New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d - Semi Guide
Page: < 12345 Showing page 5 of 5
cryptospartin
  • Ribbons : 8
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/04/29 00:45:46 (permalink)
those are some very good temps for a 480 in sli
Evga X58 Classified E60 920 D0
Mushkin XP3-12800
HeatKiller V3
2x XFX 5870 E.K Blocks Crossfire
Evga GTS 250 Physx
WD Black 640
Seagate 500GB
LG BH08-LS20 Blu-Ray Burner
Samsung SH-S223C
X-Fi Titanium Fatal1ty
Strider 1500W
XSPC Dual Res Bay
Feser Triple 2x Single
Noctua NF-P12 PUSH and PULL
Corsair Obsidian 800D
Windows 7 X64
http://www.heatware.com/eval.php?id=68344
sledgehammer70
  • Ribbons : 11
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/04/29 00:50:52 (permalink)
cryptospartin
no no no.. that is on a single GTX 480 OC'ed at 868/2125. 2 GTX 480s on a GTX 240 rad = 39c idle and 54c load which is a 15c delta = on the edge of cooling -  but than again that is running with 1500RPM fans.
I am in the midst of updating my system even more for better cooling, which can be seen here: http://forums.evga.com/tm.aspx?m=311255
Thanks
Sledgehammer70
cryptospartin
  • Ribbons : 8
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/04/29 00:53:19 (permalink)
oh i thought it was cooling in SLI but still good temps how is the performance on the intel chip x980
Mushkin XP3-12800
HeatKiller V3
Evga GTS 250 Physx
WD Black 640
Seagate 500GB
Samsung SH-S223C
Strider 1500W
XSPC Dual Res Bay
Windows 7 X64
sledgehammer70
  • Ribbons : 11
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/04/29 01:01:31 (permalink)
cryptospartin
I have her purring at 4.6GHz and it never jumps above 63c. Overall pretty happy with the temps.
post edited by sledgehammer70 - 2010/04/29 01:11:05
Thanks
Sledgehammer70
cryptospartin
  • Ribbons : 8
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/04/29 01:02:24 (permalink)
nice to hear that is my next chip
Mushkin XP3-12800
HeatKiller V3
Evga GTS 250 Physx
WD Black 640
Seagate 500GB
Samsung SH-S223C
Strider 1500W
XSPC Dual Res Bay
Windows 7 X64
sledgehammer70
  • Ribbons : 11
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/04/29 13:41:59 (permalink)
Finally done...
Thanks
Sledgehammer70
Halo_003
  • Ribbons : 50
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/04/29 18:17:14 (permalink)
Wow that looks SICK!! Great job!
Okay, I think I'll go with a 480 for CPU+Chipset, and a 360 for GPU loop. What brand of RAD should I look for? Fans will end up being CM R4s for the GPU loop. And 3k RPM Kazes for the CPU loop. I.e. Swiftec, HWlabs SR1, Black Ice, etc.
SirKronan
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/01 23:11:51 (permalink)
Whoa. Nice work.
I did notice, however, that this looks REMARKABLY similar in a lot of aspects to what Mr. Armageddon did with his build here:
http://forum.corsair.com/...showthread.php?t=81684
Fan controller, pumps, reservoirs, bottom radiator mod ... same rubber spacers and hex head bolts, etc....
post edited by SirKronan - 2010/05/01 23:15:02
Workstation/Playstation: i7 970 on EVGA X58 TriSLI, GTX 295, Intel 2nd Gen 80GB SSD, WD 640x2 RAID 0, 12GB OCZ DDR3 @1600MHz, Corsair 800D, Dell 24", Razer Lycosa, Logitech G9, HTO Striker, Windows 7 Ult. 64, Antec TruePower 1000w.
Wife's Computer: E4500 @ 3.0GHz on 1.36v, Rocketfish CPU Cooler, Foxconn, 4GB Corsair, Sea 250, Antec Sonata w/500w, ATI 2400, 17" Samsung, Vista Ult. 32.
HTPC: X2 2400BE, 500GB + 750GB + 80GB, ATI 3450 Hybrid CF w/Asus 780G, 4GB A-Data 800MHz DDR2, 32" Westinghouse, XBOX 360 HDDVD (w/o xbox), Aver DTV Tuner, Huappage DTV tuner, Vista HP 32.
PDAs: iPod Touch 16GB (jailbroken) and Samsung Fascinate (Galaxy S) undervolted and OC'd @ 1.1GHz
sledgehammer70
  • Ribbons : 11
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/01 23:31:42 (permalink)
SirKronan
Whoa. Nice work.
As I have said before a lot of the inspiration came from his design.  I have done quite a bit to deviate from his build now. If you read that thread you will see me posting questions to MR. A about his build when i started mine.
Thanks
Sledgehammer70
lordemanuel
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/06 18:33:51 (permalink)
Sledge how were you able to mount that koolance Radiator mount and a fan?  Did you skip the quick disconnect?
sledgehammer70
  • Ribbons : 11
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/07 11:54:33 (permalink)
lordemanuel
I used their 140MM adapter... allowed me to use the 120mm holes on the case for the fan. So I was than able to screw in the mount to the adapter instead of the case. So the mount for the rad is mounted to the adapter which is screwed into the 140mm holes while the 120mm fan is untouched and still mounted.
You can't go the other route and mount a 140mm fan as the mounts that come with the Koolance mount will stick into the fan.
