Need Help for the ULTIMATE of ULTIMATE SR-2 Builds
Page: << < ..678 > Showing page 6 of 8
Halo_003
  • Ribbons : 50
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/11 21:19:21 (permalink)
andrewrp
The PSU is snug. There is not chance this will move!
I got my 56k modem today!
I will order the xeon x5690 when it comes out on Mon.
Nice!
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/12 15:01:50 (permalink)
Well, I don't think I really need that modem with my internet:
YES Virginia, that is in MBPS!
I am torn on what graphics card to use:
v9800- triple monitor support, powerful, but pricy
v8800- triple monitor support, not pricy, not as powerful
quadro 5000 - ? Opinions, anyone?
quadro 6000 - ? Opinions, anyone?
Halo_003
  • Ribbons : 50
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/12 15:10:59 (permalink)
Is there a reason you're looking at workstation cards?
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/12 15:14:03 (permalink)
I do graphic design, Photoshop, small cad, video editing, multimedia. My needs are from light to medium, I am NOT rendering for Disney!
Halo_003
  • Ribbons : 50
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/12 17:43:15 (permalink)
Well I would go for 580s then, but that's just me. Otherwise, the best Quadro card. Being the Quadro 6000 I believe.
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/12 18:51:26 (permalink)
580? You mean the nvidia gaming card?
Halo_003
  • Ribbons : 50
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/12 19:26:24 (permalink)
Yeah, they'll do Photoshop etc fine, and I assume they render quite well on CAD, but I don't know for sure.
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/12 19:30:22 (permalink)
But how many of them do l I need to run 3 monitors?
I am not looking to game.
BigRat
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/12 19:42:13 (permalink)
One is better than enough if you're going to do 3 displays. Because workstation cards don't need an extreme clock configuration unlike gaming cards to run multiple monitors. If you got enough cash, try 2 for a safer side.
Quick! Edit the Wiki!
769Y2OO3T5 <--Use this code when registering!
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/13 06:33:41 (permalink)
OK.
I really don't have the money to spend for 2 $3000 graphics cards.
How do the quadros game?
I really only need the v9800 for
Photo Editing
Video Rendering and Editing
HD Video Playback
Graphic Design
LIGHT gaming.
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/13 06:40:26 (permalink)
These blocks seem better and are more expensive (but are on SALE!):
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=27631.
What do you think?
3n1gma
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/13 06:51:14 (permalink)
andrewrp
What do you think?
Personally I doubt there's significant difference in performance between the gold and the basic version. Mine is hidden inside the case so no time for me to admire its beauty :) However if you can afford it (as it's on sale) you probably should get it.
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/13 09:52:27 (permalink)
I am looking at the strider and the sr-2 manual. It seems the sr2 needs 2 8 pin cpu connectors, but the strider has only 1! What can I do? Is there an adapet I can buy?
Mac_vista64
  • Ribbons : 9
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/13 10:13:02 (permalink)
Even the $700 Quadro 4000 + Mercury Engine makes a big difference. Can't say how that compares to a GTX 580 (except you only save $200).
Processor: Core i5 3570 @ 3.78GHz OS: Windows 8 HDD: WD 1TB Samsung 840
Memory: Corsair DDR3 2526GB 1600MHz Graphic: eVGA GTX 460 1GB Monitor: HP ZR24w
Halo_003
  • Ribbons : 50
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/13 10:15:46 (permalink)
With regard to the block, if you like the gold look better than Nickle, go for it. I liked nickle when I bought mine, and I still love the way it looks.
andrewrp
As for adapters, not sure. You can get a smaller PSU to help with it though. i.e. a Corsair AX750.
CodePhoenix
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/13 13:49:57 (permalink)
Yes, you can get PCIe 8pin power to EPS12V power adapters. This is a much better idea than a second PSU; dual PSUs only become necessary if you plan on running more than two 250W+ video cards.
Halo_003
  • Ribbons : 50
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/15 22:22:18 (permalink)
Wait you don't need an adapter. These are the connectors supplied with the ST 1500.
