kotori
Re:New Water Cooling Setup EVGA X58 3way Classified & Corsair Obsidian 800d
2010/03/27 17:25:16
Wheres the male to male and T block things go in the cpu/chipset loop because Im not seeing it.
Hadron Air - MSI z97 itx - Kingston 8gb - MSI r9 290 - 2x 250ssd -4460 w/ EVGA cooler
2010/03/27 17:33:44
It is mounted into the reservoir see this image to see how it was done. Look to the upper right. the male to male attaches to one side of the T and goes into the the res.
kotori
2010/03/27 17:40:15
Why did you do that? Isnt there a in and out hole on the res?
2010/03/27 19:54:16
kotori Why did you do that? Isnt there a in and out hole on the res? The T is for the temp sensor I have hooked to my fan controller. The T-Block is installed directly into the reservoir. The Temp sensor is installed on the top port of the T-Block. Installation is a follows: Tubing => Fitting => T-Block => Male to Male G 1/4 Fitting => Reservoir
kotori
2010/03/27 20:08:17
Ok so the temp sensor goes into part of the T block and then one end is in the res and one end is hooked up to tubing? Makes sense now. And the sites you linked are where you purchased from? I dont like buying from places ive never bought before and there seems to be a few different sites linked.
2010/03/27 20:24:35
kotori Ok so the temp sensor goes into part of the T block and then one end is in the res and one end is hooked up to tubing? Makes sense now. And the sites you linked are where you purchased from? I dont like buying from places ive never bought before and there seems to be a few different sites linked. Sidewinder, FrozeCPU & Performance PC are all solid companies to buy parts from. The links I posted were to site I purchased products from. I just bought that item at the best price from one of those 3 sites. Also stock on items played a big role. Just understand each of their return methods if needed. All 3 provided fast tracking of the orders and shipping. Performance PC took the longest to ship but they sent it UPS ground from Flordia which took 8 business days to get to California.
kotori
2010/03/27 20:27:07
Thanks. I've been wanting to do WC for a while but never wanted to take the time to learn what all is involved so I just poped a thors hammer on my i7 and oced it to 4.0ghz on air and it runs cool but I think the temps on the new cards pushed me over the edge :P
DarkOwnage_
2010/03/28 08:50:04
Alright, right now I think I am going to hold off on buying a complete new system as that will be what I would have to do lol. However, I still want to water cool my GPU. The parts you listed for the GPU loop where are they located in the pictures? Also, you listed the reservoir twice for both the CPU/Chipset and GPU. Did you just use the same reservoir or did you buy two?
DarkOwnage_ RiChess You need to unplug the ethernet cables every month and let the clogged internet packets drain out.
2010/03/28 10:40:15
DarkOwnage_
2010/03/28 11:38:00
Haha! That's awesome bro! I really didn't think you were going to go with a picture and draw lines. That is hilarious, but much appreciated lol! Thanks man :)!
2010/03/28 11:46:58
I like to help out if someone is truly interested. I know most people shy away from water cooling as it can be a bit intimidating. But overall once you see how easy it is you will never want to go back.
PRISON_BREAK
2010/03/29 16:09:28
2010/03/29 20:47:10
So the Corsair stock fans that came with the Obsidian 800d case are getting replaced (the one on the back left side of the case, and the fan porting air from the lower PSU bay). the 1000RPM 140MM fans just are not moving enough air for my liking. It seems like good 140MM fans are just hard to find. I was able to locate 2 fans that seem they can push a crap ton of air while still being easy on the ears. Scythe 140x25mm SlipStream SM1425SL12H - 92.4 CFM http://www.sidewindercomputers.com/sc14slsm92cf.html
2010/03/29 20:50:15
Very nice. I had a hard time finding good 140mm fans, so I just got some 3k RPM Ultra Kazes.
Desktop: i7 3820 - ASUS X79 Sabertooth TUF - 4x4GB G.Skill TridentX 2400C9 - EVGA GTX 580 Classified ULTRA Hydro Copper Microsoft Surface Pro 4: i7 6650U - 16GB RAM - 256GB SSD - Sennheiser HD 598 - DualShock 4 Controller
2010/03/29 21:07:49
Halo_003 Very nice. I had a hard time finding good 140mm fans, so I just got some 3k RPM Ultra Kazes. Can you link what fans you used?
