Jeff_ M
Before I even begin, I am not bashing EVGA for a problem, simply asking a question about how the fix is progressing. I've used EVGA cards for the past 8 years and never had an issue, so I'm looking at purchasing a 1070 FTW in the coming months, likely sometime early 2017 when tax money is in so I can build my entire new system. I know currently you can get free thermal pads to install yourself, I'm just curious if EVGA will be changing the manufacturing a bit to start installing these at the factory or what the plan is. As far as I can tell the overheating issues are kind of spotty, so it doesn't seem to be necessary to start thinking about a recall or anything that drastic. Cheers, thanks for having me as part of the community.
EVGATech_AndrewA
EVGA Tech Support
Re: Manufacturing fix for hot VRM issues?
2016/10/31 08:57:18
There are no overheating issues with any of our 1070/1080 cards and any "issues" reported are not related to one another. The reports that have been coming out are completely false and I can assure you that our cards run within spec as stated by our Product Manager Jacob. The thermal pads that are being offered by us are completely optional and without them the cards run within spec.
Jeff_ M
2016/10/31 08:59:28
Gotcha, thanks for the clarification. I apologize if the tone came across as accusatory or anything, I'm just trying to find out information.
EVGATech_AndrewA
EVGA Tech Support
2016/10/31 09:00:24
Jeff_ M Gotcha, thanks for the clarification. I apologize if the tone came across as accusatory or anything, I'm just trying to find out information.
No need to apologize. Your concern is completely understandable. Have a great day!
brokencross
2016/10/31 09:05:09
EVGATech_AndrewA There are no overheating issues with any of our 1070/1080 cards and any "issues" reported are not related to one another. The reports that have been coming out are completely false and I can assure you that our cards run within spec as stated by our Product Manager Jacob. The thermal pads that are being offered by us are completely optional and without them the cards run within spec.
I don't think we are worried about our cards possibly blowing up. We would just like to know if those significantly higher VRM operating temps, compared to other brands, will in any way affect our cards longevity. This and why EVGA just skipped on thermal pads for the VRMs when every other vendor had them installed.
Intel i5 4690K@4.4Ghz | MSI Z97 Gaming 5 | EVGA GTX1070 FTW replaced by a MSI GTX 1070 Gaming X | G.Skill RipJawsX 8GB 1866Mhz | Corsair CS650M | Thermalright Macho | NZXT S340
EVGATech_AndrewA
EVGA Tech Support
2016/10/31 09:09:10
brokencross
The temps are not significantly higher. They run well within normal spec temperature. The temps you are seeing from places like Tom's Hardware and other sites are from people running Furmark at extreme settings for a long period of time.
brokencross
2016/10/31 09:11:19
EVGATech_AndrewA
brokencross
Sure, I didn't say they were running out of spec. But using the same methods, other vendors had significantly lower VRM temps. Except for Zotac, which was on par with EVGA (even a tiny bit higher, as a matter of fact), yet there haven't been any issues reported with Zotac VRMs. Which kinda makes me think.
dwrecording
2016/10/31 09:12:17
(Warning There is a VRM PROBLEM Protect yourself) Check out that post.
Jeff_ M
2016/10/31 09:35:14
One more thing I want to ask, how long will the free thermal pads be offered? Since I'm not purchasing a card for at least 2 or 3 months obviously I'm not eligible to get them now, but I would like to have them when I do order.
mounchli
2016/10/31 09:44:51
Bonjour j'ai acheté une GTX 1080 FTW je n'ai pas pour l'instant de problème de surchauffe vrm ou étalage d'alimentation dois je faire changer désolé mon anglais est mauvais.... merci Hello I bought a 1080 GTX FTW I have not yet vrm of overheating or power display should I change sorry my english is bad .... thank you
brokencross
2016/10/31 09:44:57
Jeff_ M One more thing I want to ask, how long will the free thermal pads be offered? Since I'm not purchasing a card for at least 2 or 3 months obviously I'm not eligible to get them now, but I would like to have them when I do order.
New ones will come with pre-installed thermal pads.
