Hi all !
I have a problem with EK WB 780 Ti waterblocks.
I got 3 of them for a 3-way SLI, and theses blocks came with screws and nylon washers. Most of them do *not* fit ! They are all M3x4 mm, but most of the standoffs installed on the waterblock are M2.5 threaded, particularly those around the GPU !!!
I made several mounting tests, and I could get a correct result reusing M2.5 x 4.5 mm screws from the stock cooler, plus 0.5 mm washers in order to compensate (stock screws are slighty too long, waterblock holes being blind threaded).
Did someone ran in such problem ?
I found workarounds, but this is absolutely not normal ! It sucks !
Am I the only one ?
Some pics :
M3 screws wont fit M2.5 threaded standoffs !
Workarounds :
Using stock M2.5x4.5mm screws in place of provided M3x4mm need 0.5 mm washers in order to correctly tighten them.
For GPU screws, I had to use 2 x 0.5 mm washers in order to get a correct spring load (by visualy comparing with a stock EVGA GTX 780 Ti). I used M3 washers.
[EDIT]
It is *very* important to use steel washers :
- 1 - not doing so, the stock M2.5 x 4.5 mm screws stop turning before the block is correctly tightened against the GPU, VRMs, etc. ; I detected this issue using a strong hallogen light : a thin space was visible between the VRMs pads and the block (sorry for my bad english)
- 2 - the nylon washers tend to yield because of the smaller screw heads : they are needed to spread the pressure
post edited by schmorblatz - 2014/06/07 17:47:53
