CallsignVega @ Overclock.net) 3x Surround
    EVGATech_BrandonS
    EVGA Tech Support
    Re: Replacement for northbridge fan on an old X58 SLI motherboard? 2016/10/18 08:30:09 (permalink)
    I apologize for the delay HeavyHemi; I was out of the office for the weekend and was unable to submit this request. I'll send you an e-mail as well, and we should be able to replace the fans.
    IsmiteU
    Re: Replacement for northbridge fan on an old X58 SLI motherboard? 2016/11/07 10:10:44 (permalink)
    I just found this thread. My fan on my Northbridge is dead. Is there a replacement I can get?
    • Ribbons : 57
    Re: Replacement for northbridge fan on an old X58 SLI motherboard? 2016/11/07 17:14:30 (permalink)
    EVGATech_BrandonS
    Thank you very much Brandon. I received the fans and my NB temps dropped 10C under load.
