More new Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts
pb680
2014/12/20 09:53:14 (permalink)
I have made some new changes after the ones list below. Trying to keep the wiring clean by using after market Individually wire ends 24 pin to motherboard and the ones to the video cards was not working. In trying to decide between the cost of ordering the wire, connectors, pins, tools and wire covering and EVGA Individually Sleeved Cable set, I ordered the EVGA set.
I would recommend this set to anyone looking for new cables. They are very well made and extra long that fit in my Cosmos II case with no problems.
I have added new pictures at the bottom.
Thanks for checking it out.
Hopefully the next add-on will be 16 gigs of memory and a second 780 Ti or and change to one of the new 900 cards.
I have added some new parts EVGA X99, INTEL 5280K Processor, 16 Gigs G.Skill Ripjaw Memory, EVGA 780 TI GPU, and a BENQ BL3200PT 32" 2560x1440 Monitor.
Thanks for looking
 Sorry do not what happened to the Images
post edited by pb680 - 2015/01/18 09:40:38
EVGA DG-87
MSI X99A Gaming Pro Carbon
INTEL CORE i7 5280K OC TO 4.5
16 gigs G.SKILL RIPJAW MEMORY
BENQ BL3200PT 32" MONITOR 2560X1440
CREATIVE SOUND BLASTER Z SERIES
LOGITECH Z906 5.1 500 WATT SPEAKERS
CORSAIR H100i COOLER PUSH/PULL SET UP
9 Replies Related Threads
    pb680
    Re: New Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts 2014/12/20 15:47:39 (permalink)
    Here are a few more.
    EVGA DG-87
    pb680
    Re: New Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts 2014/12/20 15:48:43 (permalink)
    And one more
    Thanks.
    EVGA DG-87
    • Ribbons : 282
    Re: New Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts 2014/12/20 16:26:01 (permalink)
    Nice +1, Tell us about that fan on the back of the CPU Socket!
    pb680
    Re: New Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts 2014/12/21 18:31:19 (permalink)
    Put fan on the backside of CPU socket because one day I was working on the case after having it on for a while and noticed the spot was hot. Using double sided tape put 3 pieces on the fan to get it off the back plate bracket for air to escape. Fan runs at about 1000 rpms and keeps the CPU about a degree or 2 cooler.
    EVGA DG-87
    • Ribbons : 282
    Re: New Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts 2014/12/21 19:20:28 (permalink)
    Thanks, that is what I was thinking.
    I have fans on all my X79 Rigs.
    The only issue I ever found with Corsair Cases at least for the 800D and 900D they have no vent on the back side to even put in a fan.
    I was pushing air on to the motherboard as you are doing but found it best to pull the air away from the motherboard.
    The fine dust collects and then stared to harden an cause more heat on the motherboard.
    post edited by bcavnaugh - 2014/12/21 19:28:09
    • Ribbons : 115
    Re: New Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts 2015/01/10 22:45:02 (permalink)
    Looks cool.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    pb680
    Re: New Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts 2015/01/18 09:22:28 (permalink)
    Here are some updated pictures.
    EVGA DG-87
    pb680
    Re: New Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts 2015/01/18 09:26:08 (permalink)
    And some more.
     Thanks for looking.
    EVGA DG-87
    Babyzone2
    Re: New Parts Cosmos II W/MNPCTECH Clear Side w/fan cutouts 2015/01/24 13:47:06 (permalink)
    a ha,  I have the same case with the same clear door from FrozenCPU. Nice and neat build you have there
    I7-3770K OC 4.7G @1.265V |Custom Watercooling Loop | 4x4G G-skill DDR3 2133 |Asus Maximus v Formula | 2xGTX 770 SLI With EK waterBlock | Creative Sound Blaster ZxR | 2 x Kingston Hyper X 3K 120G Raid 0 | Cool Master Cosmos II With Customized  Full Clear side Panel | 2x360, 2x 240 Radiators | Total 20 of Fans installed.