ZCTxCHAOSx
2016/10/31 09:47:46
Don't apologize to that fool. Him and all the other tech support and moderators here and skirting the issue GO TO ANOTHER COMPANY.
EVGATech_AndrewA
EVGA Tech Support
2016/10/31 09:48:52
ZCTxCHAOSx
Don't apologize. Him and all the other tech support and moderators here and skirting the issue GO TO ANOTHER COMPANY.
There is no issue
post edited by Scarlet-Tech - 2016/10/31 10:42:01
2016/10/31 09:52:25
Maybe it is time for approval of Threads and Posts on the Forum to control this issue. MODS Are you up to this tasks?
dakon
2016/10/31 09:53:03
EVGATech_AndrewA
ZCTxCHAOSx
There is no issue
Then why does the EVGA card run at 30 degrees higher, even if the program used was not ideal?
4770k @ 4.4 w/ Phoybia HeGrease Corsair Hydro Series H110 Asus Maximus VI Hero Samsung 840 Pro 256gb x2 Samsung 850 Evo 500gb Titan XP Asus Xonar Essence STX Corsair Dominator Platinum DDR3 2400 C10 Corsair Air 540 Corsair ax1200 Deck Francium Pro 87 Key Brown Switch Beyerdynamics DT 770 Pro Asus ROG Gladius ASUS ROG SWIFT PG348Q 2x Asus VX229H
shannonjpower
2016/10/31 09:56:53
Hi Andrew, Is there any chance EVGA can perform the own in house thermal tests and have the results posted in an official statement? As you can see there is a LOT of speculation and rumors going about due to the lack of information and numbers coming from EVGA. The statement from EVGA and the thermal test results after the pad was added isn't enough and is extremely vague at best. The only way all this is going to be stopped is for some official results to be posted with some actual details and numbers. That way this issue can be put to rest once and for all and everyone has a reference to link to etc. At the end of the day this can only benefit EVGA and put a stop to all of this. I'm not sure why this wasn't done when EVGA had the card on the test bed with the new thermal pad. Both the before and after results could have been used instead of just the later. That way people can see there was and still isn't an issue if you decide no to go ahead with the thermal pad fix.
post edited by shannonjpower - 2016/10/31 10:03:16
ZCTxCHAOSx
2016/10/31 10:04:10
EVGATech_AndrewA
ZCTxCHAOSx
There is no issue
Go grab my card that is in RMA and slap yourself with it while saying there is no issue. I swear you all are totally brain dead. Have you not seen the countless posts here, reddit and generally going around the internet. Vulgar language and masked vulgar language is not allowed.
post edited by Scarlet-Tech - 2016/10/31 10:44:59
Jeff_ M
2016/10/31 10:07:21
bcavnaugh Maybe it is time for approval of Threads and Posts on the Forum to control this issue. MODS Are you up to this tasks?
I didn't intend to start anything, but obviously it's a hot topic right now. I got the answers I came for, this thread can be deleted as far as I'm concerned.
ZCTxCHAOSx
2016/10/31 10:14:12
Jeff_ M
Yes jeff, in all honesty go with another company. These people have me super heated at this point and are dragging feet for resolution. EVGA has always been my goto for Graphics, but that officially ends now.
NucleusX
2016/10/31 10:14:24
ZCTxCHAOSx
EVGATech_AndrewA
ZCTxCHAOSx
There is no issue
LMBO !! Vulgar language and masked vulgar language is not allowed
post edited by Scarlet-Tech - 2016/10/31 10:46:29
CPU: Intel 486 DX2. 66Mhz (Turbo). Cooling: LN2. MTB: ECS. Chipset: SIS. HD: WD Raptor 300mb x 512. 154GB. Raid 0. RAM: Corsair Obliterator Gold. EDO. 16mb. 66mhz. x8. GPU: Nvidia GTX Riva TNT2 FTW OC. PCI. 32mb. x4 Quad SLI. PSU: ATX 200 watt (no label). Case: RGB Milk Crate.
drewskidrewsgv
2016/10/31 10:16:50
ZCTxCHAOSx
Jeff_ M
Yeah big talk from someone on a Forum post. If you dont like your card or EVGA then have fun with Gigabyte or ASUS and their crappy customer service which is also having this "issue" by the way.
brokencross
2016/10/31 10:27:25
Don't turn this into an argument, guys.
post edited by Scarlet-Tech - 2016/10/31 10:52:19
drewskidrewsgv
2016/10/31 10:30:28
I'm not turning this into anything. It's Mr. Loud Mouth up here ^^^that's deciding to come into a Forum and start bashing a company on a product he knows nothing about and try to defer customers from purchasing said product by spreading lies.
