alexciobanu
- Ribbons : 21
Hi guys, Been a while since I've been active on the forums :) I've been super busy with a new job, move to a different city and pretty much a whole new life! Glad to say that I'm back and with a very exciting project! As the banner suggests it will be based on the Dead Space games and it's my entry for this year's Cooler Master Case Mod World Series as well as the ANZ Edition of the "World Series". I am going all out with for this project and trying some modding techniques I haven't done before so stay tuned and enjoy the build log! I'm gonna give a little hint and say that this will NOT be a clean build :) SPECS Case - Cooler Master MasterCase 5 Maker Motherboard - ASUS Maximus VIII Extreme Assembly CPU - Intel i7 6700K Memory - 4 x 4GB Avexir ROG Certified Red Tesla 2400Mhz DDR4 GPU - 2 x ASUS STRIX GTX 980 SSD - 2 x Kingston HyperX Fury 240GB SSDs PSU - Cooler Master V1000 Cables - CableMod Fully Custom Individually Sleeved Cables + MercoMods Custom Braided Extensions LEDs - CableMod Magnetic RGB LED Strip Radiators - Bitspower Leviathan Slim 240 Radiator, Bitspower Leviathan Xtreme 360 Radiator Fans - CoolerMaster JetFlo 120mm Red and White LED fans Pump - Laing D5 with Black Bitspower MOD Package - Pump Top + Casing Reservoir - Bitspower D5 Top Upgrade Kit 150 with Cascade Tube Effect Fittings - PrimoChill Revolver SX Matte Black + Various Bitspower Carbon Black angle fittings and extensions Tubing - PrimoChill Copper Tubing CPU Block - Bitspower Summit EF GPU Block - 2 x Bitspower VG-NGTX980ADIIS For now I'll start with the packages received from Cooler Master A mysterious box (though the thread title might hint at what's inside) JetFlo fans and a V1000 power supply Stay tuned for more guys! Cheers, Alex
post edited by alexciobanu - 2016/06/06 02:38:48
alexciobanu
- Ribbons : 21
Re: PROJECT ISOLATION (modded Cooler Master MaserCase 5 Maker)
2016/05/01 06:26:11
alexciobanu
- Ribbons : 21
alexciobanu
- Ribbons : 21
2016/05/05 04:40:52
alexciobanu
- Ribbons : 21
2016/05/08 07:30:18
Hi guys, I've got an exciting update for you today :D Since this is a Dead Space theme I'm looking at a different painting technique for the entire case! So I'm testing out this rust paint to see if it's the effect I'd like to go for in this build as well as learning how to apply it. Luckily I have quite a few spare case panels laying around. The idea with this is that it can be applied to anything, even plastic and rust that too. It's a metal based paint which you apply with a brush and leave it to dry for about 1 hour. Once dry you apply the oxidising patina which is a form of activator that speeds up the rusting process. Leave it for a few good hours and you should have a nice, real rust effect. So tonight I've applied it to a spare case panel. I did a few different areas where I applied it on straight as well as in a random pattern to see if it gives a different effect or if it even matters how you apply it. I've then applied the activator and leaving it overnight. I've also applied the activator to a part of the panel with no metal base paint as technically this should rust metal by itself too, however it might not go through the powder coating on the panel. This is the stuff and how it looks after about 30 min since the activator was applied. I'll show you guys the effect tomorrow once it fully dries. This is the rust base applied. This is once dried. And this is the Oxidising Patina applied. Applied some more as the more you have on and the longer it stays wet for, the more intense the effect will be. You can already see it starting to rust here. This is after about 30 mins with the activator applied. We'll see the full effect tomorrow once it dries. Hope you guys have enjoyed this update! I'm definitely really excited for this entire project! Thanks for checking it out. Cheers, Alex
post edited by alexciobanu - 2016/05/22 07:08:36
alexciobanu
- Ribbons : 21
2016/05/09 00:31:15
Hi guys, So here is the effect after about 24 hours once fully dried! I gotta say I wasn't expecting this but it's the perfect effect I wanted for this build :D It seems like applying in a straight even motion looks a bit better than the random pattern I did in the corner of the panel. Also the oxidising patina by itself didn't do much to the poweder-coating. I wonder how it would affect bare metal :) Anyways, here are the result. Next up will be applying it to the case! Thanks for checking it out! Cheers, Alex
post edited by alexciobanu - 2016/05/22 07:08:50
- Ribbons : 84
2016/05/09 03:57:42
alexciobanu
- Ribbons : 21
2016/05/10 00:23:41
rjohnson11 Very nice Alex
Thanks a lot Robert :D
V84x4
- Ribbons : 7
2016/05/10 05:00:29
Very Cool..........Subscribed Regards Rick
Computer Specs:Lilan Li 011D Bitspower DISTRO, MSI 570 Carbon Pro MB, AMD 3900X @ 3.8ghz, Bitspower Water Loop, TRIDENT Z 64GB (4x16GB) DDR4 3200, evga 2080 Super, EK waterblock 980 PRO M.2 1TB ,evga 1000w G3 psu, LG GSYNC 4KK Curved 32 inch, Windows 10 64bit
alexciobanu
- Ribbons : 21
2016/05/11 04:35:47
V84x4 Very Cool..........Subscribed Regards Rick
Thanks a lot :D
alexciobanu
- Ribbons : 21
2016/05/12 03:00:20
- Ribbons : 84
2016/05/12 05:08:02
alexciobanu
- Ribbons : 21
2016/05/14 07:12:36
rjohnson11 Interesting effect
Cheers Robert :D
alexciobanu
- Ribbons : 21
2016/05/14 07:22:08
Tech_RayH
- Ribbons : 7
2016/05/14 09:13:14
That rust effect that you achieved is pretty amazing, looks like it spent years under water or in a jungle. It will be exciting to see the final result.