2010/03/29 23:42:21
Thanks for really putting out the info of your build in this thread. I'm about to attempt water cooling myself. I want to do a few things differently, but this was a really helpful thread.
i7-3960x @ 5ghz \ Asus RIVE \ 16gb Mushkin Redline @ 2133 CAS 9 9-11-10-28\ OCZ vertex 3 \ 2 GTX 580 SLI \ Corsair 1200 PSU \ Black Ice GTX 360 Rad \ Apogee GTZ waterblock \ Corsair 800D
2010/03/30 00:42:04
Made some small adjustments to my first few threads.. they give a better overall break down of what I did to get this mod going.
Pentium777
2010/03/30 03:20:45
Thank you for posting this! With the release of GTX 480s and the concern for heat and noise (fans on high during gaming) I was thinking of going water for the first time ever. I'm running Evga 790I Ultra with Ultra 120 Extreme CPU cooler which gets me water temps for the CPU. I can run 4.2Ghz but found that the board has boot issues sometimes so I run 4.05 with DDR3-1680. I'm really concerned about water leaking and having hassles with it but seeing your temps go from 84'C to 44'C is extremely impressive to say the least on the GPUs. I am running the Coolermaster 830 case and don't really want to go crazy with a new case (although that corsair 800D looks great) I'm thinking of going with just your solution for the GPU cooling setup and leaving my CPU to air cooling, I'll have enough room for that GPU radiator by removing my HDD chassis, I have 3 SSD drives and 1 TB HDD (top of case) The other concern is total spending on new case, 2 loops then add on 2 480 GTX FTW and it is up there around $3K and while I'm no stranger to spending money in excess I need to be watching it closer for a while. How do you think I'll do with going for the GPU loop solution you've done and how scared should I be with water cooling dangers? I used to have a 210G Saltwater aquarium and I maintained it myself with live coral and a chiller to maintain water temp so I am familiar with "water cooling" fitting etc. I also have an RO system for my sink area that has fittings as well. They can leak it is one thing to come home to your floor with a few GALLONS of water from aquarium or under your sink having several cups of water laying there, but totally another to find a few drops inside your PC and zap your system is down. So I'd like to move forward to at least cool the GPUs do you think I should also just go ahead and cool the CPU as well with the GPU radiator? I don't really need to have 44'C GPU temps if the temps increased a little with CPU added on that'd be OK. I definately won't be water cooling the chipset on the 790I board. Since your GPU loop had 2x120mm fans it will fit inside the front of my case to pull cool air from outside to the radiator. I guess it would be kind of dumb to go water and not do the CPU but will that save me some risks as well by not having 2 more fittings close to the MB? Thanks again for posting all of this info and pictures it has been extremely helpful and any insights to my dillemas would be greatly appreciated! Sidewinder computers is an excellent company I've ordered fans from there and they are A+++, I also highly recommend the Scythe fans I have 8 or 10 of the 120mm versions, they are the most quiet with highest CFM due to the special type of motor they use. Why did you decide not to get the Black Ice SR-1 240? Seems superior to the GTX240. http://www.hardwarelabs.com/index.php?option=com_content&view=article&id=8&Itemid=3
post edited by Pentium777 - 2010/03/30 05:55:08
2010/03/30 09:42:22
If your just going GPU loop only you will have an even easier time overall. The GTX 480 will push out 300w+ more then the GTX 295 with them in SLI so I would think the temps might rise 8-12c in my current GPU loop. This is completely dependent on air flow and other factors. Water is not an issue for leaks tbh. I posted some video on Youtube I will bring over here showing how I leak tested the system. In general if your using compression fittings just make sure they are tight. line the inside of your case under all the fittings with a paper towle and run the pump with water int he loop only. (No power to the PC) you can pick up a PSU jumper for like $10 & it will allow you to run your PSU with out being connected to other components. many users are against using dye based coolant, but I personally like it. But having a coolant that has all the corosive additives already is pretty nice, as you have nothing to worry about. This liquid recommends to be changed every 6 months so the upkeep is not that intense. If you have room you can get a nice 360 radiator to cool your GTX 480's or a 240 like mine that is rated for 900W. Going with a product that is rated to cool 900W max is more than enough. The SR-1 & the GTX240 are pretty close to being the same product. The only different is the SR-1 performs a bit better with lower airflow fans. When they are under heavy load the temps even out across the board. and the GTX240 was cheaper and in stock. As for the CPU, doing a water loop just for that is not a problem at all. Jacob posted in the 400 series forums saying their HC FTW card in office is running at 50C under full load in a 1/2 loop with a 360 radiator along with a CPU that is OC'ed in that same loop. which to me tells me my guess was about right with 60c for my current setup under load. Again I highly recommend Sidewinder as they were the best company I worked with in buying parts over this entire build. The owner also takes time to chat with you over the phone about your build and what is best.
