Hey, I'm running the list in my sig, no changes. So I'm gaming and whatnot, and all of a sudden, when I alt tab or load up a video on the net (basically switching between a 2D and 3D application) my primary GTX295 red lights, video cuts out and I'm forced to reboot. If I try a soft reset, I can't make it into Windows without the same problem happening. I'm running W7 Pro and Forceware 197.45 If I do a hard shutdown and restart, the system's fine for a length of time until it happens again, usually when I'm alt tabbing out of a game. I have a hunch it's my AX1200, because when I disable the second GTX295 by disabling the PCIe slot it's plugged into, the primary card runs like a champ for hours. No hiccups. I've even tried the secondary card alone by disabling the primary, same deal. Smooth. However when I enable both cards I run into the red light on the primary card and the video cuts. The red light usually means a power issue, but I'm not entirely sure. I've swapped out the cables, the AX1200 is maybe 3 months old? I'm convinced it's the PSU but I'd like a second opinion. Thanks in advance.
"Sang Noir" -Silverstone TJ07-BW -Intel Core i7 920 @4.209GHz 1.343VCore + EK Supreme HF Rev2 Acetal Copper -OCZ XTC Platinum 6GB DDR3-1600 [7-7-7-20] -Asus Republic of Gamers Rampage III Extreme -EVGA GTX 560Ti 448 Classified [900/1800/2100] + EK-FC480 Copper Waterblock -2x Corsair Force GT 120GB SSD + 1x WD 1TB Black -Corsair AX1200 PSU + Laing D5 (EK D5 XTop Rev2) + Feser Quad XChanger -Razer Mamba + Razer Blackwidow + Sennheiser PC 320 -46" Samsung LED TV 1920x1080p Pics in Mod Rigs!
Re:Odd Problem with my GTX295s
2011/05/11 19:02:03
Sounds like it's the PSU. Try different cables for 295 #1. I have a cable on my PSU that I can't use because my card redlights if I use it.
Desktop: i7 3820 - ASUS X79 Sabertooth TUF - 4x4GB G.Skill TridentX 2400C9 - EVGA GTX 580 Classified ULTRA Hydro Copper Microsoft Surface Pro 4: i7 6650U - 16GB RAM - 256GB SSD - Sennheiser HD 598 - DualShock 4 Controller
RainStryke
- Ribbons : 40
2011/05/11 21:44:11
Have you checked your 12v rail? I'd assume your temps are great, but have you been watching them? Have you tried reducing your CPU to stock or a lower OC?
Intel i7 4790K - Corsair H90 - MSI Z87 MPOWER MAX AC - MSI GTX 980 (81.7% ASIC) - 16GB G.Skill 2400MHz - Seasonic X-1250 - Crucial MX100 512GB - Corsair Carbide 500R EVGA Affiliate Code: S27QNQME0X
2011/05/11 21:47:31
Tried different power cables. OC (CPU) with 2 cards is a no go. OC with either card is flawless. 12V Rail holds steady according to everest, temps on everything are excellent. 3.3V rail shows 2.93 @ idle but without a multimeter it's nothing really legit IMO.
2011/05/11 21:59:50
Huh... Strange. It definitely sounds like a PSU issue but I would reset the BIOS, sweep drivers, reinstall drivers, and test from there.
rottenmutt
2011/05/12 01:07:51
EVGA X58 Classified|i7-920 @ 4.2GHz on H20|Tri SLI GTX 680|CORSAIR 6GB DDR3 CM3X2G1600C8D|SB Xfi|ThoughPower 1200W EVGA X58 Classified|i7-975 @ 4.2GHz on H20|2x GTX 275|CORSAIR 6GB DDR3 CM3X2G1600C8D EVGA X58 Rev 1.0|i7-930 @ 4.00GHz|GTX 580, GTX 470|6GB Kingston PC3-10600 Skulltrail|2x E5450 @ 3.6GHz on H2O|2X GTX 480|SB Xfi|ThoughPower 1200W Skulltrail|2x E5430 @ 3.2GHz on H2O|GTX 580 3GB|SB Xfi|ThoughPower 1200W H8DCE|2x Opteron 270|4GB|2X GTX 565ti KFN32D-SAS|2x Opteron 2354|GTX 480, GTX 470
RainStryke
- Ribbons : 40
2011/05/12 04:59:25
Sounds like your going to put that 7 year warranty to use.
2011/05/12 06:32:42
I've used 2 BIOS', 5 sets of drivers and reinstallation of some of my games. No luck... Before I contact corsair I'm going to try powering the GPU's off a spare HX1000. Thank guys, it's always great to have a second look. Has anyone ever tried calling corsair? Their tech support form is the same form you use to start an RMA, really weird.
2011/05/12 09:31:59
Yeah my assumption is PSU at this point. Never called them but RMAs are smooth.
2011/05/12 10:01:17
Ok, now I'm stumped. I just tried running the GPU's off my spare HX1000 and I get the same problem. I'm typing this off my primary card, I've disable the second 295. I haven't taken my cards apart since I installed the waterblocks on them, and I highly doubt something like the internal SLI ribbon cable has become loose. What else could the red light mean? It only comes on the primary card, when I run it or the secondary card alone they both work like champs. When I try them together I can't even boot. Confused!
2011/05/12 10:08:30
Try a different SLI bridge between the cards.
RainStryke
- Ribbons : 40
2011/05/12 18:06:35
Everywhere I have read about that red light they say it means either the card is not getting enough power or the card is overheating. If you have tried another PSU (That is certified and is known to be able to power Quad SLI GTX 295's) and it's also giving you the same problem. I would be looking towards a RMA on that video card. Have you tried running each card by it self and try a few stress test on each?
