Problems using ELeet on Z170
Yagyu_Jubei
2016/10/13 09:21:18 (permalink)
Hi,
got a problem using the ELeet software on my Z170 Classified K MB. How do i get to change voltages? I usually apply the value i want to
change and push the "Apply Selection" button. But nothing happens. The voltage stays as it is. Only way to set a new value is through
reboot and enter BIOS. But this is really annoying if you´re trying to get you OC stable. Any ideas?
Any solutions are welcome.
2 Replies Related Threads
    • Ribbons : 122
    Re: Problems using ELeet on Z170 2016/10/13 12:02:51 (permalink)
    Which version are you using?
    Yagyu_Jubei
    Re: Problems using ELeet on Z170 2016/10/13 13:13:52 (permalink)
    I am using version 0.9.4 x64. BIOS is 1.04.
    post edited by Yagyu_Jubei - 2016/10/13 13:22:04
