Power Supply 24pin fried? RMA?
leetoranges
2011/08/31 16:16:33 (permalink)
Ok so i'm pretty sure i have to RMA this but i wanted to get some second opinions on the issue at hand. I'm pretty sure that this is caused by the Power Supply and not the mobo itself.
Specs before getting to pictures.
i7 950 @stock
6gig corsair dominators 1600 3x2gb
gigabyte x58-ud3r
Corsair TX850 Power Supply
GTX 470 SLi Stock
17 Replies Related Threads
    RainStryke
    The Advocate
    • Ribbons : 60
    Re:Power Supply 24pin fried? RMA? 2011/08/31 16:37:19 (permalink)
    Main PC | Secondary PC
    Intel i9 10900K | Intel i7 9700K
    MSI MEG Z490 ACE | Gigabyte Aorus Z390 Master
    ASUS TUF RTX 3090 | NVIDIA RTX 2070 Super
    32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17
    SuperFlower Platinum SE 1200w | Seasonic X-1250
    Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GB
    Cougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5
    3DMark Results:Time Spy|Port Royal
    HotRodPolk
    • Ribbons : 8
    Re:Power Supply 24pin fried? RMA? 2011/08/31 16:38:07 (permalink)
    Ouch! You better replace the mobo as well. Where it's at suggests it's mobo related. If it were the supply, it'd be burned at the other end...
       Gigabyte Z590 Vision G Mobo, intel i3 10105 CPU, 32GB GSkill Ripjaws DDR4 3200 RAM, EVGA GTX 750ti FTW Video Card, EVGA SuperNOVA 850 G2 power supply, Fractal Design Focus G (White) case, Cooler Master Hyper212 RGB Black CPU cooler. 2 Dell LED Monitors (20" & 24"), SK Hynix Gold 1TB SATA SSD (OS Drive), 6 WD HDDs 13TB total (Storage).
    Rig is a partial update on the old Gigabyte P43/Q6600 OC rig... The WD HDD's, (13TB, total), Blu-ray & DVD burners,  GTX750ti FTW & Supernova 850 G2 psu, migrated from old setup... Will get an 11700K, and an RTX 3060 12GB Black card, when I'm ready to OC... Windows 11 Pro set for performance, and it runs at 4.2Ghz...
    Thrustmaster Ferrari GT Experience Wheel/Pedals,
    Built for Gaming, Video Production, and Cakewalk, Cubase DAWs...
    leetoranges
    Re:Power Supply 24pin fried? RMA? 2011/08/31 21:08:52 (permalink)
    HotRodPolk
    What do you mean it will be burned at the other end? The mobo end or the power supply end? Because to me both sides seemed burned. Could the problem be caused by overloading? I normally don't turn my computer off and i leave it folding at nighttime.
    HotRodPolk
    • Ribbons : 8
    Re:Power Supply 24pin fried? RMA? 2011/08/31 21:24:54 (permalink)
    Something Definitely shorted on mobo you gotta replace both. I didn't know it blackened both ends. New psu and mobo. with that much overload I wouldn't waste a new psu on that board you'll kill another one. you can try it with a low powered old one you have laying around maybe but you may kill other things... BTW- I meant burned inside the power supply itself,at that end of the wires...
    post edited by HotRodPolk - 2011/08/31 21:29:19
    leetoranges
    Re:Power Supply 24pin fried? RMA? 2011/08/31 21:44:46 (permalink)
    I forgot to post the picture for the 24pin topside view.
    So in your opinion do you think i can rma both the mobo and the psu? The psu i don't smell burned inside it, so i think it's fine, it's just the wire i think then that is melted or the sheilding around the wires is melted.
    HotRodPolk
    • Ribbons : 8
    Re:Power Supply 24pin fried? RMA? 2011/08/31 21:57:38 (permalink)
    RMA both definitely. Prob is, don't know what did it in the first place. Look your card over real good since it takes the most power to run.
    Sleinous
    • Ribbons : 32
    Re:Power Supply 24pin fried? RMA? 2011/09/01 01:19:56 (permalink)
    Are there any additional molex ports for additional power to your PCIe x16 lanes on that Gigabyte board? If so are you plugging molex leads into them? If folding for long periods of time on all PCIe x16 lanes (i.e. many GPUs on that motherboard) and there isn't enough power getting to the lanes that is probably why your 24 pin has melted on that pin as suggested above.
    If you find molex ports that you never plugged a molex lead into (typically located just above and to the left of your top most expansion lane) then plug a molex in there (can also be located underneath bottom most expansion lane).
    Either that or buy a power-boost from EVGA as previously mentioned.
    Good luck with the RMA(s)!!
    My Affiliate Code: GL1IAAFWJF
    BlackArtz5133937
    Re:Power Supply 24pin fried? RMA? 2011/09/01 06:49:06 (permalink)
    Why don't you just get one of the most recent evga classy3 boards. There is a cure for that problem you're having which is a molex power plug directly placed on the board.
