maniacvvv
- Ribbons : 159
__________________________________ This temporary Guide is being replaced by my "Ultimate Battlefield 3 Guide" in the 500 series fourms http://forums.evga.com/fb.ashx?m=1323124 Ok guys, decided to push out a quick guide for getting better performance and dealing with issues in BF3 -This is a completly temporary referance Guide- ----->THIS IS NOT MY FINAL BATTLEFIELD 3 GUIDE (that will come after the patch and new Nvidia driver) *Nvidia has another driver coming and Dice/EA has some patches planned The information below is just to help users play until the Patch/Driver are released (possibly this week) First up is what driver to use Nvidia 285.79 BETA is the driver you need to use for BF3. (285.62 was the previous best) --> MANIAC recommends using Nvidia 285.79 Next up are your Nvidia Control Panel settings (Manage 3D Settings Panel) Using the correct settings in the NVCP is critical. During testing certain settings have caused in-game issues. MANIAC recommends you -match- every single setting in the above screenshot (not just the ones in RED) *using the above settings should help users who are having issues. **Remember everyones cofig is different in some manner. The settings above are to try and help users who are having problems, it may or may NOT help. They are a "suggested" starting point to help users run better.
Ambient Occlusion must be set ot OFF. Having it ON will cause serious issues. Antialasing-Transparency should be set to MULTISAMPLE Maximum pre-rendered frames needs to be set at a value of (2). Leaving it at 3 can cause issues. Texture Filtering- Negitive LOD bias should be set to ALLOW. Using CLAMP can cause issues. Texture Filtering- QUALITY should be set to QUALITY. Do NOT set anything else for this value. Triple buffering- OFF should be set to OFF. Do NOT turn this setting ON even if your using VSync (in-game) Vertical Sync needs to be set to "Use the 3D Application setting". Do NOT force Vsync in the NVCP, use the in-game option. *Important Note for SLI users You MUST use the "Nvidia Recommended" setting for SLI , as this is the included custom SLI profile for BF3! Next up is the in-game VIDEO options panel I am not going to go into all the details and the complex differences between all the settings, I am just going to post a Screenshot of the BASE SETTINGS to use to get the game working properly. The settings I have posted below are not MAX ULTRA settings (what I use) -->but are tested to provide the best quality, moderate VRAM use and most importantly STABLITY MANIAC recommends that users who are having issues, use ALL of the above settings for testing The above settings provide a good quality experience, moderate VRAM loading and most importantly, the settings used above -and- the posted NVCP settings work very well together. The NVCP settings matched with the above in-game settings, will FIX most of the VRAM and game/driver bug issues that some users are having using anything less than dual 3gig 580's in SLI. *Important note for users of single cards with lower VRAM (1gig and below) It is suggested that the (3) Ultra settings in the above screenshot be changed to "HIGH" if you experiance any issues Next up, a bug in the Mouse setting is causing many users to have issues. MANIAC recommends turning "Raw Mouse Input" to the setting of OFF **Always after making changes in the BF3 options panel... Save the settings Re-enter the game Hit escape, and check that the settings changes you made were saved correctly... Then CLOSE BF3, Battlelog and ORIGIN Restart everything, enter a server and deploy.. then check that settings are still showing the changes you made *Some changes will NOT have any effect---> until a map change or a game restart Just wanted to post up a good base of NVCP settings and in-game VIDEO options for those users who are having problems I expect many issues to be resolved with patching and the new Nvidia driver. Right now it appears that users running incorrect NVCP settings and in-game settings is causing alot of issues... There is also a large problem with the way the game loads out of Battlelog and the Shaders compile while waiting for a map the first time you run it, if the VRAM buffer at that time is exceeded, issues will occur when running the game even though VRAM use is "lower" when your in the game vs loading. I also expect this will be addressed with either a patch of Driver fix... Good luck and happy testing. I hope this helps you guys having problems *My full Guide will not be coming out, until we see what the next Nvidia driver and DICE/EA patches bring over the next few days.
post edited by maniacvvv - 2011/11/17 00:04:03
Wraith.
Re:MANIAC's BF3 -temporary- Quick Guide
2011/10/27 09:31:47
Keep it coming Maniac... I'm installing tomorrow and could use the pointers. Thanks!
