Need advice on sound card option
XeroHertZ
2014/10/15 21:49:16 (permalink)
Hi all,
So I've decided to go for an Asus Rampage V Extreme mobo for my x99 build, but wanted to know should I get a dedicated sound card or the built in mobo sound will do?? and if I should get one which one do you recommend?
Thanks in advance :)
Case: Corsair 750D
Motherboard: Asus Rampage V Extreme
CPU: Intel Haswell-E 5960x @ 4.4Ghz
Memory: Mushkin Redline DDR4 16GB (4x4GB) 13-13-13-35
GPU's: 2x EVGA GTX 980 SC's
Sound Card: Soundblaster X-Fi Titanium Fatality Champion Series
CPU Cooling: Corsair HX110i Liquid Cooling
Storage1: Mushkin Scorpion 240GB PciE SSD
Storage2: Samsung 840 EVO 1TB
Storage3: 2TB WD Caviar Black
Power Supply: Corsair AX1200i
Speaker: Logitech Z-5500
3DMark Benchmark: http://www.3dmark.com/fs/3410236
31 Replies Related Threads
    dave851
    Re: Need advice on sound card option 2014/10/16 00:21:55 (permalink)
    Well sound cards are totally personal preference. I would use it as is and if your not happy with you can always add in a sound card later.
    XeroHertZ
    Re: Need advice on sound card option 2014/10/16 00:32:32 (permalink)
    dave851
    Good point...will try onboard sound first and see how good it is if not will add a sound card later on.
    Case: Corsair 750D
    bob16314
    • Ribbons : 761
    Re: Need advice on sound card option 2014/10/16 00:55:46 (permalink)
    I think you'd probably be very happy using quality headphones/speakers with the onboard ROG SupremeFX 8-Channel High Definition Audio..That board comes with the software to fully manage/unlock the onboard audio potential which include:
    - Sonic SoundStage
    - Sonic SenseAmp
    - Sonic Studio
    - Sonic Radar II
    I'd be inclined to stick with the high-quality onboard..Just my opinion.
    XeroHertZ
    Re: Need advice on sound card option 2014/10/16 01:01:07 (permalink)
    bob16314
    - Sonic SoundStage
    - Sonic SenseAmp
    - Sonic Studio
    - Sonic Radar II
    Nice !! So it will be perfect with my Logitech Z-5500's??
    Case: Corsair 750D
    bob16314
    • Ribbons : 761
    Re: Need advice on sound card option 2014/10/16 01:16:38 (permalink)
    SpeedMax
    Undoubtedly.
    XeroHertZ
    Re: Need advice on sound card option 2014/10/16 01:29:03 (permalink)
    bob16314
    SpeedMax
    Undoubtedly.
    Great...that's a relief.
    Thanks bob :)
    Case: Corsair 750D
    boredgunner
    Over 9000!
    • Ribbons : 79
    Re: Need advice on sound card option 2014/10/16 17:52:44 (permalink)
    You won't need a sound card with Logitech speakers.
    • Ribbons : 115
    Re: Need advice on sound card option 2014/10/16 22:56:36 (permalink)
    I would rather have a card, than have to rely on onboard sound.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    SirJamesDTech
    • Ribbons : 46
    Re: Need advice on sound card option 2014/10/17 19:42:15 (permalink)
    If you decide to get a sound card, like Bob mentioned above make sure you get great headphones at some point.
    The Audio-Technica ATH-M50X pair I got with the FiiO amplifier are jaw dropping with the Sound Blaster Z...or comparable sound card.
