Hot!Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) Now Login Issues
  • Ribbons : 68
2016/06/24 20:28:06 (permalink)
Seems we are have some issue on the Forum like missing post in threads.
While you can view post in some thread some you cannot unless you have a link or go to "My Posts" then "View More"
Like here:
http://forums.evga.com/Prime-Grids-4th-Challenge-of-2016-Summer-Solstice-Challenge-5-days-CPU-only-June-2025th-m2496764.aspx
This Post is not show unless you click on this link.
http://forums.evga.com/Prime-Grids-4th-Challenge-of-2016-Summer-Solstice-Challenge-5-days-CPU-only-June-2025th-m2500468.aspx#2502711
Also Paging is missing on some Threads as well.
post edited by bcavnaugh - 2016/06/26 07:58:39
56 Replies Related Threads
    • Ribbons : 92
    Re: Odd Issues on the Forum 2016/06/24 21:50:23 (permalink)
    I don't see any of those mentioned problems. Anyone else have the same problems as BCav?
    My Affiliate Code: 8WEQVXMCJL
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum 2016/06/25 05:13:37 (permalink)
    I am having problems loggin in using Firefox at times. I clear cookies, restart FF 47.0 and still can't login. I get right in using IE11 but can't logout. My iPhone is logged in but it's hard to make a post from there. Some notifications not arriving either.
     Heatware
    bdary
    • Ribbons : 55
    Re: Odd Issues on the Forum 2016/06/25 06:45:23 (permalink)
    Past 2 days I've had intermittent problems logging in using Waterfox/FF.  Just a few minutes ago I tried several times to log in and couldn't.  Now I just logged in as normal.
    EVGA X99 Classy ~ EVGA 1080 FTW ~ EVGA 970 SSC for PhysX
    i7-5930K @ 4.40GHz ~ Corsair H100i ~ 16GB G.Skill RipJaws 4 @ 2400MHz
    Samsung 840 Pro w/ W7 HP & W10 Pro 64bit (Dual Boot) ~ Samsung 840 256GB
    EVGA 1300W G2 ~ CM HafX ~ ASUS ROG Swift 144Hz Gsync ~ Acer 27" 120Hz 3D
    Firestrike >> http://www.3dmark.com/fs/9823006
    TimeSpy >> http://www.3dmark.com/spy/297131
    EVGA Affiliate Code - M1D1QH1FTU
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 06:47:34 (permalink)
    I did have logging in problems last night as well, then about an hours later I could long on and then I stated to see issues.
    I remember that this Thread has as lest 4 pages and now I only see 1 and none of my posts or even robbysites Posts.
    But from this link: http://forums.evga.com/Prime-Grids-4th-Challenge-of-2016-Summer-Solstice-Challenge-5-days-CPU-only-June-2025th-m2500468.aspx#2502711
    I can see mine and robbysites Posts but still only shows 1 Page for this Thread.
    I will install Waterfox and re-test.
    post edited by bcavnaugh - 2016/06/25 09:48:52
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 07:55:30 (permalink)
    • Ribbons : 52
    Re: Odd Issues on the Forum 2016/06/25 08:08:34 (permalink)
    As of this time I can find no errors using Waterfox nor Google Chrome on any of the posts above but I will try again later.
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 08:11:34 (permalink)
    So my links above are ok to you?
    It is like their are two different 2500468 Posts.
    But thanks for looking.
    I am now install Firefox. It is even stranger on Firefox. Checking other areas now.
    post edited by bcavnaugh - 2016/06/25 09:48:33
    Dukman
    Re: Odd Issues on the Forum 2016/06/25 08:21:33 (permalink)
    FWIW, Im using Google and I can see all the posts you linked.  I can also go into the section, click on the thread and see the posts as well.
    Heatware
    B Movie: A work in progress.
    EVGA Z87 Classified, i7 4790k @ 4,4 Ghz, 2xEVGA 980Ti Classified, 32GB 2133Mhz Corsair Dominator RAM, Creative SB ZX soundcard, 2xSamsung 250GB SSD, 2xWD 1TB Velociraptor HDD, EVGA 1300w GS PSU. Corsair C70
    I need cheaper hobbies.
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum 2016/06/25 08:27:49 (permalink)
    I can see all posts from you and Robby but couldn't see them earlier. I'm never really sure if what I am seeing is real or I am losing my mind from old age so I didn't say anything.
     Heatware
    • Ribbons : 68
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 08:43:20 (permalink)
    Zuhl3156
    Nope this is not our age or eyes, our old eyes are fine It is all bill1024's Fault.
