- Ribbons : 98
Re:My 7' Tall Evaporative Water Cooling Tower
2010/01/21 09:39:07
merc.man87 Okay, then i will just get it from my local plumbing shop, would rather support them as they are a local owned business and seem to have respectable prices. Could i still benefit from using a radiator in the loop? Maybe like one quad rad? I have no experience here, but I would venture to say that the only place that would make sense for a radiator would be after the waterblock(s) in the return loop to the bong cooler. Anywhere else wouldn't make sense. The water going to the PC from the bong cooler should be lower than ambient room temperature and placing a radiator anywhere along that supply section of the loop would cause the radiator to actually heat up the water instead of cooling it down. Could the radiator even be beneficial? I would think that it wouldn't be much benefit at all for the bong cooler's operation.
Fiius
- Ribbons : 25
2010/01/21 10:33:16
it might be beneficial if the rad was stuck in between two high heat items, but the bong cooler is supposed to replace the rads as the heat exchanger. ~Fus
"Abyss v2" | Gigabyte GA-Z77MX-D3H | Core i5 3570k w/ XSPC Raystorm Waterblock | Corsair AX-650 | | 32GB (4x8GB) G.Skill RipJaws X PC3-1600 10-10-10-30 (BXL) | | EVGA GTX 670 w/ Heatkiller LT 13105 + Backplate | Crucial M4 240GB SSD | 2x HGST 4TB | | Fractal Design Arc Mini | 2x PULL AP-15s on Swiftech MCR240 | D5 w/ Koolance COV-PMP450A Top | | Win7 x64 | 2x Dell UltraSharp 2408WFPb | Dell UltraSharp 2407 WFPb |
nateman_doo
- Ribbons : 52
2010/01/21 15:36:06
I have it going through 3 radiators as well, 2 triples, and 1 double. I forget what is what as far as direction... but they are there.
Fiius
- Ribbons : 25
2010/01/21 16:12:34
/scratches head What are they there for? Do they have fans attached to them? Where does the heat go? ~Fus
nateman_doo
- Ribbons : 52
2010/01/21 16:17:30
they have fans on them. They are sorta left over from my standard water cooling system. more tests will be done tomorrow, I just brought board back from the dead yesterday. right now trying my luck at HWbot at a friends house. Got a 5th place score, we have yet to submit it yet.
cade121
2010/01/22 22:59:54
I've never water cooled before so am unfamiliar with what various pumps can do. Any chance microcenter.com would have a pump that would suffice for, say, a 5 or 6 foot tower?
nateman_doo
- Ribbons : 52
2010/01/23 09:34:37
oh YES they would... they carry the swiftech mcp 655 for $60-$70. i promise it will be all the pump you ever need. it powers mine JUST fine.
cade121
2010/01/23 17:31:57
Thanks man, and would you recommend any particular fittings for this type of project? How bout hose size? : ) Looks like the hoses at MC are kind of pricey. Any alternate sources for acceptable hose that would not require ordering? (I can drive to Microcenter) Thanks again for putting this info up.
Q56_Monster
- Ribbons : 5
2010/01/23 17:43:12
How's the project going Nate. You got it up and running, any results yet?
Mobo: tbd CPU: tbd GPU: tbd RAM: tbd HD: tbd PSU: 2 x PC Power & Cooling 1200W OS: All of them Monitor: Whatever Other Cooling Fun: F1 Gemini/Tek-9 Fat LN2 | 12k BTU A/C to Chiller Conversion
nateman_doo
- Ribbons : 52
2010/01/24 00:06:54
I am holding off until I pic up another MCP 655 probably in the next few weeks. that pump owns my other ones. They just do not like pumping up to the 7 feet required. So now I am running straight water to my chipsets, and chiller to GPU's and CPU. maybe some decent runs tomorrow?
cade121
2010/01/24 17:45:20
How do you couple the hose to the shower head? I bought 3/8 inner diameter hose and one of the very small shower heads with the push button adjuster that lets you adjust spray pressure or shut it all the way off. Bought a couple of 1/2 inch barbs at MC, but not sure how to get hose onto shower head. nevermind I overlooked the pic One other question. I noticed in one of the other pics u have a barb in the bottom of the tower for the intake hose. Would it work just to have water in the res and just let the intake hose rest in the water? That way you could perhaps install a filter onto the end of the hose. For some reason I got tha fever for this project. Today I drove to Microcenter and picked up an Apogee XT block and a 655 pump, but bought hose too small. Gotta get back up to MC to exchange. Or refund and get some from Performance PCs. If I can't get it to work out I will just get me a 360 or 480 rad. Either way, looks like I'm diving into water cooling, for better or for worse lol.
post edited by cade121 - 2010/01/24 20:51:13
nateman_doo
- Ribbons : 52
2010/01/25 12:06:16
you can just run the hose like you said. I just did it cause thats how I roll (and I have a 1/2" pipe tap) This Thursday I will hopefully pick up a MCP-655 for this bong cooler alone. I plan on running this daily when my chiller is not in operation. So that means more pictures to follow. I really don't take that much when my office is in shambles. Once I get this project finished, I will more then likely tidy the room up, and go crazy with the pictures.
cade121
2010/01/25 12:31:22
Thanks most kindly nateman. Look forward to more pics!
