No signal problem
dragon_27
2011/11/01 18:12:59 (permalink)
I just took my comp apart for a major dust removal, get everything back together, plug in the monitor and I get no signal, I go back through check all my wires unplug and plug them back in even replugged my vid card everything is fine I get a FF on the bios screen my heatsink is  on tight and all nothing wrong with it, I dunno what to do now.
I have 780i SLI mobo with Geforce 8800 GT. I'm lost i dunno what to do now. side telling my friend I won't make it to Raid tonight if they need me. lol
9 Replies Related Threads
    quadlatte
    • Ribbons : 32
    Re:No signal problem 2011/11/01 19:26:40 (permalink)
    check in your PCIE slot, a stray dust bunnies could get in there and cause a problem, also make sure you are plugged into port one on the video output
                                                 Heatware: http://heatware.com/eval.php?id=72498
    dragon_27
    Re:No signal problem 2011/11/01 19:29:24 (permalink)
    back i took can air to ram slots and pcie slots and still getting unsupport/no signal.
    I also just now noticed that the comp isn't going through the boot up sequence.
    post edited by dragon_27 - 2011/11/01 19:36:08
    quadlatte
    • Ribbons : 32
    Re:No signal problem 2011/11/01 19:32:08 (permalink)
    dragon_27
    remove the card and look into the slot with a light, that air can just push it right down in there and will stay until you pull it out.
    dragon_27
    Re:No signal problem 2011/11/01 19:46:33 (permalink)
    ya it's clean as a whistle. and no boot up sequence.
    nick1551
    • Ribbons : 24
    Re:No signal problem 2011/11/01 19:58:52 (permalink)
    Is it going directly to the FF code, if so.
    Check to see it you knocked loose your bios chip on the motherboard.  Press down on it.
    Also try a bios clearing.
    And double check the cpu power connector.
    Check this out too:
    Evga "FF" diagnostic video and guide
    some more ideas:
    http://www.evga.com/support/faq/afmviewfaq.aspx?faqid=58002
    post edited by nick1551 - 2011/11/01 20:03:03
    Heatware      Evga 8800GT 512mb Fan Speed BIOS
    i7-920 @4.0 - Evga X58 Micro - 2x4gb Gskill - Evga GTX 760 ACX @1228mhz
    WD 1tb Blue - Corsair HX620 - CM690
    Nexus 4 -- Beanstalk 4.4.2 - LTE+ART enabled
    Moto G  --  Stock 4.4.2
    dragon_27
    Re:No signal problem 2011/11/01 20:03:57 (permalink)
    Fly'n monkey balls. ya it was that black little chip. now i'm up and running and now i know what to do if it happens again. i didn't even think about that chip i should have though since the chip was originally loose on the board when i got it.
    Thank you for the help everyone.
    nick1551
    • Ribbons : 24
    Re:No signal problem 2011/11/01 20:16:16 (permalink)
    Your welcome, have fun
    Afterburner
    • Ribbons : 108
    Re:No signal problem 2011/11/03 16:37:51 (permalink)
    AB Was here...
    quadlatte
    • Ribbons : 32
    Re:No signal problem 2011/11/03 17:17:50 (permalink)
    dragon_27
    great to hear