1 x Main connector (20+4Pin)
1 x 8 / 4-Pin EPS / ATX 12V
1 x 8-Pin EPS 12V
12 x Peripheral
12 x SATA
4 x Floppy
8 x PCI-E
Regarding SSDs, if I were you I would get a Revodrive X2.
texinga
  • Ribbons : 20
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 04:19:09 (permalink)
Just watch your pin-out in whatever you find to compensate for only getting 1 8-pin CPU power cable.  I've read of people that have found it fairly easy to put a "round peg in a square hole" with these power plugs.
Here's a website that I have found very valuable when it comes to PC cables information of all types:
http://www.playtool.com/p...nectors.html#eps4plus4
Rick
Halo_003
  • Ribbons : 50
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 09:28:18 (permalink)
texinga
Rick
I have as well, but the ST1500 has two of the CPU 8 pin(EPS) connectors, so it's not a problem.
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 09:40:32 (permalink)
I checked and the power supply fits!
I purchased the cpu,
Water cooling
Coller master and kaze rad fans
Crucial ssd 6gbps!
2x 1tb caviar black.
I think I will get the v8800 and an hp 30 inch monitor.
texinga
  • Ribbons : 20
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 09:58:49 (permalink)
I really love the HP 30" monitor (the ZR30w) and totally appreciate the screen real estate having come from an HP 2335 (23") monitor.
Rick
Halo_003
  • Ribbons : 50
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 10:06:33 (permalink)
Personally I would go for a Dell UltraSharp 30", but that's just my preference. I haven't heard anything bad about the HP though.
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 10:06:52 (permalink)
Those are the $1000 ones, right?
Are there any better models?
How does the scaling work with the bios?
Does it have tilt, swivel?
Can you give me the dimensions, I'd lke to have 3 in a semicircle around my desk.
How is the color quality?
Halo_003
  • Ribbons : 50
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 10:22:45 (permalink)
I don't have a 30" Dell, so I can only base my opinion on what I've seen others say...
I believe they are more like $1500 each, not sure. Might be more like $1300.
Unsure what you mean about the bios..
Tilt and swivel, I know for a fact the 27" does, so the 30" should.
It's about 30" wide for the actual screen, so figure around 31"-32" total width.
Color quality is absolutely superb, it's an IPS panel, capable of 1.07 billion colors as opposed to a regular pan with 16.7 million colors.
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 10:30:15 (permalink)
So the color quality is great on the hp?
I don't think the hp had internal circuitry.
A plus since there is almost no input lag (I think!)
But I am not sure about the bios optons (since they are low resolution and not native) or other displays that do not operate at native resolution since the hp has no scaling.
It also does not have an osd for options.
texinga
  • Ribbons : 20
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 11:31:08 (permalink)
Check out the reviews (on-line written and you-tube) for the ZR30w and you will see that it is a great monitor.  Of course as is with many monitors, if you are a graphic artist, etc, you would be using hardware/software tools to fine-adjust colors to your needs anyway.  The ZR30w is a very solid monitor and has held up very well in reviews.  I first heard about the ZR30w when MaximumPC chose 3 of them to be part of their annual Ultimate Build PC (the SR-2 was included in that build too).
The actual monitor used in the HP ZR30w is made by LG, but HP adds some better connectivity to the rear than LG's 30" product offering.  Dell doesn't make their own monitors either, so either way (HP or Dell), you want to look past the big-company names and peer into who is making the internal LCD.  At times, HP and Dell have used the same internals, so whatever you do don't get hung-up on the company names (Dell or HP).  I have used professional series HP monitors for years and have always been happy.
Rick
3n1gma
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/16 15:44:51 (permalink)
You may consider the NEC PA Series LCD if you are looking for a pro monitor http://www.necdisplay.com...4f55-a29c-ad0fbdf58464
andrewrp
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/18 04:34:30 (permalink)
We have a problem!
3x zr30w or any 30 inch monitor will not fit on my desk!
I guess I need a smaller (24 inch) monitor. However, I would like to keep the high resolution and color gamut of the zr30w.
Any suggestions?
RaMansell
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/18 04:36:43 (permalink)
Bigger desk!
3n1gma
Re:Need Help for the ULTIMATE of ULTIMATE SR-2 Builds 2011/02/18 04:41:05 (permalink)
Spot on, RaMansell!