I7 990X 4.3 Ghz(under water) E770-A1 Classified 3 (under water) (2) GTX-780 Classified HC 3GB (under water) 12GB Corsair Dominator GT (under water) Asus Xonar Xense/PC350 (2) 120 GB Intel X-25 SSD 1500 Watt Silverstone ST1500 3 independent water cooling loops Overlord Tempest X27OC 1440@110hz CM Cosmos Black Label case #32
Im Hit!
EVGA Gaming News Reporter
2011/10/27 09:35:48
Wraith. Keep it coming Maniac... I'm installing tomorrow and could use the pointers. Thanks! I disabled motion blur. Gave me a noticeable boost in performance.
i7 5960X OC'd @ 4.5Ghz | ASUS X99-Deluxe | 16Gb GSkill 3000MHz | NVIDIA GTX 980 | 30in HP Monitor @2560x1600 Games' Media - Daily Updates @ EVGaming
2011/10/27 09:38:08
I despise Blur but like DOF.... But as far as NVCP , I just used the previous settings like in BFBC2 & it seems to be solid enough
Intel Core i5-6600K SKYLAKE ~ MSI Z170A-G45 gaming board~ EVGA 1080 FTW ACX 3.0~ G.SKILL Ripjaws V series 16 GB DDR4 3200 ~ CORSAIR Vengeance C-70 Military Green case~ EVGA SuperNOVA 750 Platinum2 PSU~ CORSAIR Force GT 240 Gig SSD~ CORSAIR H80i V2 cooler~ Logitech G502 Proteus Core mouse~ CORSAIR K70 mech. keyboard~ HGST NAS -2TB Hd & 4TB Hd.~ Dell UltraSharp U2412M 24" LED @ 1920 X 1200~ Win 10 x64 STEAM
Im Hit!
2011/10/27 09:43:25
STEVEBABCOCK2002 I despise Blur but like DOF.... But as far as NVCP , I just used the previous settings like in BFBC2 & it seems to be solid enough Same - Love DoF. Always turn it up a bit. Gives me the sense of more speed and less sluggish. And well...you have more depth of field. LOL! Also kept my same settings as always. Turn ambient occlusion off in NVCP, but on in-game. V-sync forced Off...etc.
downie20
2011/10/27 09:49:29
Thx Manic. I'm going to try this out tonight.
 Affiliate Code: IY2CSZIKRN Heatware EVGA X58 E760** i7 920 D0 @ 4.21Ghz**Corsair Dominiators 6GB (7-7-7-20) 1600Mhz**Corsair HX1000 PSU Noctua NH-D14 Cooler**EVGA GTX 580 Classy-SLI*Tri-SLI SOON*OCZ Vertex 60GB SSD**(2x) WD Caviar Black 640GB-Raid 0
2011/10/27 10:09:09
I'll be trying this when I get home tonight woot woot
staypuft
- Ribbons : 19
2011/10/27 10:21:40
Awesome! Will try your settings above and report back tonite.
XeroHertZ
2011/10/27 10:52:06
Awesoooooome Maniac..will try these later tonight and will give my feedback :)
Case: Corsair 750D Motherboard: Asus Rampage V Extreme CPU: Intel Haswell-E 5960x @ 4.4Ghz Memory: Mushkin Redline DDR4 16GB (4x4GB) 13-13-13-35 GPU's: 2x EVGA GTX 980 SC's Sound Card: Soundblaster X-Fi Titanium Fatality Champion Series CPU Cooling: Corsair HX110i Liquid Cooling Storage1: Mushkin Scorpion 240GB PciE SSD Storage2: Samsung 840 EVO 1TB Storage3: 2TB WD Caviar Black Power Supply: Corsair AX1200i Speaker: Logitech Z-5500 3DMark Benchmark: http://www.3dmark.com/fs/3410236
- Ribbons : 57
2011/10/27 11:22:50
Whelp personally I just use the default NVCP settings... In game is all maxed except for I have reduced motion blur and turned off 'raw mouse input' of course. As an aside, 'ambient occlusion' is not supported so there is no way to change that in the NvCP game profile.