Thanks
Sledgehammer70
threedhero
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/12 15:07:54 (permalink)
Nice to see a good looking rig that can also produce some good scores.
sledgehammer70
  • Ribbons : 11
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/12 16:54:37 (permalink)
Sorry for the delay... got the camera back and snapped some images of the back rad mount and some of the new fittings I used. I replaced the Koolance SLI fitting as I just didn't like the way it looked. Also the HC FTW cards have ample space to not need a spacer with 1/2" compression fittings. so it just looks thicker & i am sure doesn't force a constraint on the flow as much.
Instead of cutting a hole in the case I used my lower PCI-E bay to port the wires for power.
Thanks
Sledgehammer70
Halo_003
  • Ribbons : 50
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/12 18:59:31 (permalink)
Nice! That's very ingenious!
imweasel
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/12 20:37:18 (permalink)
Quick question about the 120.3 rad on the back.  I bought the Koolance Radiator Mounting Bracket to help move the rad away from the back of my case (so I was concerned about access to the HDMI port)
Do I see something underneath your rad on the back that is helping hold up the weight of the 120.3?  I was going to put my 120.2 on the back and put my 120.3 in the top of my case because I was concerned about the weight of the rad+water on the back.
Thanks!
Intel X99 5830k @ 4GHz
Gigabyte X99 UD-4 (v1.0, F22 BIOS)
32GB (4x8GB) GSkill 2800 RAM
Cosmos 1000 case
CPU Cooling Loop:
     Some kind of CPU block I can't remember
     Koolance RP-1000BK
     Black Ice SR1 360 Rad
Windows10 x64 Fast-ring tech preview
Samsung 950 PRO 256GB PCIe NVMe - M.2 SSD
EVGA GTX 1080 FTW Gaming ACX 3.0
EVGA PowerLink™
EVGA SuperNOVA 1200 P2 P/S
28" Hanns-G LCD
sledgehammer70
  • Ribbons : 11
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/13 11:27:49 (permalink)
The weight isn't an issue... The black item you see is a cut to size paint stick to push the rad out to have it more parallel with the case. Most people with this mount will attach it at the 2nd fan port to evenly distribute the weight. I didn't like the way that looked.
Thanks
Sledgehammer70
sledgehammer70
  • Ribbons : 11
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/05/30 08:02:13 (permalink)
So... I have been folding with the new GPU3 that was released from F@H, and in that I was not to happy with some of the temps on my CPU & GPU. So to fix that I have been toying with the idea of moving my chipsets off the CPU loop and reversing the flow of my GPU's so that the chipset was the last item to be cooled in the loop before going through 2 Radiators.
I just got the loop's back together here are a few quick images that show the water flow on the GPU loop.
I did some extensive temp testing on the loops before swapping them around, and have begun to put this new layout through the trenches.
So the loops have warmed up and the liquid temp has dropped on the CPU loop by 3.6c & the overall load temp on the CPU it self has dropped roughly 2.5c Not huge but an improvement for just taking the chipset off this loop.
As for the GPU loop the lower card is now the cooler of the 2 which is good as less heat is generated that rises into the 2nd card, and the temp difference between the 2 cards has come closer together. When the flow was going from GPU 1 to GPU 2 the bottom GPU would run about 3c hotter Now with the flow going from the bottom to top the temps are only 1c apart. Nothing huge, but in general better.
Now the GPU loop did get an additional amount of heat to cool along with having more pressure and resistance to overcome, but with the basics of allowing the heat to flow the way it should (UP) There is a difference in temps.
First off before the swap the VREG's on the CPU loop ran at about 45c idle and would reach 52c when the CPU was under full load. Now that they have been switched to the GPU loop the VREG's run at 45C with the GPU's under full load, which overall allowed us to drop the chipset temps 7c. To me that is a huge temp drop which I am sure will lead to a more stable OC. I haven't let the system run idle yet as I am seeing how hot everything gets, but it will be nice to see what temps the VREG's sit at idle.
As for the GPU's its hard to say how hot they are getting just yet. It was 95 degree outside today and is still currently 82 degrees in my office, and with F@H running for the last 1 hour+ the GPU's are holding at 45C at full load.
Now earlier today in the old loop GPU #2 was peaking at 51C and GPU #1 was at 47C, so in general it seems the cards are running cooler, but overall the big difference is that card #2 is cooler overall and within range of GPU #1's temps.
I am going to allow more testing and let these temps set in a bit more before I make a full blown conclusion, but so far the temps seem to be better. Will that yield a better OC? who knows, but until I find out stay tuned.
Thanks
Sledgehammer70
Johnny-1987
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/06/20 01:05:35 (permalink)
awesome mate  but why the rad externally? Why not a 360 on top and a 240 on top, 240 for both bpu's, 360 for cpu+chipset?
Core i7-975 / 3x2GB 1866mhz Dominator Gt's / EX58-UD3R /
SLI GTX 295 Co-ops / 2x 128gb SSD's / Corsair HX-1000W /
Heatkiller Water Block
7/16 Primochill U/V Tubing
360GTX Black ice rad/ PA 120.3
D5-Vario Pump
 EK-Multioption 250 Rev Reservoir
Primochill Non-Conductive Coolant
1/2 DD fatboy Fittings
churto
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/08/18 17:48:08 (permalink)
Awesome build
YerBuddy
  • Ribbons : 59
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d 2010/08/21 03:11:14 (permalink)
Johnny-1987
Excuse me, but did you not read the entire thread?
I love it sledge!