post edited by sledgehammer70 - 2010/04/02 01:58:13
2010/03/30 09:59:23
2010/03/30 12:06:36
I'd just like to throw out there that distilled water by itself isn't conductive, so unless your water picks up conductive impurities (like salts) from your mobo / wc loop its going to be just as non-conductive as "non-conductive" solutions offered by various companies.
2010/03/30 12:17:36
zimbambadu I'd just like to throw out there that distilled water by itself isn't conductive, so unless your water picks up conductive impurities (like salts) from your mobo / wc loop its going to be just as non-conductive as "non-conductive" solutions offered by various companies. The conductive aspect isn't that big, but the chemicals needed to keep the coolant from going bad is what I like. Yes I know you can buy the stuff to mix in water, but to me I just do not like to do it.
2010/03/30 15:24:02
sledgehammer70 zimbambadu I'd just like to throw out there that distilled water by itself isn't conductive, so unless your water picks up conductive impurities (like salts) from your mobo / wc loop its going to be just as non-conductive as "non-conductive" solutions offered by various companies. The conductive aspect isn't that big, but the chemicals needed to keep the coolant from going bad is what I like. Yes I know you can buy the stuff to mix in water, but to me I just do not like to do it. Yeah, I hear that. Do you think that you could get away with doing this with one loop or would you always do two?
2010/03/30 15:28:40
I do not think 1 loop will cool 2 GTX 480's with the CPU & chipset. You can do dual radiator and maybe get away with it & that can save yo the money for a pump, res, and some tubing.
2010/03/30 16:26:39
sledgehammer70 I do not think 1 loop will cool 2 GTX 480's with the CPU & chipset. You can do dual radiator and maybe get away with it & that can save yo the money for a pump, res, and some tubing. Yeah, I didn't think so either. What I am trying to do is get the cpu, chipset and one gtx 480 for now, and I will expand later. I noticed you used a stealth 360 radiator, is there any reason why the GTX 360, also from black ice, wouldn't work for this? It seems like it should fit in the case, in the same location, just fine.
2010/03/30 16:48:56
I went with the GT stealth as it offered ports on the top and bottom. Which made less pipes needed. Overall going with this slime line cooler I have noticed warmer CPU temps than I would have gotten with the GTX or SR versions. Overall all 3 version would fit without any issues. I think I also like the idea of having more space in the case in the top area. 1 360 GTX or SR version will cool up to 1400watts of power so if you went with the GTX instead of the GT you could probably cool 2 GTX 480's and the CPU in one loop. Your going to need a good pump with high flow to pull it off, but it should in theory work.
post edited by sledgehammer70 - 2010/03/30 16:51:19
kotori
2010/03/30 20:03:42
Im unable to see where the other pump is located, are you using it right now or is it hidden somewhere?
