Ragingidiot
Hi. I am building my first gaming PC and need help. I already bought the CPU - Intel i5 2500K. Everything else still needs to be bought. I am highly considering the EVGA X58 FTW3, though it is alittle more than I was hoping to spend.. I eventually want to run two GTX 570's so SLI is important. My question is- does the EVGA X58 FTW3 support i5? Thanks!
In Process- P8Z68,i52500K,8GBVENGEANCE,GTX580,AX850,IN WIN DRAGON RIDER.
KMoore4318
Pistoj Doulos Unum Pluribus
- Ribbons : 233
Re:Need help with my first gaming PC build.
2011/06/02 00:16:28
☄ Helpful
No ; look at your socket type and socket requirments when selecting a board. 1155 and 1366 are not the same, look at the P67.
post edited by KMoore4318 - 2011/06/02 00:21:11
Just clink Link to Register > My Affiliate Code:VTJPDC4OMB 1)965 V-8 E758(77)580 AX1200 2)980 NH-U12P-SE E761(77)2(980) AX1200 3)980X H-70 E770 (77)2(590) AX1200 4)980X H-70 E762(77)2(580) AX1200 5)920 EVGA Super Cooler E756(82)590 HX1000 6)680I 2(560-ti) HX1000W
2011/06/02 00:20:02
☄ Helpful
KMoore4318 No ; look at your socket type and socket requirments when selecting a board. What he's saying is that 2500K is a 1155 socket, so you would need to get a MOBO that is P67, H67, or Z68. NOT a x58. If you want an x58(which is still a great choice) you would need to get a 1366 socket CPU including but not limited to i7-950, i7-960, etc.
Ragingidiot
2011/06/02 00:21:31
Argh.. ok thanks. Do you have any suggenstions on a good motherboard for i5 that can sli two 570's?
KMoore4318
- Ribbons : 233
2011/06/02 00:22:36
☄ Helpful
Ragingidiot
2011/06/02 00:26:14
You guys are quick! Greatly appreciated!
2011/06/02 00:27:54
We're awesome :) The boards in the link is awesome, just released I think not long ago. Now you just have to choose between the FTW and the normal one
Ragingidiot
2011/06/02 00:48:00
My only problem now is that I was hoping to have my local Fry's electronics to make me a custom PC. Unfortunately they don't sell either of those boards... frustrating!
KMoore4318
- Ribbons : 233
2011/06/02 00:55:36
You do not want to pay fry's to build you a PC, as long as you can read instructions, and follow directions, building a system is not that complicated, a good part of the fun, and pride, is in the build, this is no different than a puzzle or model you wouldn't buy a box of lego's, and ask the store to put it together. This is a learning opportunity, learning to take advantage of your learning opportunities, and how to utilize the resources ( here ) and elsewhere is what determines where you end up. Fry's would have to pay me to let them assemble my PC. I would only consider that option , if I had a better use for my time, that paid more. IF you have any questions during your build, just ask.
post edited by KMoore4318 - 2011/06/02 00:59:33
Ragingidiot
2011/06/02 00:58:15
You make a great point and part of me wants to build it myself. The bonus I see from having them build it is they would hopefully give it to me working.. if they use a part and it doesn't work they use another. If i build it myself and something goes wrong... first I wouldn't know what wasn't working, and secondly I would have to wait for a return in the mail.
loveha
- Ribbons : 53
2011/06/02 00:59:18
Building them is not hard and self satisfying. If you have any sort of do it your self skills then I would suggest doing it your self. Helps get to know how a computer works and when something goes wrong you aren't forking over money to someone to diagnose it. Plenty of us here will help you with that for free. It may seem like a daunting task when you first start out but in no time you will have the ability to build a computer strip it back down and put it all back together again in an hour. Not that you would have to do that for any reason. Just saying I will never take my computer to get fixed by anyone ever. When I started, only thing I could do was add another HDD. Look at my rig now...
