Surenzxx
Whenever I uncheck the Nvidia Control Panel's "Show Notification Tray Icon" option the system tray icon keeps popping up. Every time I do uncheck the tray icon disappears, but if I open Nvidia Control Panel again and close it the icon keeps popping up. The same thing happens everytime I restart or log off. I have tried searching this problem but I haven't found any relate-able problems or solutions. Is there anyway to stop the icon from popping up so much? I really hate unnecessary icons in my system tray since the Nvidia Control Panel is already in my desktop context menu.
Re:Nvidia Settings System Tray Icon Won't go away
2013/01/12 20:50:20
wow all this rage for a poor tray icon... sorry mate i never tried since i didn't notice it!
Case:Corsair Obsidian 650D M.B.:ASRock Z68 Ext7 Gen3/PSU: Seasonic-X 850W Gold GPU:2xEVGA GTX680 2GB/RAM:16GB DDR3 Corsair CPU:Intel i5 2500k@4.6Ghz+Zalman CNPS9900 MAX FANS:3xBitFenix Spectre PRO RedLed SSD/HDD:OCZ Agility 3 60gb/Samsung 840 250gb/WD Raptor 300gb/Seagate Barracuda 500mb MICE:Corsair M60/KB:Razer BlackWidow/HP:Roccat Kave 5.1/Shure SRH440 Screen:BenQ XL2420T+Asus PA238Q
- Ribbons : 57
2013/01/12 20:59:38
Surenzxx Whenever I uncheck the Nvidia Control Panel's "Show Notification Tray Icon" option the system tray icon keeps popping up. Every time I do uncheck the tray icon disappears, but if I open Nvidia Control Panel again and close it the icon keeps popping up. The same thing happens everytime I restart or log off. I have tried searching this problem but I haven't found any relate-able problems or solutions. Is there anyway to stop the icon from popping up so much? I really hate unnecessary icons in my system tray since the Nvidia Control Panel is already in my desktop context menu. That is a strange one. What driver version are you using and have you tried a clean install of the driver? In other words, When installing the driver, select custom, the check the clean install box then select the driver item you wish to install. Secondarily using the clean install option you can deselect the Nvidia Update Component and see if that cures it.
EVGA E758/i7 980x 4.3ghz 1.36v 12GB Corsair Dominator 2000C9 GTX 980Ti w/GTX TITAN SC for PhysX Crucial M4 512GB SSD/2x WD RE4 Black 2TB Corsair H50 Cooler/Corsair AX1200/Window 10 Pro
maniacvvv
- Ribbons : 159
2013/01/12 21:01:25
Surenzxx Whenever I uncheck the Nvidia Control Panel's "Show Notification Tray Icon" option the system tray icon keeps popping up. Every time I do uncheck the tray icon disappears, but if I open Nvidia Control Panel again and close it the icon keeps popping up. The same thing happens everytime I restart or log off. I have tried searching this problem but I haven't found any relate-able problems or solutions. Is there anyway to stop the icon from popping up so much? I really hate unnecessary icons in my system tray since the Nvidia Control Panel is already in my desktop context menu. This occurs because you used the "express" install option or used Nvidia "auto update" which uses the same... Doing so==> installs 4 added components that are -completely- unneeded, one of which is the NVTray The fix is quite easy. Download your current driver from Nvidia Launch the installer, using "CUSTOM MODE" Uncheck everything--> but the Nvidia Graphics Driver and PhysX (only these two components are needed) AND-->Put a check box in "perform a Clean install" Click next and complete the install... No more NVTRAY, use the control panel if needed
squall-leonhart
- Ribbons : 7
2013/01/12 21:18:30
nvtray is not present if updater is removed.
CPU:Intel i7 920 @ 3.8(D0), Mainboard:Asus Rampage II Gene, Memory:12GB Corsair Vengeance 1600 Video:EVGA Geforce GTX 680+ 4GB, Sound:Creative XFI Titanium Fatal1ty Pro, Monitor:BenQ G2400WD HDD:500GB Spinpoint F3, 1TB WD Black, 2TB WD Red, 1TB WD Black Case:NZXT Guardian 921RB, PSU:Corsair 620HX, OS:Windows 7 SP1
- Ribbons : 57
2013/01/12 21:25:32
maniacvvv Surenzxx Whenever I uncheck the Nvidia Control Panel's "Show Notification Tray Icon" option the system tray icon keeps popping up. Every time I do uncheck the tray icon disappears, but if I open Nvidia Control Panel again and close it the icon keeps popping up. The same thing happens everytime I restart or log off. I have tried searching this problem but I haven't found any relate-able problems or solutions. Is there anyway to stop the icon from popping up so much? I really hate unnecessary icons in my system tray since the Nvidia Control Panel is already in my desktop context menu. This occurs because you used the "express" install option or used Nvidia "auto update" which uses the same... Doing so==> installs 4 added components that are -completely- unneeded, one of which is the NVTray The fix is quite easy. Download your current driver from Nvidia Launch the installer, using "CUSTOM MODE" Uncheck everything--> but the Nvidia Graphics Driver and PhysX (only these two components are needed) AND-->Put a check box in "perform a Clean install" Click next and complete the install... No more NVTRAY, use the control panel if needed This issue should not occur using the express install option from the installer. He should be able to deselect the 'Display Notification Tray Icon' using the Nvidia Control Panel and it should not display.
maniacvvv
- Ribbons : 159
2013/01/12 21:33:31
All the more reason to perform a correct Custom/Clean install
- Ribbons : 57
2013/01/12 21:39:02
maniacvvv All the more reason to perform a correct Custom/Clean install I think you misread my post.
