mikotan
- Ribbons : 10
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d
2010/04/01 16:37:21
First great build. second, the slipstream fans die really fast. I suggest getting/trading to scyth S-flex fans. third, ocz freeze can clog up the loop. so watch it and dont give it a chance to still. keep it moving. the best is to go with Distilled + silver coils (.999 pure). After 2 years of silver coils... ive only had to drain my loops once, and that was to add more parts. When i previously used ocz freeze, dyes, and other additives (excluding petras pt nuke), I would come across cleaning my loop at least once every 6 months. with the power of the mcp355 and 655, tube length incase will hardly matter on the flow/temp. these pumps are built strong. even more so if you have an eiheim or a fishtank equivalent pump. As for static pressure, honestly with the 1600 sflex fans, you really wont have to worry about anything. I use the 1600 ones myself with noctua fans and my rig stays cool and blew cool air to my face so I had to re-position my rig to the floor.... again its all preference in the end. but im very firm in my belief that DW + silver = best ever.
2010/04/01 16:49:51
mikotan First great build. second, the slipstream fans die really fast. I suggest getting/trading to scyth S-flex fans. ] Its to bad they don't make the S-flex in a 140mm layout.
mikotan
- Ribbons : 10
2010/04/01 17:01:35
DOH! lol... yeah 140mm fans are still like a vacuum space for fans. not too many good 140mm fans out yet...
2010/04/01 20:17:38
zimbambadu I went with the SR-1. Apparently it can handle fan speeds up to 2000 rpm. I'm not sure what this means exactly as RPM doesn't exactly equal CFM, but I think that I will go with lower RPM but higher CFM fans. The SR-1 was specifically designed to drop into a system with low airflow (800RPM's) the GTX will also do the same thing. Overall the GT, GTX & SR-1 work well with high flow fans (2000RPM's) the GT is the only one not really designed for low flow fans. ---------------------------------------------- So I dropped the 2 new 140mm fans in the case... and... temps actually dropped. Scythe 140x25mm SlipStream SM1425SL12H - 92.4 CFM http://www.sidewindercomputers.com/sc14slsm92cf.html I have 2 of the above fans running at 1350 RPM that have replaced the crappy 1000RPM fans that shipped with my Obsidian 800d case. I have to say I am impressed... GPU Loop: The GTX 295 now sits at a nice 35c at idle instead of 39-40c and under full load on Furmark for 1 hour it peaked at 46c overall a 4c drop in temp at full load and 5c temp drop idle. CPU Loop: This one was a bit harder to calc as temps are all over sometimes. But before I tested the system with the new fans I had it running for 2 hours idle to see where the temps sat at. ELEET reported CPU 30c 44,42,43,41 (case closed up). With the new fans ELEET is reading 26c 40,41,40,39 (case closed) The temps overall dropped and it was as simple as getting 2 better fans... to top it off they are just as silent as the Cooler Master fans at 1350 RPM. But if I crank them up they can be heard.
post edited by sledgehammer70 - 2010/04/02 02:04:40
vegasr
2010/04/04 19:31:07
 Awesome stuff! I love that 800D and trying to talk myself to replace my Lian Li G70 with it. Tons better features and allows awesome work like yours. Your design is awesome, and I have the same feelings about being able to move that 655 pump. Did you have any other alternatives on putting the 655 pump anywhere else? Looking at your pics, is it possible to move it to the right side of the vid card, and rotate it to where the inlet was pointing upwards towards the res and the outlet facing to the left? Hope that makes sense.
i7 3930K @4600-1.376v w/Swiftech Apogee HD Block, 2 - 120 rads, Rampage IV Formula, 2x EVGA GTX 980 KPEs in SLi, Crucial 256GB SSD, WD Black 1TB, G.Skill 16Gb 2133 C9, Dell U3011, Enermax Galaxy EVO 1250 psu, Corsair Obsidian 700D, Logitech Z-5500s.
