Re: Need Some Monitor Help.
2016/09/30 10:33:18
The concern I would have is that going from an overlord to one of the 4k models you will see a big drop in refresh rate. And since you have a 900 series you can't go [link=mailto:4k@120]4k@120[/link]. What model of Overlord do you have? If it is a 60 Hz model you will be fine with 4k, otherwise you might want to stay with 1440p @ 120+Hz, as many people find it VERY hard to go back after having a high refresh for a while.
