Helpful ReplyProblem with EVGA 430W power supply after installation
RJ8812
2016/10/26 08:29:59 (permalink)
Hello,
I recently found out that I needed to replace the power supply to my Dell XPS 430. I bought the EVGA 430W as a replacement. Installation went quite smoothly, connected all the right cords, plugged in the power cord, flipped the switch and the fan started running. So I turned the computer on, it got to the desktop and started to load everything up, but then the computer shut off and I can't get it back on. The fan is not running any more. When I turn the power button to the power supply on the fan moves a little bit, but that's it.
Anyone know what the problem could be?
  • Ribbons : 68
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:16:40 (permalink)
Welcome to the Forms RJ8812
Did you REMOVE All of the Older Power Cables and Used ONLY the Cables that came with your New PSU?
Did you remember to connect the 4-Pin MB Connector?
You would use the 8-Pin CPU Cable that came with your New PSU, it will split into 2 4-Pin Connectors.
post edited by bcavnaugh - 2016/10/26 09:19:21
RJ8812
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:22:07 (permalink)
Thank you for the reply!
Yes. I removed the old PSU and all of the cables that were connected. The 4-Pin cable is connected to the MB
  • Ribbons : 68
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:23:33 (permalink)
Why did you feel that you needed to replace your Power Supply?
Did you Test the Power Supply Before you installed it?
Is the Power Supply Switch set to I or O?
post edited by bcavnaugh - 2016/10/26 09:26:26
bob16314
  • Ribbons : 203
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:28:44 (permalink)
Welcome to the forums..Since that PSU doesn't come with a PSU Tester adapter for the 24-pin ATX connector, what you should do is bench test the PSU itself by jumping the PS_ON to a COM terminal of the 24-pin ATX connector as described here by Corsair (scroll down to the 'PSU Paper Clip Test')..See if the unit turns on/the fan spins..If it does not, the unit is faulty.
* Cooler Master NV-334 * ASUS P8Z77-V LE PLUS * Intel i7-2600K @ 5.0GHz * Corsair H80 * Seasonic M12II 750W * 4x4GB 2133MHz Patriot Viper Xtreme * EVGA GTX 760 SC * 2 x WD 500GB Caviar Black RAID 0 * Toshiba DT01ACA 500GB * Dual-boot Win7 Home Premium 64-bit/Win10 Home 64-bit *
"If it ain't broke, fix it untill it is"
RJ8812
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:28:51 (permalink)
My computer wasn't turning on. The power light was blinking amber. I looked up to see what that meant, and from what I read, it means that the PSU was no longer functioning and needed to be replaced
  • Ribbons : 68
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:32:10 (permalink)
"blinking amber" Yep on the Dell it means new power supply.
bob16314  has your back now so follow his suggestions.
RJ8812
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:32:55 (permalink)
bob16314
Welcome to the forums..Since that PSU doesn't come with a PSU Tester adapter for the 24-pin ATX connector, what you should do is bench test the PSU itself by jumping the PS_ON to a COM terminal of the 24-pin ATX connector as described by Corsair (scroll down to the 'PSU Paper Clip Test')..See if the unit turns on/the fan spins..If it does not, the unit is faulty.
 ok great...I will try this and get back to you
RJ8812
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:48:04 (permalink)
bob16314
Ok I did the paper clip test and the PSU fan is not spinning. Does that mean my new PSU is faulty??
bob16314
  • Ribbons : 203
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:54:03 (permalink) ☄ Helpfulby RJ8812 2016/10/26 09:54:44
Yes..Contact the retailer you bought it from for a replacement or refund for the failed unit, or register the unit by clicking 'Member' on the EVGA home page, then 'My Products', then 'Register Product' and then contact EVGA about setting up an RMA or a refund.
See the stickies at the top of the EVGA Warranty Questions section of the forum for more details and helpful information, such as uploading your invoice.
RJ8812
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:55:08 (permalink)
bob16314
Yes..Contact the retailer you bought it from for a replacement or refund for the failed unit, or register the unit by clicking 'Member' on the EVGA home page, then 'My Products', then 'Register Product' and then about setting up an RMA or a refund.
See the stickies at the top of the section of the forum for more details and helpful information, such as uploading your invoice.
Thank you very much for all your help!
RJ8812
Re: Problem with EVGA 430W power supply after installation 2016/10/26 09:57:04 (permalink)
Was there something that I originally did or didn't do when I installed this before turning it on that caused this? As I had said, it turned on originally and then shut off once it got to the desktop...
bob16314
  • Ribbons : 203
Re: Problem with EVGA 430W power supply after installation 2016/10/26 10:04:30 (permalink) ☄ Helpfulby RJ8812 2016/10/26 10:05:33
You're welcome..Sounds like just a random failure or a basically DOA unit, nothing you did or didn't do..The paper clip test should definitely turn the thing on and the fan should spin.
Be advised that if you RMA through EVGA, don't send any cables/accessories, you keep them, just send the unit itself..That is all they require and if you send any cables/accessories, you may not get them back.
RJ8812
Re: Problem with EVGA 430W power supply after installation 2016/10/26 10:06:04 (permalink)
bob16314
All the cables are connected within the PSU
bob16314
  • Ribbons : 203
Re: Problem with EVGA 430W power supply after installation 2016/10/26 10:09:24 (permalink)
Yep they are..I'm talkin' about the wall power cable or anything else.
RJ8812
Re: Problem with EVGA 430W power supply after installation 2016/10/26 10:16:53 (permalink)
bob16314
right on. Thanks! Much appreciated