Case: Corsair 900DMotherboard: EVGA Z170 Classified E179CPU: Intel Core i7 6700K 4.6GHzRAM: 16GB Corsair DDR4 2133 16-15-15-36GPU: EVGA GTX 1070 FTW DT SLIPSU: EVGA 1000w G2SSD: Samsung 512GB 950 Pro NVME M.2Monitor: Acer Predator X34 100Hz G-SyncSound: Schiit Modi 2 DAC~Schiit Vali 2 AmpHeadphones: AKG K7XX Massdrop Edition
loveha
- Ribbons : 53
2011/06/02 01:04:30
Ragingidiot You make a great point and part of me wants to build it myself. The bonus I see from having them build it is they would hopefully give it to me working.. if they use a part and it doesn't work they use another. If i build it myself and something goes wrong... first I wouldn't know what wasn't working, and secondly I would have to wait for a return in the mail. Then you come here give us your list of computer parts and tell us exactly what is happening. Even if it is, "My Computer will not turn on." there is always a place to start, such as, are there LED's lit up on the motherboard, or do the fans spin up, is there a post code, etc... As far as parts go, we can recommend everything that is compatible like the above Motherboard Compatibility. Now we can't prevent DOA parts when they get to your door step. EVGA and Corsair are two good company's when it comes to RMA's though so highly suggest getting as much from them as possible.
KMoore4318
- Ribbons : 233
2011/06/02 01:06:08
If the mail return thing bothers you look to see if there is a Microcenter in your area, or buy parts from fryes, you usually have a 30 day exchange at brick and mortar storers. Companies like New egg, will generally provide pre paid shipping labels, if you know to ask, The knowledge the people in this form, is typically far better than the guy standing behind the counter at fry's or best buy's, and you always have EVGA's 24/7 tech support just a phone call away at 888-881-EVGA ( 3842)
Ragingidiot
2011/06/02 01:11:39
Yeah I ordered the i5 2500k Today from Fry's. I like the EVGA P67 FTW , I just can't find a list of compatible memory.
loveha
- Ribbons : 53
2011/06/02 01:14:14
☄ Helpful
Ragingidiot Yeah I ordered the i5 2500k Today from Fry's. I like the EVGA P67 FTW , I just can't find a list of compatible memory. Just about any DDR3 RAM which is 1600MHz+ from Corsair, G Skill, or Mushkin with a voltage of 1.5v. Not very descriptive but the whole compatibility list thing is a bunch of bull if you ask me. I have seen cases where RAM on that list doesn't work for some people, but works for others. DDR3 RAM is DDR3 RAM.
KMoore4318
- Ribbons : 233
2011/06/02 01:16:47
☄ Helpful
4 DIMM Dual-Channel DDR3 1333MHz+ (up to 16GB) Get at least 1600 rated memory,( if you plan on Over clocking ) stick with names you know and trust , Mushkin, corsair, ... , look for memory rated 1.65 volts or below, if you plan on running at stock speeds any 1060 or 1333 memory should work, and would be 1.5 V buying 1600 memory even if you plan on ruining at 1060, or 1333 would be fine, and save you from having to double spend later if you decide to over clock down the road, just as buying too much power supply will save you should you latter decide you want to change GPU's, or SLI.
post edited by KMoore4318 - 2011/06/02 01:22:44
Ragingidiot
2011/06/02 01:23:48
Seems like the EVGA P67 SLI is the only one released thats from that link. Amazon seems to be the only place too.. says 5 left in stock. How much RAM should I aim for? I was originally hoping to do 2 - 4gb's for 8 total... but on every 1155 sockett board seems to do in 2's. So 4 or 6gb seem like the options... Again i was hoping for 8 I definitely want to sli in the future, but start with one 570 GPU.
KMoore4318
- Ribbons : 233
2011/06/02 01:27:34
☄ Helpful
Buying from EVGA is an option as well, and would save you taxes, unless you live in calafornia, plus you do not have to save or submit reciets to actavite the warranty as they already have it on file, although you would still have to regester, look at the top of this page under products, select motherboard, and the P67.
KMoore4318
- Ribbons : 233
2011/06/02 01:30:47
☄ Helpful
Buying from EVGA is an option as well, and would save you taxes, unless you live in calafornia, plus you do not have to save or submit reciets to actavite the warranty as they already have it on file, although you would still have to regester, look at the top of this page under products, select motherboard, and the P67. with 4 slots on your board, I would go with 4 2G sticks for 8G unless you fear that might not be enough, in which case I would buy 2 4G sticks and just populate the red slots, to allow future options. 8G will be more than enough, most of the people here running triple chanel have found 6G more than suffecent. If you are going to run more than 4G make sure you get the 64 bit version of windows.
post edited by KMoore4318 - 2011/06/02 01:41:26
Ragingidiot
2011/06/02 01:38:17
True, I am very tempted to take the plunge and buy from EVGA. The one thing causing pause is lack of reviews.. I can't find any. I want to run games very well. Current ones like Witcher 2,Shogun 2, Civ 5 and Battlefield 3, Skyrim in the fall. Lets say my foundation so far is EVGA P67 SLI Intel i5 2500K GTX 570
Ragingidiot
2011/06/02 01:42:11
Every 1155 board I have checked for memory that is compatible there is no two 4gb stick options for 1600. Thats what I want... but only see options in the amounts of 2's.... Don't really get that.
