IchigoSoulReaper
I went to have dinner and I left my PC on. When I came back, my computer was off and I couldn't turn it back on. The next day I bought a new PSU and the computer worked...UNTIL I put my GTX 1080 FTW back in. When the 1080 is in, the LEDs flash for a second and then the computer won't turn on. I tested my old PSU and it still works. I tried the 1080 in both slots and I even switched between master and slave mode. Nothing. I've had a 1080 FTW since release with no issues until now. So can anybody please help? Do you know anything about this?
post edited by IchigoSoulReaper - 2016/11/05 21:08:43
CPU: i7-4790K GPU: EVGA GTX 1080 FTWMOBO: MSI Z97 GAMING 5RAM: 16GB Avexir Core (red)PSU: EVGA SuperNOVA 1050 GSStorage: 500GB Samsung 850 EVO, 256GB Samsung 840 Pro & 1.5TB SeagateCase: NZXT H440 (black/red) & NZXT HUE+ lightingCooler: NZXT Kraken x41 + Noctua PPC-3000 Mouse & Keyboard: Razer Mamba Chroma & Razer Deathstalker ChromaTV: Sony 55" X810C 4K (60Hz) 1080p (120Hz) with Sony 5.1 ch 1,000W
Re: PC won't power on when 1080 FTW is plugged in
2016/11/05 10:58:11
Try the 970 in your rig, and I would also have your friend try the 1080 in his - if he's willing. Then you would know for sure if its the card or not.
i7 6700K, Corsair H80iGT, 16GB Corsair Vengeance DDR4 @3000MHz, EVGA GTX1080 FTW, MSI Z170A Gaming M7, Samsung 950 Pro 512GB, Samsung 840 EVO 250GB, WD 1TB, Creative SB Zx, Dell P2715Q 4K/UHD @60Hz, Samsung B2230HD 1080p @60Hz, Windows 10 Pro, Corsair Air 540, Seasonic 860watt XP2, Corsair K70 RGB, Razer Deathadder Chroma
IchigoSoulReaper
2016/11/05 21:06:22
hapkiman Try the 970 in your rig, and I would also have your friend try the 1080 in his - if he's willing. Then you would know for sure if its the card or not.
Yup I just did and my computer works with his 970 but his computer won't with my 1080. When the 1080 is in, the LEDs flash once and then the computer won't turn on. It's like it activates a surge protector or something. So it's definitely my GPU. Any solutions or do I need to send it back to EVGA?
2016/11/05 21:09:33
how many watts is the PSU? edit: nvm i saw it on your sig
2016/11/05 21:11:07
gahelm
2016/11/05 21:17:02
Sounds like one or more of the VRM's has shorted out causing your power supply to shutdown (ie. crowbar) due to high current. Most power supplies these days have over-current protection, you should NOT install the card in any other machines, RMA it back to EVGA. ** Edit ** Crowbar circuits are for over voltage protection and usually included in most power supplies as well. In both cases you usually have to remove the AC mains either by shutting off a physical switch or disconnecting the power cord in order to reset the circuit.
post edited by gahelm - 2016/11/05 21:27:37
2016/11/05 21:17:08
- Ribbons : 57
2016/11/05 21:20:12
IchigoSoulReaper
Time for an RMA. You tested it in a different computer and had the same error. Your system functions with a known good GPU. Just cite this thread when you request an RMA. Personally, If you can, I'd do it by phone. It's quicker and they are there 24/7. - Toll Free: +1.888.881.EVGA (3842)
- Tel: +1.714.528.4500
- Fax: +1.714.528.4501
- Email us
Support Hours - 24 Hour / 7 Day Phone and Email Support
post edited by HeavyHemi - 2016/11/05 21:22:40
EVGA E758/i7 980x 4.3ghz 1.36v 12GB Corsair Dominator 2000C9 GTX 980Ti w/GTX TITAN SC for PhysX Crucial M4 512GB SSD/2x WD RE4 Black 2TB Corsair H50 Cooler/Corsair AX1200/Window 10 Pro
IchigoSoulReaper
2016/11/06 00:00:10
nautics889 Bios up to date? :/
Yeah man gahelm Sounds like one or more of the VRM's has shorted out causing your power supply to shutdown (ie. crowbar) due to high current. Most power supplies these days have over-current protection, you should NOT install the card in any other machines, RMA it back to EVGA. ** Edit ** Crowbar circuits are for over voltage protection and usually included in most power supplies as well. In both cases you usually have to remove the AC mains either by shutting off a physical switch or disconnecting the power cord in order to reset the circuit.
That's exactly what's happening. Thanks for the explanation. You guys are probably right...time for the RMA. I'll post back here to update people in case they're curious to see how EVGA handles the situation. EDIT: Update - http://forums.evga.com/Ne...formance-m2584626.aspx
post edited by IchigoSoulReaper - 2016/11/18 13:45:07