    Asus Maximus VII Hero Z97 | i7-4790K Devil's Canyon @ 4.4GHz | Corsair H105 | EVGA GTX 1080 Ti SC2 | Samsung 850 Pro 256GB, Samsung 840 EVO 1TB, SanDisk Ultra II 480 GB SSD | 16GB Dominator GT DDR3 2000 @ 2400 | EVGA 850W G2 Full Modular | Acer Predator 27" IPS 1440p 144Hz G-Sync | Creative Sound Blaster Z | Audio-Technica ATH-M50X Headphones | Razer Blackwidow Chroma RGB Mechanical Keyboard | Corsair 760T Full Tower
    XeroHertZ
    Re: Need advice on sound card option 2014/10/18 21:09:01 (permalink)
    Thanks for the replies guys...the opinions are contradicting
    Guess i'll try with onboard sound first if I'm not satisfied i'll install my current X-Fi, no need to purchase a new soundcard
    Case: Corsair 750D
    XeroHertZ
    Re: Need advice on sound card option 2014/10/18 21:10:16 (permalink)
    SirJamesDTech
    I usually don't game with headphones, i'm satisfied with gaming on my Logitech Z5500 speakers :)
    Case: Corsair 750D
    • Ribbons : 115
    Re: Need advice on sound card option 2014/10/18 21:12:33 (permalink)
    My Creative X-Fi sound card plays well together with my Z5500's.
     &nbsp
    sleevo
    Re: Need advice on sound card option 2014/10/18 21:14:16 (permalink)
    SirJamesDTech
    I also have the Audio-Technica ATH-M50 headphones plus sound blaster Z. Way better then onboard imo.
    I'm using the Logitech Z -2300's speakers.
    post edited by sleevo - 2014/10/18 21:18:35
    CASE - Corsair Graphite Series 760T White
    CPU - Intel
    Devil's Canyon Core i7-4790K @ 4.7GHz 1.265v
    CPU Cooler - Noctua NH-U12S push & pull
    MB - Gigabyte GA-Z97X-UD5H- Black Edition
    MEMORY - Corsair Dominator Platinum 2400 16GB
    GRAPHICS - EVGA GTX 1080Ti FE
    SSD - Samsung 850 Pro Series 512GB SSD
    HD - WD Black Series 2TB
    SOUND -Sound Blaster Z
    PSU - EVGA SuperNova 1000 G2 PSU
    MONITOR - Dell S2716DG 2560x1440 @144Hz G-Sync
    Windows 10
    XeroHertZ
    Re: Need advice on sound card option 2014/10/18 21:21:33 (permalink)
    Same here...mine has the front I/O panel as well, I guess i'll eliminate it in the new build as I don't want any mess inside with the cabling.
    Case: Corsair 750D
    • Ribbons : 115
    Re: Need advice on sound card option 2014/10/18 21:38:24 (permalink)
    SpeedMax
    I have the front I/O panel as well. I'm not getting rid of it. No way. It's too convenient for me. The cables aren't in the way in my case.     =)
     &nbsp
    XeroHertZ
    Re: Need advice on sound card option 2014/10/18 22:11:59 (permalink)
    SpeedMax
    It actually is very convenient for me too, maybe with the new case (Corsair 800D) and motherboard the cables won't be in the way...
    Case: Corsair 750D
    • Ribbons : 115
    Re: Need advice on sound card option 2014/10/18 22:27:53 (permalink)
    SpeedMax
    SpeedMax
    Here's to hoping it works out just fine...
     &nbsp
    XeroHertZ
    Re: Need advice on sound card option 2014/10/18 22:29:30 (permalink)
    SpeedMax
    SpeedMax
    Thanks XrayMan ;)
    Case: Corsair 750D
    seth89
    • Ribbons : 14
    Re: Need advice on sound card option 2014/10/20 20:39:23 (permalink)
    Option one:
    Use your sound card as a Pre-amp. Run directly from your card to a 5 channel amp and a sub.
    Option two:
    Use the on board digital out (RCA or Optical) to a surround sound receiver. This bypasses the computer DAC and processor and will let the external stereo equipment deal with it.
    Option three:
    Use the on board sound card if you're only connecting directly to a set of computer speakers or computer surround sound speaker set.
    Number one sounds the best BTW. Every channel gets its own dedicated pathway with no compression or conversion. there's an audible difference too.
    XeroHertZ
    Re: Need advice on sound card option 2014/10/20 21:28:16 (permalink)
    seth89
    Option one:
    Option two:
    Option three:
    Thank you seth89 for the detailed info, very much appreciated.
