Monitor interface connection
merlewagner
2016/11/11 13:47:45 (permalink)
I just received the GTX 1080 card (08G-P4-6180-KR) and installed. It is working quite well with my LG 4K monitor using the HDMI interface. I have ordered another HDMI monitor but just realized my card only has one HDMI port. The graphics card has 3 additional Display ports and a DVI-D port.
How or what do I use to connect another HDMI monitor? Or, what interfaces with the Display ports?
Thanks,
Merle
4 Replies Related Threads
    qbvbsite
    Re: Monitor interface connection 2016/11/11 13:51:42 (permalink)
    Just get a dp to hdmi connector. I do the same with my monitors
    arestavo
    • Ribbons : 8
    Re: Monitor interface connection 2016/11/11 13:54:46 (permalink)
    For 4K 60Hz resolutions, you need an ACTIVE adapter or you won't be able to get 4K 60Hz.
    Like this one: https://www.amazon.com/DisplayPort-HDMI-2-0a-Active-Adapter/dp/B01B6ZOMIS/ref=sr_1_1?ie=UTF8&qid=1478901385&sr=8-1&keywords=DP+to+HDMI+4K+60Hz
    EVGA affiliate code: 9ZWDWFNW6A
    (Don't forget to upload your invoice or no credit is given!)
    FOLD ON
    • Ribbons : 122
    Re: Monitor interface connection 2016/11/11 13:56:09 (permalink)
    You'll need to buy a displayport to hdmi adapter. I'd recommend this one.
    merlewagner
    Re: Monitor interface connection 2016/11/11 13:57:13 (permalink)
    Thanks for the info. Didn't realize there was an adaptor