2010/04/04 21:00:58
vegasr Awesome stuff! I love that 800D and trying to talk myself to replace my Lian Li G70 with it. Tons better features and allows awesome work like yours. Your design is awesome, and I have the same feelings about being able to move that 655 pump. Did you have any other alternatives on putting the 655 pump anywhere else? Looking at your pics, is it possible to move it to the right side of the vid card, and rotate it to where the inlet was pointing upwards towards the res and the outlet facing to the left? Hope that makes sense. The only thing with that placement is it will be covering the air passing from the bottom. the Dual Rad setup relies on that 140mm fan to be there. I could move the pump next to the smaller 335 but than it would be a mass of tubing right there. I have an idea that will allow me to make the stack look better and cleaner, but i will not be able to show that off until I get the 2 GTX 480's. The only other option I have is getting another 335 with a 1/2" top... which could be a good route to go to make the case look a little cleaner and would allow both pumps to be in the same location.
vegasr
2010/04/05 21:27:50
I think if you leave it as is, thats awesome. Was just wondering though but again, great job.
2010/04/06 00:42:48
sledgehammer70 zimbambadu I went with the SR-1. Apparently it can handle fan speeds up to 2000 rpm. I'm not sure what this means exactly as RPM doesn't exactly equal CFM, but I think that I will go with lower RPM but higher CFM fans. The SR-1 was specifically designed to drop into a system with low airflow (800RPM's) the GTX will also do the same thing. Overall the GT, GTX & SR-1 work well with high flow fans (2000RPM's) the GT is the only one not really designed for low flow fans. ---------------------------------------------- So I dropped the 2 new 140mm fans in the case... and... temps actually dropped. Yeah, I figured that, but it is also true that not all 120mm fans are created equal. From the wording used to describe the SR-1, and the density of the fins (greater than the GTX), I would suspect a point of diminishing returns. I could be wrong though, things don't always work as I expect. :p I found a great article here on the different radiators: link Do you know if anyone is putting out any estimates of how many watts the overclocked 480's are going to put out? Also, thanks for the tip about the 140mm fans, I'm glad it made such an impact on your system. It bodes quite well for the rest of us. If they start coming out with good 140mm fans, I might grab a 280 instead of a 240 for my second loop. There should be plenty of room on the bottom of the case for it. I don't know that that will gain me any more in heat dissipation, but it's something to consider.
post edited by zimbambadu - 2010/04/06 01:29:08
i7-3960x @ 5ghz \ Asus RIVE \ 16gb Mushkin Redline @ 2133 CAS 9 9-11-10-28\ OCZ vertex 3 \ 2 GTX 580 SLI \ Corsair 1200 PSU \ Black Ice GTX 360 Rad \ Apogee GTZ waterblock \ Corsair 800D
2010/04/06 02:28:20
My guess on 1 480 under full load is at 300watts even than with 2 that is only 600 watts on my 900watt rated 240 rad. So I am not to worried about it. :)
2010/04/06 16:16:56
sledgehammer70 My guess on 1 480 under full load is at 300watts even than with 2 that is only 600 watts on my 900watt rated 240 rad. So I am not to worried about it. :) Word. I mainly want the 140mm form factor because the fans tend to be quieter the bigger you go. Same sort of reason I went with the SR-1 so I can get away with low fan RPMs. I'm sick and tired of fan noise. I'm sure my pumps will make noise but they don't seem to be as high pitched as some of my current fans get. I guess I just need to make some measurements to see if I can get the black ice gtx 280 in there.
2010/04/06 17:27:03
I hear you on sound... but in any case, 120mm or 140mm none of the fans I have worked with can even get 1/2 as close in noise as a stock GTX 295 fan spinning at 100%.
2010/04/06 17:38:44
That's the truth. I have a 295 and when I'm playing I dunno if I'm listening to the game or the card fan. I suspect that the 480's are going to be just as bad. I've been wanting to WC for a long time, this just pushed me over the edge. I don't seem to be able to find any EVGA Hydro Coppers for pre-order anywhere. I might just grab the normal 480 and put waterblocks on them. I dunno if that would make them easier to sell if I decide to upgrade at a later point.