Surenzxx
2013/01/12 21:39:32
maniacvvv Surenzxx Whenever I uncheck the Nvidia Control Panel's "Show Notification Tray Icon" option the system tray icon keeps popping up. Every time I do uncheck the tray icon disappears, but if I open Nvidia Control Panel again and close it the icon keeps popping up. The same thing happens everytime I restart or log off. I have tried searching this problem but I haven't found any relate-able problems or solutions. Is there anyway to stop the icon from popping up so much? I really hate unnecessary icons in my system tray since the Nvidia Control Panel is already in my desktop context menu. This occurs because you used the "express" install option or used Nvidia "auto update" which uses the same... Doing so==> installs 4 added components that are -completely- unneeded, one of which is the NVTray The fix is quite easy. Download your current driver from Nvidia Launch the installer, using "CUSTOM MODE" Uncheck everything--> but the Nvidia Graphics Driver and PhysX (only these two components are needed) AND-->Put a check box in "perform a Clean install" Click next and complete the install... No more NVTRAY, use the control panel if needed Thank you so much.
post edited by Surenzxx - 2013/01/12 21:46:32
codekrash
2016/08/27 10:54:20
it's been 3 years and maniacvvv's workaround no longer works! Does anyone know how to cease the endlessly persistent tray icon (advertisement token)'s appearance? The thing is, if the setting is within the NVIDIA control panel then I won't be able to access that GUI because I don't have a monitor attached to my NVIDIA GPU. For some reason if you don't have something actually attached to the card it will take a (Deleted for Foul Language) on your face if you try to open the control panel. It would seem like this (Deleted for Foul Language) wouldn't be an attribute of NVIDIA (Deleted for Foul Language) still, but it is. I WONDER WHY , no i don't, it's willful ignorance because of all of the game streamers, people see that (Deleted for Foul Language) nvidia icon and its ultimately adding a boost of awareness and thus revenue. If you right click -> exit - close the icon then the endless timed loop will fire the (Deleted for Foul Language) up again in 5 minutes or so. I thought it was a (Deleted for Foul Language) virus at first using the (Deleted for Foul Language) to launch something else so i ran an MBAM scan which turned up clean Even with an empty task scheduler it still manages to remain permanently (Deleted for Foul Language) affixed to my screen because the god damn kernel mode video drivers are invoking the launching of this trash. I don't (Deleted for Foul Language) like being used. (Deleted for Foul Language) off for trying to using me. This will be my last NVIDIA purchase because of this. Not EVGA related, just too mad to post my grievance on the right forum. Not so (Deleted for Foul Language) subtle now is it NVIDIA you greedy (Deleted for Foul Language)
post edited by XrayMan - 2016/08/27 20:36:12
2016/08/27 11:20:36
#1 Boot into safe mode. #2 Delete nvtray from C:\Program Files\NVIDIA Corporation\Display\ #3 Reboot PC. #4 Done.
codekrash
2016/08/27 12:39:56
thanks for the info, that seems to work how do i make it not reappear when NVIDIA releases an updated driver and i install that or even if that gets installed automatically if i decide to get (Deleted for Foul Language) experience?
post edited by XrayMan - 2016/08/27 20:37:02
2016/08/27 12:42:34
codekrash thanks for the info, that seems to work how do i make it not reappear when NVIDIA releases an updated driver and i install that?
Uncheck it in the Control Panel, that is if you install the driver from NVIDIA and Not Windows Update.
2016/08/27 12:43:04
codekrash thanks for the info, that seems to work how do i make it not reappear when NVIDIA releases an updated driver and i install that or even if that gets installed automatically if i decide to get (Deleted for "quoting" Foul Language) experience?
No problem. You'll have to delete it again on each new driver install. Don't install geforce experience.
post edited by XrayMan - 2016/08/27 20:37:51
- Ribbons : 52
2016/08/28 00:47:49
I'll remind everyone that cursing/swearing isn't allowed on the forums. Such posts will be deleted or edited.
(Pazmeister: rjohnson.....YOU ARE A LEGEND, problem solved, i am sendning my missus round to you now so she may have your babies!!) , R.I.P Jeffreyham, R.I.P Corsair_Mike, R.I.P Wrinvert, i7 5820K, Corsair H100, Corsair Vengeance LPX 32GB (CMK32GX4M4A2666C16R), EVGA GTX 1080FTW ACX, Corsair AX1200, EVGA X99 Micro2, Samsung Sm961 m.2, One Corsair SSD, Crossover 4K,