...an untrammeled flow of words in an open forum. - Adlai E. Stevenson
- Ribbons : 84
2016/05/15 00:38:30
EVGATech_RayH That rust effect that you achieved is pretty amazing, looks like it spent years under water or in a jungle. It will be exciting to see the final result.
+1. Just the right effect.
alexciobanu
- Ribbons : 21
alexciobanu
- Ribbons : 21
2016/05/18 07:01:13
coderz
2016/05/25 15:46:46
Cant wait to see what it will look like all put together
alexciobanu
- Ribbons : 21
2016/05/26 02:23:06
coderz Cant wait to see what it will look like all put together
Hehe cheers :D
alexciobanu
- Ribbons : 21
2016/05/26 02:37:17
alexciobanu
- Ribbons : 21
2016/05/27 08:45:38
alexciobanu
- Ribbons : 21
2016/05/28 09:00:03
alexciobanu
- Ribbons : 21
2016/06/06 03:11:18
Hi guys, Sorry for the lack of updates on this build. I've been quite sick over the last week and haven't had a chance to post more updates. The race is now on to finish this build by the 12th of June. That's Sunday this week as that's when the Cooler Master CaseMod World Series ends. Here is the work I've done for the top and front panel. If you haven't guessed it by now the front panel will have Isaac Clarke's helmet from the original Dead Space game mounted to it. It should look pretty nice if done right! Let's have a look at the progress! First up the helmet pieces. Started of with a piece of 2mm black acrylic. Measured and drew out the shape by hand. If you can't see it yet, you will be the end of this update. Next up were pieces for the top panel to work around the tube. Just designed a random pattern from scratch that I thought would look good and everything was cut by hand with my Dremel Moto-Saw. Helmet pieces all cut too I went ahead and bent the acrylic pieces to shape and mounted with other straight pieces to form the overall helmet design. The way I bent them was with a sheet of thin aluminium that was used to measure the shape of the front panel and then taped up to hold that particular shape. Once done, the acrylic pieces for the helmet were placed in the middle individually and heated up until they took the shape of the aluminium sheet. Unfortunately I was too into it at the time and forgot to take pics. You can see it coming together. More work on the top panel. Mounting the pieces together. And here they are both on the case. More pics from the next day. And lets not forget the finishing touches on the helmet Let me know what you guys think! These will also be rusted which you will see once done. Sorry if the quality of these images wasn't too good. They were all from my phone. Cheers, Alex
alexciobanu
- Ribbons : 21
2016/06/07 04:49:09
Bit more progress! Starting to get hardware in the case! Also yesterday I forgot to mention that the full specs have been updated in the first post! Here they are: Case - Cooler Master MasterCase 5 Maker Motherboard - ASUS Maximus VIII Extreme Assembly CPU - Intel i7 6700K Memory - 4 x 4GB Avexir ROG Certified Red Tesla 2400Mhz DDR4 GPU - 2 x ASUS STRIX GTX 980 SSD - 2 x Kingston HyperX Fury 240GB SSDs PSU - Cooler Master V1000 Cables - CableMod Fully Custom Individually Sleeved Cables + MercoMods Custom Braided Extensions LEDs - CableMod Magnetic RGB LED Strip Radiators - Bitspower Leviathan Slim 240 Radiator, Bitspower Leviathan Xtreme 360 Radiator Fans - CoolerMaster JetFlo 120mm Red and White LED fans Pump - Laing D5 with Black Bitspower MOD Package - Pump Top + Casing Reservoir - Bitspower D5 Top Upgrade Kit 150 with Cascade Tube Effect Fittings - PrimoChill Revolver SX Matte Black + Various Bitspower Carbon Black angle fittings and extensions Tubing - PrimoChill Copper Tubing CPU Block - Bitspower Summit EF GPU Block - 2 x Bitspower VG-NGTX980ADIIS Thanks for checking it out! Cheers, Alex
alexciobanu
- Ribbons : 21
2016/06/08 06:54:23
alexciobanu
- Ribbons : 21
2016/06/09 03:44:21
alexciobanu
- Ribbons : 21
2016/06/10 08:04:23
- Ribbons : 84
2016/06/11 02:25:06
Looks great. I assume finished pics are coming soon?
alexciobanu
- Ribbons : 21
2016/06/11 09:11:32
rjohnson11 Looks great. I assume finished pics are coming soon?
Yup, coming shortly! Thanks, glad you like it :D
