AnsweredNeed help connecting PSU To EVGA GeForce GTX 1060 SSC
Joojojook
2016/10/25 19:35:53 (permalink)
I'm a bit of a nooby and I need some help giving power to my new EVGA GeForce GTX 1060 SSC. Here are my specs for my mobo, gpu and PSU:
Motherboard: Asus z170-p
Graphics card:  EVGA GeForce GTX 1060 SSC
Power Supply Unit:  SeaSonic S12II 520 Bronze 520W
So my issues is this, on the GPU I have an 8pin PCI-Express port and on my PSU I also have 8 pins. I was only provided an 8pn to 2 6pins PCI-Express with the 1060 (refer to bottom picture as reference).
 I tried connecting the PSU to gpu using an 8 pin to 6+2pin PCIE however, it doesn't seem to have enough power.
Any suggestions? I would appreciate all the help!
  • Ribbons : 122
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 19:39:56 (permalink)
No need to use the adapter. The 6+2 from your psu is all you need. Is the card not working after plugging in the 6+2 from the psu?
Joojojook
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 19:42:50 (permalink)
So, I tried using the 6+2 pin. But I noticed that on the 8pin end it only had 6 pin (2 of the holes were hollowed). I connected the 6+2 side to my GPU and the 8pin to my PSU, my card turns on sure (the logo glows), but the fan just kind of flickers. Like rotates very slightly and then stops. It then it does this again and again.
My main issue is that I'm connecting my monitor to my GPU (not connected to mobo because of the lack of dp port on the mobo) and there is no signal. If you need more pictures I will happily take them!
Edit: format + grammar errors
post edited by Joojojook - 2016/10/25 20:01:10
  • Ribbons : 122
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 19:47:53 (permalink)
The fans on the gpu won't run until the card gets above 60c. The fan flickering is normal. To help try and resolve the black screen try updating your motherboard bios to the latest version using another video card/igpu. After updating the motherboard bios to the latest version retry the 1060.
Joojojook
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 19:49:19 (permalink)
The fans on the gpu won't run until the card gets above 60c. The flickering is normal. To help try and resolve the black screen try updating your motherboard bios to the latest version using another video card/igpu. After updating the motherboard bios to the latest version retry the 1060.
Oh really? Man I was so worried lol. So, why is the fan just moving slowly by its own though? I will buy a connecto to link my mobo to my monitor in order to update everything.
  • Ribbons : 122
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 19:53:49 (permalink)
Joojojook
Looks like this right?
Joojojook
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 19:58:45 (permalink)
Joojojook
Looks like right?
Yup! Is that normal? If it is, is there anyway for me to test that the power to the GPU is enough? Or do I have to update the MOBO and then test it by connecting my monitor to the gpu?
  • Ribbons : 122
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 20:00:57 (permalink) ☼ Best Answerby Joojojook 2016/10/25 20:01:37
Yeah, the twitching is normal, see here for more info. The gpu is definitely getting enough power. Yes, you need to update your motherboard bios to the latest version then retest the 1060 by connecting your monitor to it.
Joojojook
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 20:01:59 (permalink)
Yeah, the twitching is normal, see for more info. The gpu is definitely getting enough power. Yes, you need to update your motherboard bios to the latest version then retest the 1060 by connecting your monitor to it.
Very nice. Thanks a lot, I was really worried there!
  • Ribbons : 122
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 20:05:21 (permalink) ☄ Helpfulby Joojojook 2016/10/26 15:46:01
Joojojook
No problem. Report back and let me know if updating your motherboard bios helps get you up and running.
Joojojook
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/25 20:08:30 (permalink)
Joojojook
Defiantly! You've been very helpful on this thanks again dude!
ArmeniusLOD
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/26 11:12:33 (permalink) ☄ Helpfulby Joojojook 2016/10/26 15:45:23
Just so you're aware:  if you have a dedicated video card like you do now you always want to plug your primary monitor into it.  If you plug it into the motherboard then the games you run will be using the integrated GPU instead of the video card.
Joojojook
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/26 15:45:54 (permalink)
ArmeniusLOD
Hm. I will defiantly do that. But what about the case if I have 2 monitors?
  • Ribbons : 122
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/26 18:21:59 (permalink)
Joojojook
ArmeniusLOD
Both monitors will need to be plugged into the video card.
NucleusX
Re: Need help connecting PSU To EVGA GeForce GTX 1060 SSC 2016/10/26 18:55:52 (permalink)
By the way, if you update your Bios on the motherboard, it will reset all settings to default, and usually it
will default to on-board or iGPU. If you turn your system on after the update and get a black screen, you'll
need to temporarily reconnect to the onboard port, go back into the Bios, and set the PCI-E slot as your
primary display adapter. Save, exit, reconnect back to dGPU or 1060, black screen gone.
CPU:  Intel 486 DX2. 66Mhz (Turbo). Cooling: LN2.
MTB: ECS. Chipset: SIS. HD: WD Raptor 300mb x 512. 154GB. Raid 0.
RAM: Corsair Obliterator Gold. EDO. 16mb. 66mhz. x8.
GPU:  Nvidia GTX Riva TNT2 FTW OC. PCI. 32mb. x4 Quad SLI.
PSU:  ATX 200 watt (no label). Case: RGB Milk Crate.
