HAZMAN_THE_GREAT
- Ribbons : 7
http://www.extremetech.com/computing/191128-nexus-6-leaks-5-9-inch-moto-monster-with-2560x1400-display-3200-mah-battery According to 9to5Google, the Nexus 6 won’t be all that different from the second generation Moto X– the site even called it a “scaled up” version of Motorola’s latest. There will be some minor tweaks designed to make the screen easier to use and the volume / lock buttons will be positioned a bit lower but that’s about it. As for specifications, the 5.92-inch display will be of the QHD nature (2,560 x 1,440) with a pixel density of 498 PPI. A 3,200mAh battery will be tasked with powering all of those pixels throughout the day. Around back is a 13-megapixel camera rumored to be able to shoot 4K video at launch. A 2-megapixel camera will be used on the front, identical to the one on the second generation Moto X. It has almost every freaking spec that I wanted from this phone!! The only spec I dont care about is the camera because I dont take pictures. But BOY that battery and res pixel density is going to be sweet!! But the best part is its going to be STOCK android so I dont have to worry about all that Samsung and HTC bloatware crap and I finally can get my updates even faster without those too phone companies converting the android experience to their UI.
ARMYguy
Re: Nexus 6 leaks: 5.9-inch Moto monster with 2560×1400 display, 3200 mAh battery
2014/10/01 06:14:01
I have the verizon Droid Maxx which is basically stock android, with a 3500 mah battery. I go over 2 days on one charge of normal use. Its pretty skippy. I hope there is something else with this size of battery when i upgrade in a year.
Asus Strix Z790 F - Intel 13700 K - Gigabyte 4090 Windforce - 32gb DDR 5 - 1TB Samsung SSD 850 evo - Windows 10 Pro - 1TB Samsung M.2 860 - Inland 2 TB NVMe - Acer Predator X27
dyno0919
- Ribbons : 8
2014/10/01 09:50:35
Wow, looks like I won't be upgrading from my Nexus 5. A 6 inch phone is WAY too big to fit in my hand comfortably or fit in my pockets.
Brad_Hawthorne
- Ribbons : 39
2014/10/01 11:00:07
dyno0919 A 6 inch phone is WAY too big to fit in my hand comfortably or fit in my pockets. That's what she said.
Bruno747
- Location: Looking on google to see what Nvidia is going to o
- Ribbons : 5
2014/10/02 16:47:12
Hmmmm, seems like an LG g3 with stock android. Maybe I missed something in the specs I'll have to look at my lg g3 again. If they would have released this instead of the nexus 5, I would already have one. Glad to this might also come with more than 2gb of ram. Thats a barrier we have needed to break for a while IMO.
X399 Designare EX, Threadripper 1950x, Overkill Water 560mm dual pass radiator. Heatkiller IV Block Dual 960 EVO 500gb Raid 0 bootable, Quad Channel 64gb DDR4 @ 2933/15-16-16-31, RTX 3090 FTW3 Ultra, Corsair RM850x, Tower 900
Nitemare3219
2014/10/03 11:29:29
If these specs are true, and the camera delivers, I will jump from my G3 to the N6. I love the Nexus line, but the camera has always been lacking. After taking some really nice pictures for once, it's hard to go back. The G3 is a laghouse though compared to my N5 which I only use for music in the gym/outside now.
MSI X570 Tomahawk | Ryzen 5800X | Samsung 980 Pro | 32GB Trident Z Neo | RTX 3090 Obsidian 5000D | SuperNOVA 1000 P2 | 48" C1 4K LG OLED | Naga | G915 TKL | Sennheiser HD 800 S | Grace m9XX
Dooms87
2014/10/03 16:09:19
any idea what chip it'll be using ? Snapdragon 805? or better ?
NZXT Phantom 630 - Asus P6X58D-E - EVGA GTX 680 FTW 4gb - Intel I7 930 2.8 Ghz OC @ 4.0Ghz - H80 Corsair HX1000W - Corsair 12gb DD3 Dominator ram 1600 - Intel 80 gig X25m SSD - Samsung 500g HDD -Logitech G15 - Logitech G9X -Win 8.1 Pro 64-bit
NazcaC2
EGC Admin
- Ribbons : 38
2014/10/03 19:51:13
Intel i9-12900K ASUS Prime Z690-A Corsair 850W RM850x Windows 11 Professional Arctic Liquid Freezer II 360 A-RGB Corsair Dominator 32GB DDR5 5200MHz EVGA GeForce RTX 3080 Ti FTW3 ULTRA GAMING 4x Samsung 2TB 980 Pro SSD + 1x ADATA 512GB SU800 Corsair iCUE 5000X RGB SIGNATURE SERIES Mid-Tower - Neon Night
- Ribbons : 84
2014/10/04 03:51:37
The main problem with the Nexus 5 was poor battery life and poor camera. Let's hope there are sufficient improvements in both areas. If Google can keep the price very low, let's say 499 dollars or so then they have a winner.
bornn
2014/10/04 20:09:45
rjohnson11 The main problem with the Nexus 5 was poor battery life and poor camera. Let's hope there are sufficient improvements in both areas. If Google can keep the price very low, let's say 499 dollars or so then they have a winner.
I feel like every nexus phone is cursed with a terrible camera.
Ryujin Jakka
2014/10/05 03:23:43
6 inch is way too big if it had been 5.5 i would have bought it. Anyways when it is being released?
HAZMAN_THE_GREAT
- Ribbons : 7
2014/10/05 08:05:14
Ryujin Jakka 6 inch is way too big if it had been 5.5 i would have bought it. Anyways when it is being released?
Supposed to be this month. Unless otherwise
NazcaC2
EGC Admin
- Ribbons : 38
2014/10/05 15:09:59
Android 5.0 L is supposed to increase battery life 30%-40% and the Nexus line will be the first to get it. This may help the Nexus 5.
HAZMAN_THE_GREAT
- Ribbons : 7
2014/10/12 10:22:48
Here is an update article on this phone. Boy I am actually excited for a cellphone for the first time. I guess because it actually has all the specs that I am asking for from a phone. I want that BIG screen, bigger battery compared to my 2100mAh from my S3, high res screen, and most important of all is stock android. http://www.techspot.com/news/58400-nexus-6-release-soon.html