2010/01/25 13:41:09
nate have you ever seen irrigation spray heads , there are some that mist the water, just as you require and i do belive that the head pressure doesn't need to be to high
rig 1 X79 DARK 3940k (4.4oc), corsair Platinum 2133mhz,Evga GTX580 2way sli, mountain mod assention, rig 2 EVGA X58 759 CLASSIFIED I7 930/ 4.5GHZ Corsair Domminator 2153MHZ 10,10,10,24/1T Evga GTX 460
nateman_doo
- Ribbons : 52
2010/01/26 03:21:54
cade121 Thanks most kindly nateman. Look forward to more pics! you too! i wanna see how yours comes along
nateman_doo
- Ribbons : 52
2010/01/26 03:34:42
fusionssl nate have you ever seen irrigation spray heads , there are some that mist the water, just as you require and i do belive that the head pressure doesn't need to be to high No i havent? send me a link to one... I'll try just about anything.
ShockTheMonky
- Ribbons : 45
2010/01/26 03:57:13
" Psst. Zip up. Your ignorance is showing." " I don't suffer from insanity. I enjoy every minute of it!" " Can an Atheist get insurance for acts of god?
2010/01/26 04:34:48
str1d3r
- Ribbons : 5
2010/01/26 05:26:30
Been following this thread with alot of interest and it has gotten me motivated to go to the garage and try various configurations. with 24 years in commercial/industrial refrigeration I have aquired a MASS of spare, new/used parts etc. I have never tried watercooling any of my rigs yet (other than using an H50) but have been wanting to for a long time. ------>goes to garage------>
MCS1181
2010/01/26 05:35:03
Man I'd hate to have to clear that thing solo. The ol' lungs ain't what they used to be.
i7 965 // R2E // EVGA 295s // Dominator GT // Obsidian 800D
nateman_doo
- Ribbons : 52
2010/01/26 05:35:34
The only problem that I see with an outright mister... the air coming up the shoot I think would kick out the majority of the water being thrown out of the mister. I have 2 high flow fans and lots of water kicks out of the tube from the showerhead I have now: I would probably have to put a much lower cfm fan if I was to use the mister.
nateman_doo
- Ribbons : 52
2010/01/26 05:37:34
MCS1181 Man I'd hate to have to clear that thing solo. The ol' lungs ain't what they used to be. HA HA!!
nateman_doo
- Ribbons : 52
2010/01/26 05:41:24
str1d3r Been following this thread with alot of interest and it has gotten me motivated to go to the garage and try various configurations. with 24 years in commercial/industrial refrigeration I have aquired a MASS of spare, new/used parts etc. I have never tried watercooling any of my rigs yet (other than using an H50) but have been wanting to for a long time. ------>goes to garage------> NICE! you should find some sweat caps, solder them together (probably a 1.25" & 1.5") drill holes and insert 1/2" OD pipe, and make a block for a CPU/GPU. Don't forget to post pictures!
str1d3r
- Ribbons : 5
2010/01/26 06:13:50
I have a pretty full machine shop and looking @ those links of the mister heads got me thinking.... http://www.bestnest.com/bestnest/RTProduct.asp?SKU=DRA-10-12344&src=shopzilla&kw=DRA-10-12344 those sprinkler heads may be useful but just not deliver the "misting" result. The orifice is more than likely to large depending on the gpm of the pump being used. The brass heads used in those pics look quite similar to those used in LP and natural gas furnaces. (can be found in plumbing/heating supply houses very cheap) The orifices in LP and natural heads are sooooo small and may give "misting" with a much less gpm pump. The smaller the hole=more of a mist with less gpm pump. to small or not enough and the pump may get damaged. A manifold with 3-10+- very fine orifices may give a desired result. (I will be attempting this with various pumps) Also sold @ these locations are drill tap sets for clearing/ enlarging. like the diff of a blond and brunnett hair. they are incredibly small and break very easily so care is needed (no coffee) BTW If you have an LP gas funace in your house then there is a very good chance that you have a small bag with 3-6 of these brass orifices lingering on, around or inside the furnace cover.
post edited by str1d3r - 2010/01/26 06:20:28
nateman_doo
- Ribbons : 52
2010/01/26 08:07:25
niiceee... machine shops.... verryyyy nicceee... Maybe you can put a few of those heads in a single pipe? I just figure as soon as the mist hits the side wall, it clings and just slides down the side. It will still get cooled as it falls down, but it looses half the surface area exposed to the air by it clinging to the side wall of the tube? i thinks?
str1d3r
- Ribbons : 5
2010/01/26 08:43:51
nateman_doo
- Ribbons : 52
2010/01/26 08:57:19
really its not a bad thing going down the walls (of the tube that is  ) Lets see that pic
IndianScout
nateman_doo
- Ribbons : 52
2010/01/26 09:43:45
I like the avatar btw. futuremark FTW
str1d3r
- Ribbons : 5
2010/01/26 10:05:06
PhotoShop skillz arent gr8 but anyway, my thoughts (not always great) would be to keep the air moving rapidly without losing the vapors. A (or multiple) high velocity fan(s) with sealed motor would work provided there were baffles upstream to collect large droplets. Just a thought and what I will be starting soon. will be leaving the "to/from loop" out for awhile. The large tube shown could be finned copper/aluminum with air circ (at least something thin enough to disapate heat (not pvc))
post edited by str1d3r - 2010/01/26 10:38:47
