Problems uploading my invoice - help needed!
moonrise
2011/02/01 13:24:16 (permalink)
Hi guys
I've registered my GTX 570 and am trying to upload a 750KB scan of the receipt...I can select the file but when I tell it to upload the page thinks for a bit then comes back with a blank browser window that just says "The system cannot find the file specified."
How can this be fixed?
Thanks.
5 Replies Related Threads
    MikeF2
    EVGA Product Specialist
    Re:Problems uploading my invoice - help needed! 2011/02/01 14:17:07 (permalink)
    Hello,
    What type of file is it? You can email me Mikef@evga.com with your invoice image and I can try it on my side.
    Mike
    ¤ Product Specialist ¤
    Mike Fierheller
    (D)714.528.4500x150
    mikef@evga.com
    PSU Home Page -www.evga.com/psu
    moonrise
    Re:Problems uploading my invoice - help needed! 2011/02/01 15:59:37 (permalink)
    Hi Mike
    Thanks for the reply, I've emailed you the invoice now, I hope you have better luck than me!
    Cheers.
    • Ribbons : 92
    Re:Problems uploading my invoice - help needed! 2011/02/01 20:36:53 (permalink)
                 The following link has a detailed method to upload your invoice.
                 http://www.evga.com/support/faq/afmviewfaq.aspx?faqid=58652
                * (There are three types of files you can upload: XPS, PDF, and JPG.)
    post edited by XrayMan - 2011/02/01 20:43:35
    My Affiliate Code: 8WEQVXMCJL
    Eclipse1991
    Re:Problems uploading my invoice - help needed! 2011/02/05 04:42:28 (permalink)
    I have the same problem as moonrise and I also want to load up an invoice for my GTX 570 . Can I also send you an email, MikeF ?
    • Ribbons : 92
    Re:Problems uploading my invoice - help needed! 2011/02/05 14:43:54 (permalink)
    Eclipse1991
    You don't really have to ask him. Just go ahead and email him with your problem. Give him a couple days to respond.