ZCTxCHAOSx
2016/10/31 10:36:24
drewskidrewsgv I'm not turning this into anything. It's Mr. Loud Mouth up here ^^^that's deciding to come into a Forum and start bashing a company on a product he knows nothing about and try to defer customers from purchasing said product by spreading lies.
Look at my joined date compared to yours. Not to mention I have been using EVGA cards long before I got on there to register that 750ti. I'm going to continue to bash them until the truth comes out and the people around here stop side stepping the issue. It is now my personal mission to spread this word. If they would have just been up front and honest from the beginning, we would have no problem. And that includes sending out a mass email to all registered users about the Thermal Pads. So yes, I am taking to any medium I can now to deter people away from this shady company. I work from home and have ALL day to sit here and do what is needed.
post edited by Scarlet-Tech - 2016/10/31 10:50:31
new0ne
2016/10/31 10:44:50
Why dont u just leave the forum if you are already happy with another company? Good luck and bye
acxcoolerssuck
2016/10/31 10:55:53
mytwocents: i think evga should reveal the reasons of the caught fire cases in order to show ftw card can run in spec without additional pads.
Jeff_ M
2016/10/31 12:49:46
acxcoolerssuck mytwocents: i think evga should reveal the reasons of the caught fire cases in order to show ftw card can run in spec without additional pads.
They did a test and it performed within spec, articles on mobipicker.com and techpowerup.com are the first Google results, it won't let me post a link. I don't think it's entirely possible for EVGA to verify the cause of each and every claim, there are too many variables with each setup, and as demonstrated by some of the posts on this forum, it becomes hearsay pretty quickly. Someone could say they were running on a particular setting, but really they were doing something else entirely, etc. etc.
- Ribbons : 57
2016/10/31 12:57:40
ZCTxCHAOSx
I see, so my join date means my comments are more valid than yours, right? I recently asked you to provide something backing your claims of a MAJOR ISSUE of VRM components failing across ALL EVGA 1080 and 1070 GPUs. You refused. Why is that?
EVGA E758/i7 980x 4.3ghz 1.36v 12GB Corsair Dominator 2000C9 GTX 980Ti w/GTX TITAN SC for PhysX Crucial M4 512GB SSD/2x WD RE4 Black 2TB Corsair H50 Cooler/Corsair AX1200/Window 10 Pro
robmp11
2016/10/31 14:26:55
jlp209
2016/10/31 14:39:37
Everyone always points to that same photo of that burned card, lol. I haven't seen "hundreds of cards blowing up." I've seen hundreds of useless posts about cards blowing up. I'd be miffed if I had to apply thermal pads to my card, but it isn't the end of the world. You may learn something new by taking apart your card and applying the pads, and re-apply thermal paste to boot. Or, send it to EVGA and they'll take care of it. The more people who stop buying from EVGA, the quicker I'll receive my next card(s) from fewer people ordering ahead of me. Score.
MB: Asus Z170 Sabertooth Mark 1CPU: i7 6700K @ 4.5ghzCPU Cooling: Noctua NH-U14SGPU: EVGA GTX 1080 FTW HybridRAM: Corsair LPX 16GB DDR4 3000Main / OS: Samsung 950 Pro 256GB m.2Games: Samsung 830 512GB SSDStorage: HGST 4TB HDDMonitor: Acer XB271HU 27" IPS 1440p 165HzPSU: EVGA SuperNOVA 850 G2Case: Corsair 760TOS: Windows 10 Pro