    Case: Corsair 750D
    RainStryke
    The Advocate
    • Ribbons : 60
    Re: Need advice on sound card option 2014/10/21 03:04:03 (permalink)
    With the upgraded built in audio on that board, not sure why you would want a sound card.
    Main PC | Secondary PC
    Intel i9 10900K | Intel i7 9700K
    MSI MEG Z490 ACE | Gigabyte Aorus Z390 Master
    ASUS TUF RTX 3090 | NVIDIA RTX 2070 Super
    32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17
    SuperFlower Platinum SE 1200w | Seasonic X-1250
    Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GB
    Cougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5
    3DMark Results:Time Spy|Port Royal
    XeroHertZ
    Re: Need advice on sound card option 2014/10/21 21:12:05 (permalink)
    RainStryke
    lol you made me more confused...heheheh
    I'm done..I think i'll just install the X-Fi from my current build to be on the safe side !!
    Case: Corsair 750D
    #23
    • Ribbons : 115
    Re: Need advice on sound card option 2014/10/21 21:23:31 (permalink)
    SpeedMax
    RainStryke
    That would be my suggestion too.
     &nbsp
    #24
    XeroHertZ
    Re: Need advice on sound card option 2014/10/21 21:27:08 (permalink)
    SpeedMax
    RainStryke
    Great...Thanks Xray :)
    Damn I've never been so excited for a build such as this one !! Will have it soon on my Mods Rigs
    Case: Corsair 750D
    #25
    RainStryke
    The Advocate
    • Ribbons : 60
    Re: Need advice on sound card option 2014/10/21 23:55:40 (permalink)
    You basically have a sound card built onto your motherboard.
    There are specs pulled directly from Asus's website:
    ROG SupremeFX 8-Channel High Definition Audio CODEC
    - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
    - SupremeFX Shielding Technology
    - ELNA® premium audio capacitors
    Audio Feature :
    - Blu-ray audio layer Content Protection
    - DTS Connect
    - Optical S/PDIF out port(s) at back panel
    - Sonic SoundStage
    - Sonic SenseAmp
    - Sonic Studio
    - Sonic Radar II
    Source:
    http://www.asus.com/us/Mo...XTREME/specifications/
    #26
    SirJamesDTech
    • Ribbons : 46
    Re: Need advice on sound card option 2014/10/22 14:30:05 (permalink)
    Correct me if I'm wrong, but aren't there issues with the ROG onboard audio and the toslink connection to surround speakers?
    I spent a few nights trying to get my Z-5500s to jive with SupremeFX 2014 and I could only get the analog to function. Not saying others wouldn't have better luck, but just seems like an extra PITA especially when IMO a sound card just plain sounds better...even though yes onboard has come a long way.
    #27
    XeroHertZ
    Re: Need advice on sound card option 2014/10/22 21:02:58 (permalink)
    RainStryke
    Audio Feature :
    - DTS Connect
    - Sonic SoundStage
    - Sonic SenseAmp
    - Sonic Studio
    - Sonic Radar II
    Source:
    Thanks for the info, RainStryke..appreciated :)
    Case: Corsair 750D
    #28
    XeroHertZ
    Re: Need advice on sound card option 2014/10/22 21:06:50 (permalink)
    SirJamesDTech
    I've heard about such issues as well...and another thing that keeps me away from onboard sound is that I got used to the creative software.
    I keep asking myself..should I keep the X-Fi for my old rig and buy a new card, let's say Soundblaster Z or just use the X-Fi?
    Edit: I just read that people still prefer the X-Fi over the Soundblaster Z modules as there are some issues with them.
    post edited by SpeedMax - 2014/10/22 21:13:48
    Case: Corsair 750D
    #29
    RainStryke
    The Advocate
    • Ribbons : 60
    Re: Need advice on sound card option 2014/10/22 23:06:29 (permalink)
    Asus Xonar cards are not bad at all. Those are also worth looking at.
    http://www.asus.com/Sound_Cards/
    #30