    This is a classified board but not the classified 3 but they both have the molex connector directly on the board on top left corner in which this one is white on the classy3 is black.
    post edited by BlackArtz5133937 - 2011/09/01 07:09:17
    chrisdglong
    • Ribbons : 7
    Re:Power Supply 24pin fried? RMA? 2011/09/01 06:57:10 (permalink)
    Hey guys, is that PCIe add-on power adapter needed if you only have one 580 and a sound card in your PCIe slots? I am getting all paranoid after reading this thread now.
    BlackArtz5133937
    Re:Power Supply 24pin fried? RMA? 2011/09/01 07:15:22 (permalink)
    If your board doesn't have that molex connector on it, I would certainly get it.
    kaninja
    • Ribbons : 25
    Re:Power Supply 24pin fried? RMA? 2011/09/01 21:42:36 (permalink)
    chrisdglong
    I've never seen pins 10 and 11 melted on the 24-pin connector on a non-SLI'd system.  This only happens on multi-gpu systems.  It's not a fault of the power supply.  It's just the PCI-E subsystem drawing more power than the +12V connectors were designed to handle on the 24-pin connector.  Power Boost will solve this issue as will any mobo with supplemental power to the PCI-E subsystem.....either molex or 6-pin connector.  If you have a single card there is nothing to worry about.
    Corsair 650D   -  i5 3570K @ 4.6GHz  -  Corsair H80i  -  MSI Z77 M-Power  -  16GB DDR3 Corsair Dominator Platinum
    WD 1TB Caviar Black x2  -  OCZ 120GB Vertex2 SSD  -  Corsair HX620  -  GTX285 SSC  -  Samsung T240  -  DIR-655
    leetoranges
    Re:Power Supply 24pin fried? RMA? 2011/09/05 00:22:53 (permalink)
    I just sent my mobo and my psu back to their companies for the RMA. I hope they get accepted and i get the stuff back working :D
    big_willie
    Re:Power Supply 24pin fried? RMA? 2011/09/05 11:44:34 (permalink)
    And I bet it'll be years before motherboard manufactures actually decide to redesign the whole way a motherboard works so this won't happen again
    kaninja
    • Ribbons : 25
    Re:Power Supply 24pin fried? RMA? 2011/09/05 14:02:39 (permalink)
    big_willie
    Agree.  The ATX 24-pin connector is very outdated.  In an era of PC's using mostly +12V power it is ridiculous that the 24-pin connector only has two +12V connections.  Look at how many +5V and +3.3V there are!.....and one connection is not even used.  There needs to be a new standard/spec.  If anything they will do what they did with the 20-pin connector and just add-on in order to maintain legacy compatibility.....so maybe a 28-pin or 30-pin connector is in our future.
    Ouyeah
    Re:Power Supply 24pin fried? RMA? 2015/05/22 07:12:35 (permalink)
    i know this post is kind of old, but i didnt find the recent one, the one where are more details about 24 pins burned, i had this problem also, well not really burned but almost did burn it, the problem is the power supply, i had a ms-tech 750w val, on a q6600 clocked to 3.2, evga gtx 460 stock clock 720 small overclock to 800 core and 2000 memory... so the 24 pin was getting pretty hot i didnt know why... but i seen problems like freezes, low voltage and blue screens, so i changed the psu to a fortron hyper 700w, now same settings overclocked, and the 24 pin is ice cold np now... so in other words for me was the powersupply the problem on 24 pin getting hot...
     it seems the problem comes when your components suck too much power and the psu cannot give enough...
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 79
    Re:Power Supply 24pin fried? RMA? 2015/05/22 07:45:11 (permalink)
    You just revived an almost 4 year old thread... How did you find it, lol.
    I have always found that when attempting to draw too much power across a single wire, the wire will melt. Probably the same theory here, and why many manufacturers have started adding provisions to spread the electrical load to different sections of the board by adding molex or 6pin PCI connectors to the base of the motherboard to power the PCI lanes. It is strange that only 1 card would ever cause the issue, and that it would happen on the motherboard side, but I guess that is what would happen if it wasn't built to a proper quality at the manufacturer maybe?
    Ouyeah
    Re:Power Supply 24pin fried? RMA? 2015/05/22 08:10:12 (permalink)
    hmm i think there is another problem... not that it draws to much power... i think it happens when the power supply cannot deliver enough for all components but then again after i put the new power supply no cable got hot... and with old one the 6 pins or the 8 pin for cpu did not get hot instead 24 pin was... and yep you are right like the quality is not good... for example the old one says 750w but i doubt it it was delivering 750w... not even 500 i dont think it could... and my motherboard dont have a molex connector on it... now like i sayd its ice cold with a good quality psu... and i dont think it helps much if every 12v connector have different lanes... it could cause instability in my opinion...