2011/05/12 20:32:17
If you RMA the cards you are screwed though.
RainStryke
- Ribbons : 40
2011/05/12 21:05:50
Halo_003 If you RMA the cards you are screwed though. I was thinking it wouldn't be that bad for a second, but since he paid for those really nice aftermarket waterblocks i'd have to agree. Unless they replace them with GTX 480 hydro's.
2011/05/12 21:19:15
RainStryke Halo_003 If you RMA the cards you are screwed though. I was thinking it wouldn't be that bad for a second, but since he paid for those really nice aftermarket waterblocks i'd have to agree. Unless they replace them with GTX 480 hydro's. That's doubtful though since they weren't Hydro 295s. I'm not sure.. Perhaps they would replace them with 480s and then he could sell the blocks. That would really suck though..
2011/05/12 21:28:08
Yeah I'd rather not RMA these, and thanks for all your help. I've tried a triple SLI bridge, and I can boot with all 4 GPU's, but I can't enable quad SLI. I'll be sweeping the drivers again in the morning, I'll keep you guys posted. Thanks!
2011/05/12 21:33:13
yellow__fever Yeah I'd rather not RMA these, and thanks for all your help. I've tried a triple SLI bridge, and I can boot with all 4 GPU's, but I can't enable quad SLI. I'll be sweeping the drivers again in the morning, I'll keep you guys posted. Thanks! That's strange. Makes me wonder if it is the SLI bridge... I can send you a flexible SLI bridge if you want.
RainStryke
- Ribbons : 40
2011/05/12 21:47:55
Really sounds like the card. Just wanted to say... Since he has the GTX 295+ model with more memory I went and checked out benchmarks. Seems that if they were to give him a card of equal or greater value a GTX 480 would be close, but he would actually lose a bit of performance on games @ 2560x1600 resolution. So i'd say a SSC or Hydro version would be right in the same performance range.
2011/05/12 22:37:51
IMO, we paid for $530 cards. We should get $530 cards back. In other words. A 580 is fair. They say it's of equal or greater value, not performance. Again, just my opinion.
RainStryke
- Ribbons : 40
2011/05/13 01:22:41
Halo_003 IMO, we paid for $530 cards. We should get $530 cards back. In other words. A 580 is fair. They say it's of equal or greater value, not performance. Again, just my opinion. That would be nice, but it is in fact performance and not value. EVGA Warranty Replacement and Refund: - Products sent in for RMA will be repaired or replaced with a product of equal or greater performance if an exact replacement is not available.
- EVGA requires an invoice or receipt as proof of purchase to take advantage of any warranty related services necessary.
- The EVGA warranty is non-transferable. Products purchased second hand, from a non-authorized seller, or from an auction site do not carry any warranty.
- EVGA only offers refunds on products purchased directly from EVGA.com within 30 days of purchase. For products not purchased at EVGA.com, all refund claims would need to be processed through the vendor that sold the product congruent to their return policy.
- All products returned from EVGA's RMA department are thoroughly tested recertified products. If an RMA is necessary within 30 days of the original purchase date, a new in box replacement will be sent in return.
- Replacements under EVGA's RMA Service will always follow the original product's warranty based on the original purchase date.
Source: http://www.evga.com/support/warranty/
2011/05/13 06:56:44
Thanks for all the support guys, really appreciate it! To clear up your statement, Rain, the GTX295+'s don't get more memory, just higher stock clocks. 576/1242/999 for the standard GTX295, 596/1296/1026 for the Plus editions. I'm also using the SLI bridge I've been using since the start, so I'll see whether or not it holds up. Thanks for the generous offer Halo, if I need one I'm glad to know there's someone to help me. As far as an RMA is concerned these GTX295+'s are pretty near and dear to me, if I got a 480 back it wouldn't match my other GTX295+, and then I'd have to go through the hassle of aquiring new blocks. I'll keep working on it, thanks again! EDIT: Turns out the triple SLI bridge is what held me back from enabling quad SLI. I'm using the normal bridge right now and hoping it works.
2011/05/13 09:30:30
yellow__fever Thanks for all the support guys, really appreciate it! To clear up your statement, Rain, the GTX295+'s don't get more memory, just higher stock clocks. 576/1242/999 for the standard GTX295, 596/1296/1026 for the Plus editions. I'm also using the SLI bridge I've been using since the start, so I'll see whether or not it holds up. Thanks for the generous offer Halo, if I need one I'm glad to know there's someone to help me. As far as an RMA is concerned these GTX295+'s are pretty near and dear to me, if I got a 480 back it wouldn't match my other GTX295+, and then I'd have to go through the hassle of aquiring new blocks. I'll keep working on it, thanks again! EDIT: Turns out the triple SLI bridge is what held me back from enabling quad SLI. I'm using the normal bridge right now and hoping it works. Good to know, keep us updated. RainStryke
Halo_003
Ah I gotcha, I was just going off of where you said value in your post.  Thanks for clearing that up for me, I always thought it was off value and not performance.
2011/05/13 10:50:46
Well I burned through 2 hours of SC2 without a problem...confused as ever but glad the rig works.
2011/05/13 10:58:27
Ha I know exactly the feeling. I was thinking my card was dying the other day, turns out it was fine. No idea why it was artifacting though. It went away with a reboot.
RainStryke
- Ribbons : 40
2011/05/13 12:13:06
Awesome, all that due to a bad SLI bridge. I'll keep that in mind for future reference. Good thing you didn't have to go through an RMA processes. lol
2011/05/13 16:03:33
RainStryke
I'm glad I mentioned that lol.