loveha
- Ribbons : 53
2011/06/02 01:42:25
☄ Helpful
Ragingidiot True, I am very tempted to take the plunge and buy from EVGA. The one thing causing pause is lack of reviews.. I can't find any. Still any suggenstions on particular ram amounts DDR3 1600 - ? 4gb 6gb? I want to run games very well. Current ones like Witcher 2,Shogun 2, Civ 5 and Battlefield 3, Skyrim in the fall. Lets say my foundation so far is EVGA P67 SLI Intel i5 2500K GTX 570 4GB Should be enough for most people. 8 if you want to be safe. 6GB is most likely with X58 in mind running 3 sticks. you want 2 or 4 sticks for your Motherboard and you won't be running your RAM in Dual Channel. This RAM here seems to be popular for the P67 lineup. Not to crazy on the timings but they aren't terrible. They are average but it's still good RAM. http://www.newegg.com/Pro...x?Item=N82E16820233144 Edit-here is a better set with better Timings More expensive though. http://www.newegg.com/Pro...x?Item=N82E16820226203 With the lack of reviews thing, EVGA just released there boards last week. I wouldn't worry about it though. They make quality stuff. I'll Buy EVGA until there policy on RMA's Change or there quality goes into the dump.
post edited by loveha - 2011/06/02 01:49:09
KMoore4318
- Ribbons : 233
2011/06/02 01:49:07
☄ Helpful
Ragingidiot
2011/06/02 01:51:18
I definitely am thinking 850W as my minimum. I don't wan't to have to rebuy in the near future. How about this ram? It is available at my local Fry's which is a plus. The more parts I can buy locally the better. I want to deal with shipping as less as possible the CPU, and Board are for sure shipping. I think I can get the rest local. http://www.frys.com/produ...sr:SEARCH:MAIN_RSLT_PG
Johhny Doe
2011/06/02 01:54:27
☄ Helpful
KMoore4318
- Ribbons : 233
2011/06/02 01:59:58
The high heat spreders may give you issues depending on the cooler you select , case latency of 9 is acceptable, but 6 would give you more performance. see if they also have http://www.mushkin.com/Memory/Redline/996805.aspx the lower latency and low profile may make things easier, but if you go with a modest cooler, spreader height would not be an issue.
loveha
- Ribbons : 53
2011/06/02 02:02:34
Johhny Doe lovehaThis RAM here seems to be popular for the P67 lineup. Not to crazy on the timings but they aren't terrible. They are average but it's still good RAM. http://www.newegg.com/Pro...x?Item=N82E16820233144 Edit-here is a better set with better Timings More expensive though. http://www.newegg.com/Pro...x?Item=N82E16820226203 I wouldn't consider Corsair make IC's good, they're just cheap. The Redlines are pretty good, Elpida BBSE chips. They look great as well. Whatever happend to Corsairs really good stuff? I am running a kit of Dominator GT 1600MHz 7-7-7-20. My wallet didn't like it either, that was like a year ago or more. Stuff like that doesn't exist from them anymore....
Ragingidiot
2011/06/02 02:09:56
Johhny Doe
2011/06/02 02:11:48
lovehaWhatever happend to Corsairs really good stuff? I am running a kit of Dominator GT 1600MHz 7-7-7-20. My wallet didn't like it either, that was like a year ago or more. Stuff like that doesn't exist from them anymore.... Elpida's Hyper chips used in SuperTalent, Dominator GT, Perfect Storms and such were discontinued a year ago. They were being too expensive to bin so they left us with lower end chips like Microns. I ordered 2 sets of Hypers, and found 2 more Perfect Storms to order from eBay. Going to bin them myself on a DDR3 mobo, guess how much 16 GB of DDR3 2200 CL8 costs... Those Dominators are CL9, I'd go for the Redlines. As for the PSU, can't go wrong with this one. http://www.newegg.com/Pro...x?Item=N82E16817703022
post edited by Johhny Doe - 2011/06/02 02:25:02
2011/06/02 02:37:46
Sorry if I didn't read through all the posts, but why aren't you buying online again? Fry's doesn't have all the varieties to choose from. From the memory brands that they offer, it seems that Corsair is the only good one. So I would go with 2x4GB Dominators or the 2x4GB Vengences, since I think you said you wanted 8GB, its either 8 or 4
post edited by Xtrem - 2011/06/02 02:43:26