Pentium777
2010/03/30 21:09:20
kotori Im unable to see where the other pump is located, are you using it right now or is it hidden somewhere? Yeah I was thinking the same thing, I looked at videos and pics just couldn't find the 2nd pump. Great videos except for darkness I guess the ambient light just isn't enough for filming. Thanks for putting those videos together. As I mentioned the big hangup I have right now is the fitting types and what fittings are needed. Also what do you think about that Fluid XP Nano stuff it is expensive @ $45 and I know most real modders will say it is an absolute waste of money (snake oil) here's a link http://fluidxp.com/index.php?option=com_content&task=section&id=26&Itemid=65 Some people just say straight distilled water, some say add this add that, a bit confusing for the first timer. I decided today with seeing the OCs on GTX 480 that investing the extra $300 (for Evga water blocked version cards SLI) and the approx $300 for WC setup was money that'll be decently invested and OC results were averaging 800mhz on air for the GTX 480 almost 15% increase so with temps lower on water might squeeze a few more mhz but on air they say the fans were like hairdryers. Most people are saying that a shrink will be required to get a higher end card out and that it'll be 6-12 months before we see a refresh of GTX 480 it seems it is pushing PCI-E 300W specs right now, thermal issues and technological issues. I'm looking on having these cards in SLI for a good 18-24 months so the higher I can push them the longer I'll get out of them. I'm thinking of doing the Black Ice SR1 240 (since it will fit inside the front of my case with HDD bays removed) along with your same reservoir, pump, tubes and fittings. I just don't know what kind of fitting adjustments I might need to make, I'll spend a few more $ to get the best / safest leak resistant fittings available. Another question I have is loop design is there a certain method of how the loop goes to what location first 2nd etc? I am sure there is a proper way to maximize the efficiency of the loop. Case Fans I've been researching and found that static pressure due to the depth of radiator is something to consider, so would a 120x120x38 be better than 120x120x25 since it is deeper and I think they generally have more static pressure? Right now I'm using Scythe 120mm SFF21F which is 28dBa @ 63.7CFM @ 1600RPM, I was thinking of switching to SilenX IXP-76-18 which is 18dBa @ 90CFM @ 1400RPM. Seems the Silenx moves quite a bit more air and is very noticably quieter, I'll be using 5 total, 1 for CPU HSF, 1 for rear exhaust, 2 for radiator, 1 for side intake of cool air. Thoughts on the fan choice? Found this review http://www.madshrimps.be/?action=getarticle&articID=936 if anyone has other reviews for radiator fans please PM or post. I am now thinking of using the Scythe 120x120x25 fans to do a push/pull (4 of them) on front and back of radiator however I can't find a picture of the back only the side with the inlet/outlet, does it have the capability (screw holes) for mounting on the other side? FYI you list your pump used for GPU as MCP665 however your link goes to MCP655 was this a typo? Swiftech's website doesn't list a MCP665 which is probably why I had trouble finding it around the net :-)
post edited by Pentium777 - 2010/03/31 00:32:40
2010/03/31 01:45:42
Yeah I was thinking the same thing, I looked at videos and pics just couldn't find the 2nd pump. The 2nd small pump is mounted to the bottom of the 5.25" drive bay it is the smaller of the 2 pumps so it was easily tucked away. Here is an image... Great videos except for darkness I guess the ambient light just isn't enough for filming. Thanks for putting those videos together. As I mentioned the big hangup I have right now is the fitting types and what fittings are needed. Also what do you think about that Fluid XP Nano stuff it is expensive @ $45 and I know most real modders will say it is an absolute waste of money (snake oil) here's a link http://fluidxp.com/index.php?option=com_content&task=section&id=26&Itemid=65 Honestly I picked the fluid i used based on reviews. I hear people say dye can clog blocks etc... but I just added the dye and let it sit for 2 days. the crap that can clog it up sinks to the bottom. I just didn't use the last 20%. But for my first clean out on coolant I have switch from a Dye to just a clear liquid from the same company. I just like having coolant that has all the stuff to keep the liquid clear & clean. For fittings regardless of the radiator you get, if you go with the same loop size (1/2" ID & 3/4" OD) you will get all the same parts I have listed. Overall Barbs vs. compression is a toss up. get good barbs like the ones form Bitspower or even