2010/04/06 17:52:05
The 480 HC FTW cards have not gone on Pre-order yet.
post edited by sledgehammer70 - 2010/04/07 10:09:01
2010/04/06 18:56:54
Desktop: i7 3820 - ASUS X79 Sabertooth TUF - 4x4GB G.Skill TridentX 2400C9 - EVGA GTX 580 Classified ULTRA Hydro Copper Microsoft Surface Pro 4: i7 6650U - 16GB RAM - 256GB SSD - Sennheiser HD 598 - DualShock 4 Controller
borna
2010/04/07 02:57:19
Do you think the GTX 240 rad would be enough to cool two Fermi cards?? I'm thinking on getting the koolance blocks and cool them with the external Exos 2.5 instead of adding another 240 rad down there... Any ideas?
2010/04/07 10:08:43
The GTX 240 rad I am using is rated for 900watts and keeps my GTX 295 at 35c idle. If it can't keep 2 GTX 480's cool enough than I have a problem. But I am sure it will be more than fine.
2010/04/07 12:45:25
I think I'm going to try and put a gtx 280 in there. According to reviews I saw it was able to keep up with a lot of 3x120 rads. I don't have the link at the moment, but the heat dissipation was comparable on the same test system, and at medium fan speeds too. It's about an inch wider and 2 inches longer. Obviously that is rounded because metric / standard conversions. My case is still in the mail so I can't measure yet, or see if that is just too close to my PSU.
borna
2010/04/08 03:35:47
Please let us know how the gtx 280 or the gtx 240 would fit in there..
2010/04/08 09:23:43
zimbambadu I think I'm going to try and put a gtx 280 in there. According to reviews I saw it was able to keep up with a lot of 3x120 rads. I don't have the link at the moment, but the heat dissipation was comparable on the same test system, and at medium fan speeds too. It's about an inch wider and 2 inches longer. Obviously that is rounded because metric / standard conversions. My case is still in the mail so I can't measure yet, or see if that is just too close to my PSU. I would measure first before buying.
2010/04/08 15:37:45
Sorry if I was unclear. I am going to make sure not only will it fit, but make sure I still have an amount a workable room before I get the radiator.
2010/04/08 15:43:12
Well I took the plunge the other day and upgraded my PSU. My Silverstone 1500ST should arrive today along with the other 3 fans for my 360 radiator so I can finally get a push pull setup going. I will post images later once I have it installed.
vegasr
2010/04/08 21:01:51
sledgehammer70 Well I took the plunge the other day and upgraded my PSU. My Silverstone 1500ST should arrive today Damn nice psu!!! Hats off to you, sir. I almost got that one but went with the Enermax Galaxy Evo 1250 myself. That 1500ST is the king.
2010/04/09 02:17:49
I ran into some issues installing the Silverstone 1500ST.. In general the PSU works great & runs.. but the down side is... it will not fit properly in the Obsidian 800D case. Also the cables being very new I spent a few hours rotating and bending them in 360 motions to get them nice a loose to install properly. On the back of the PSU it has a huge plug input that sticks out a bit. See image below and you will see what I mean about not fitting. Since I have already done mods to my case that voided the warranty I will have to do some more modding around the PSU area. As with this PSU I will not be doing anything that will void its warranty. I guess I could Vinyl Black the cables since those can be repurchased from Silverstones website since this is a 100% modular PSU. Adding the other 3 fans to allow the Push/Pull setup seems to have dropped temps by 2C idle, haven;t had a chance to see how it fairs under load.
wizardx10
2010/04/10 00:04:58
WOW that looks good nice touch on well... everything! I'm just getting started in all of this stuff and it's so cool to see all this creativity. It makes my little case mods not even worth bragging about lol.