    May need to join the two Threads together
    post edited by bcavnaugh - 2016/06/25 09:48:23
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum 2016/06/25 08:48:52 (permalink)
    I thought there were two threads with identical titles but couldn't find the second one. Must be in another subforum. He should know better than doing that us old timers. That's just plain mean and nasty to be honest.
     Heatware
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 09:20:58 (permalink)
    Zuhl3156
    You will only find ONE Thread Listed Under http://forums.evga.com/FoldingEVGA-f28.aspx or Crunching@EVGA
    I do believe this is a new Bug from this weeks updates on the EVGA Websites.
    post edited by bcavnaugh - 2016/06/25 09:48:14
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 09:22:31 (permalink)
    I think I found it?
       Re: Prime Grids 4th Challenge of 2016. Summer Solstice Challenge 5 days CPU only June 20-2                                 bcavnaugh                                   1 hour ago                       in Crunching@EVGA
       Re: Prime Grids 4th Challenge of 2016. Summer Solstice Challenge 5 days CPU only June 20-2                                 bcavnaugh                                   1 hour ago                       in Folding@EVGA
    So the question is did bill1024's create Two Posts?
    post edited by bcavnaugh - 2016/06/25 09:48:05
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 09:30:44 (permalink)
    This is also a Thread with the same title name but in two locations.
     This is what most users will see
    1080 Stock/OC vs 1070 Stock/OC vs Titan X Stock vs 980 Ti Stock/OC vs 980 Stock/OC vs 970
    This is what you will see within the Address Line.
    http://forums.evga.com/1080-StockOC-vs-1070-StockOC-vs-Titan-X-Stock-vs-980-Ti-StockOC-vs-980-StockOC-vs-970-m2500245.aspx
    http://forums.evga.com/1080-StockOC-vs-1070-StockOC-vs-Titan-X-Stock-vs-980-Ti-StockOC-vs-980-StockOC-vs-970-m2500244.aspx
     The OP said it is because users only go the their area in the forums.
    One for 10 series owners.
    One for 900 series owners thinking about upgrading! (not everyone goes to a forum for a card they don't own)
    I posted that I go here http://forums.evga.com/RecentPosts as my default location for the Forum and that is why it was confusing for me.
    post edited by bcavnaugh - 2016/06/25 09:49:41
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 09:50:46 (permalink)
    I think I found it?
    Aha! So I was right! Surprise surprise. LOL
     Heatware
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 09:52:19 (permalink)
    One has 11 replies while the other has 25 replies. So, I'm not losing it after all. Hooray!
     Heatware
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 09:56:05 (permalink)
    Zuhl3156
    It is all bill1024's Fault,  Blame him for our CRS problem.
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 10:29:53 (permalink)
    Yeah, bill1024, shame on you!
     Heatware
    • Ribbons : 52
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 10:41:06 (permalink)
    I think it is OK for two threads in different locations in this particular case because one deals with 9XX owners and the other dealers with 10XX owners.
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 10:45:22 (permalink)
    I would agree I only wish the titles were a not the same.
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 10:57:24 (permalink)
    I agree. The absolutely totally identical title throws me a curve every time. Too many times I see one and when I click on it I get a message saying that it was moved to the correct forum. Then it stays in its original location too where I never know if I should click it or not. Sometimes I am missing out on something I would find interesting and other times I am wasting one of my limited amount of keystrokes on my K70 keyboard.
     Heatware
    #23
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 11:02:14 (permalink)
    Zuhl3156
    Yea I see that to when a Mod moves a Thread, it would be nice if the did not post a Thread saying it was move or add the Word Moved at the end of the title.
    #24
    bill1024
    • Ribbons : 12
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 11:07:04 (permalink)
    I changed the threads name, lets see if that fixes it.
    Never had this happen before.
    #25
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 11:09:53 (permalink)
    bill1024
    Oh, speak of the Devil...
     Heatware
    #26
    bill1024
    • Ribbons : 12
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 11:14:57 (permalink)
    Zuhl3156
    bill1024
    I always cause trouble. Trouble is my middle name.
    #27
    • Ribbons : 68
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 11:17:01 (permalink)
    Let it Go!
    This Thread can be Deleted if needed.
    post edited by bcavnaugh - 2016/06/25 12:12:48
    #28
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 11:20:36 (permalink)
    bill1024
    Zuhl3156
    bill1024
    Mine too! What a coincidence. There's no option to list our middle name in our forum profile or we would have already known that.
     Heatware
    #29
    Zuhl3156
    • Ribbons : 30
    Re: Odd Issues on the Forum (Found Duplicate Posts or Same Title Names) 2016/06/25 12:04:10 (permalink)
    You Buzzkill, you!
     Heatware
    #30