fat boys and some clamps and you should be leak free. I like the look of compression fittings and honestly feel they are safer to use. Also they allow me to avoid using a T line, so when I drain my system I just undo an easy access compression fitting. Some people just say straight distilled water, some say add this add that, a bit confusing for the first timer. I decided today with seeing the OCs on GTX 480 that investing the extra $300 (for Evga water blocked version cards SLI) and the approx $300 for WC setup was money that'll be decently invested and OC results were averaging 800mhz on air for the GTX 480 almost 15% increase so with temps lower on water might squeeze a few more mhz but on air they say the fans were like hairdryers. Most people are saying that a shrink will be required to get a higher end card out and that it'll be 6-12 months before we see a refresh of GTX 480 it seems it is pushing PCI-E 300W specs right now, thermal issues and technological issues. I'm looking on having these cards in SLI for a good 18-24 months so the higher I can push them the longer I'll get out of them. I doubt Nvidia will be doing a shrink or re spin at this point. and in honesty I am not counting on it. They may release a 512 core part (GTX 485 or something) but I doubt we will see re spins of the higher end cards. Yes buying 2 GTX 480's HC FTW cards come at a price premium but in honesty they are the fastest single GPU board out there hands down. I'm thinking of doing the Black Ice SR1 240 (since it will fit inside the front of my case with HDD bays removed) along with your same reservoir, pump, tubes and fittings. I just don't know what kind of fitting adjustments I might need to make, I'll spend a few more $ to get the best / safest leak resistant fittings available. After talking with a few people at Hlabs.. the GT stealth will actually give better performance with good fans. the SR-1 was designed for low flow, hence the size of it compared to the stealth. Another question I have is loop design is there a certain method of how the loop goes to what location first 2nd etc? I am sure there is a proper way to maximize the efficiency of the loop. As far as loops go, I feel the longer they are the more fluid you have the longer it has to cool down. It never hurts to have a bit more tubing with good flow of liquid. It will only allow temps to drop a little more. Just depends on how clean of a look you want. But always take in mind.. just because your on water doesn't mean you do not need great airflow in the case. You need a good amount of cool air being sucked in to keep those radiators nice and cool. Case Fans I've been researching and found that static pressure due to the depth of radiator is something to consider, so would a 120x120x38 be better than 120x120x25 since it is deeper and I think they generally have more static pressure? Right now I'm using Scythe 120mm SFF21F which is 28dBa @ 63.7CFM @ 1600RPM, I was thinking of switching to SilenX IXP-76-18 which is 18dBa @ 90CFM @ 1400RPM. Seems the Silenx moves quite a bit more air and is very noticably quieter, I'll be using 5 total, 1 for CPU HSF, 1 for rear exhaust, 2 for radiator, 1 for side intake of cool air. Thoughts on the fan choice? Found this review http://www.madshrimps.be/?action=getarticle&articID=936 if anyone has other reviews for radiator fans please PM or post. I am now thinking of using the Scythe 120x120x25 fans to do a push/pull (4 of them) on front and back of radiator however I can't find a picture of the back only the side with the inlet/outlet, does it have the capability (screw holes) for mounting on the other side? If you go with the SR-1 you can get low RPM fans and get the same result as high CMF fans. It all depends on the goal you want... super quite or you can hear the fans. Either or know that the sound of the pumps will be there. and no matter what even with the Cooler master fans I got, it is never as loud as the GPU fan I once had... not even close. You heard int he videos how silent it got with the side panel off.. overall is it fairly silent. FYI you list your pump used for GPU as MCP665 however your link goes to MCP655 was this a typo? Swiftech's website doesn't list a MCP665 which is probably why I had trouble finding it around the net :-) I bought the pump from Sidewindercomputers.com I got the one with the speed adjustment Link: Swiftech MCP655 12v DC Pump - with Speed Controller http://www.sidewindercomputers.com/swmc12vdcpu.html
post edited by sledgehammer70 - 2010/04/02 02:00:47
2010/04/01 10:01:57
I went with the SR-1. Apparently it can handle fan speeds up to 2000 rpm. I'm not sure what this means exactly as RPM doesn't exactly equal CFM, but I think that I will go with lower RPM but higher CFM fans.