post edited by wizardx10 - 2010/04/10 00:31:58
-EVGA X58 Classified E760 -Core i7 980- stock -Noctua NH 120's (push-pull) -Corsair Dominator 6GB 1600 -EVGA 480 GTX x2 -(Water cooled) -Rad Black Ice GTX Gen Two Xtreme 240 -Heatware blocks - 3/4 OD feser tubing -Intel 120 ssd/ WD Black 640GB/ WD external 2TB -Antec TPQ 1200 -Hanns G 28'' -win 7 64 -Case Nzxt Tempest
gomnadz
2010/04/10 12:05:40
Sledghammer, so how do you like the DEMCiflex fan dust filters? I need to buy some filters for my case but not sure what kind to get just yet. if it wouldn't be to much to ask, could you take a picture of how u set the filter up?
heatware link i7 720 OC~3.6GHz/4.2GHz, EVGA Classified, G.Skill 3x2GB at 1600Mhz(7-7-7-18), ATI 5870 in CrossFire, 3x30GB OCZ Vertex's (RAID 0~90GB) and 3x300GB VelociRaptor's (RAID 0~900GB), Corsair HX 1000W, Mountain Mods Pinnacle 24, Creative X-Fi Titanium Fatal1ty Champion Series, Windows 7, Samsung 2233RZ E8600 OC ~4.4GHz, Rampage Formula, G.Skill 2x2GB at 1100Mhz (5-5-5-18), EVGA GTX 285 on water, 4x 150GB Raptor's in Raid 0 (600GB), Swiftech GTZ & 3x120 Thermochill rad, Corsair HX 850W, Thermaltake Armor Plus case, ZALMAN MFC2 Muti Fan Controller, HT Omega Claro plus+, Vista 64-bit, Gateway HDMI 22"
wizpug
2010/04/10 15:25:00
eVGA 680i A1 - XFX P32 BIOS Q6600 FSB@1300 Multi@9x @2.925GHz @1.3v AUTO AC Freezer 7 Pro Mushkin PC2-800 4-4-4-12-2T @2.1v SLI EVGA 260GTX 1x Seagate Barracuda 7200.10 500GB HD 2x Seagate Barracuda 7200.10 750GB HD 1x Seagate Barracuda 7200.11 1TB HD 1x HD103UJ Samsung Spinpoint F1 1TB SilverStone Strider ST1000-NV 1kw modular PSU Antec 900 4x Yate Loon D12SMs Samsung SH-S182M/BEBM DVD-RW/CD-RW WinXP Pro SP2 Samsung 24" SyncMaster 245bw + Samsung 42" LCD TV
2010/04/10 23:34:50
So as usual I can't keep my hands off this system... its a curse I know. I went ahead and started to make the adjustments to remove the 665 from the system as I just do not like the pump sitting in plain view. While the entire idea of the 665 was to make sure I had proper flow, I truly believe the 335 with a top will provide enough flow in the system. If I am wrong I will find out fairly quickly and can re adjust as needed. I will post images of the updates once I get my 2 GTX 480 HC FTW cards to show you just what I mean. gomnadz Sledghammer, so how do you like the DEMCiflex fan dust filters? I need to buy some filters for my case but not sure what kind to get just yet. if it wouldn't be to much to ask, could you take a picture of how u set the filter up? I like the filter a lot, but overall in the area I am at in California dust is always going to be problem. While I no longer see large specs of dust and lint in my system I have already noticed a fair amount of very fine dust on the fan blades. but in general the filters I am using are some of the best and do make a difference. I will snap some images when I get a chance.
post edited by sledgehammer70 - 2010/04/10 23:37:19
kotori
2010/04/10 23:41:27
How do you tell how many watts a radiator is rated at?
Hadron Air - MSI z97 itx - Kingston 8gb - MSI r9 290 - 2x 250ssd -4460 w/ EVGA cooler
2010/04/11 00:09:18
kotori How do you tell how many watts a radiator is rated at? Danger Den has it listed on there site. GTX 240 = 900Watts GTS 320 = 1100watts
kotori
2010/04/11 00:17:47
Whats the xflow gts 240 cover? I was looking at it on the DD site and i didnt see the info anywhere.