EVGA E758/i7 980x 4.3ghz 1.36v 12GB Corsair Dominator 2000C9 GTX 980Ti w/GTX TITAN SC for PhysX Crucial M4 512GB SSD/2x WD RE4 Black 2TB Corsair H50 Cooler/Corsair AX1200/Window 10 Pro
kmfd71
2011/10/27 11:24:58
XeroHertZ
2011/10/27 11:34:56
Ok for some reason my game become jerkier and I didn't like the performance...hmmmmmm, strange.
maniacvvv
- Ribbons : 159
2011/10/27 11:47:58
SpeedMax
XeroHertZ
2011/10/27 11:51:57
maniacvvv SpeedMax Ok for some reason my game become jerkier and I didn't like the performance...hmmmmmm, strange. Always after making changes in the BF3 options panel... Save the settings Re-enter the game Hit escape, and check that the settings changes you made were saved correctly... Then CLOSE BF3, Battlelog and ORIGIN Restart everything, enter a server and deploy.. then check that settings are still showing the changes you made *Some changes will NOT have any effect---> until a map change or a game restart Alright will do as adivsed and try again...thanks maniac :)
staypuft
- Ribbons : 19
2011/10/27 11:52:27
The OP has posted Global profile changes but you are setting a program-specific profile for BF3. If one or the other is changed isn't it the same thing relative to BF3? (ignoring global effect on other games)
maniacvvv
- Ribbons : 159
2011/10/27 11:55:27
SpeedMax
maniacvvv
SpeedMax
Remember bro, whatever works for you is "Best"... everyones config is different  You got dual 580's like I do... the settings I posted are NOT what you or I would use with the horsepower we have. What I posted is is NVCP and in-game Video options... to help users who are having serious issues running the game.
maniacvvv
- Ribbons : 159
2011/10/27 12:02:53
staypuft
If you look at the "Program setting" tab for the included BF3.exe profile you will see that it "defaults" to whatever value is set in the Global settings tab (except for what is noted below) -->Ambiant Occlusion is "disabled" as BF3 uses its own in-game method -->The SLI profile for BF3 (included) --> Application controlled Antialising is "Forced" to prevent users from using settings that are incompatable with BF3
kboucher
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues
2011/10/27 12:07:23
I can not see the pictures in this thread can anyone help, I tried r/click and show picture but no luck. Just an X where the picture should show?
maniacvvv
- Ribbons : 159
2011/10/27 12:17:04
kboucher
Try clearing your browser and then reloading the page
- Ribbons : 57
2011/10/27 12:17:06
staypuft HeavyHemi Whelp personally I just use the default NVCP settings... In game is all maxed except for I have reduced motion blur and turned off 'raw mouse input' of course. As an aside, 'ambient occlusion' is not supported so there is no way to change that in the NvCP game profile. The OP has posted Global profile changes but you are setting a program-specific profile for BF3. If one or the other is changed isn't it the same thing relative to BF3? (ignoring global effect on other games) Personally I would never change the Global Profile for a game as this would affect all the other games as well. Some titles are not compatible with multi-sampling for example.
Baasha
2011/10/27 12:19:18
Can't wait for your full BF3 guide! Also, the power mode shows "Adaptive" in your screen but I thought that ALWAYS has to be on "Prefer Maximum Performance", no?
4K Gaming in all its Glory! - ThirtyIR The Uber Rig -------------------------------------------------------- Please check out my FOR SALE thread!
- Ribbons : 57
2011/10/27 12:22:30
Baasha Can't wait for your full BF3 guide! Also, the power mode shows "Adaptive" in your screen but I thought that ALWAYS has to be on "Prefer Maximum Performance", no? Most of the time that setting doesn't make any difference in game. There were a few titles, Fallout 3 being an example where the GPU would change power states in game causing stuttering. It won't hurt to change that to 'Prefer Max Perf' in the game profile.
maniacvvv
- Ribbons : 159
2011/10/27 12:24:47
staypuft
Agreed But since many users get into trouble with profiles, and profiles are deleted during a Clean intstall... My BFBC2 Guide and my BF3 guide will be suggesting changes in the Global settings tab. *if users have any problems using other games, all they need to do is hit the "RESET" button in the global tab and it bcomes a non-issue. My advice and posted information is for running BF3.... and nothing else
maniacvvv
- Ribbons : 159
2011/10/27 12:26:39
Baasha
BF3 (unlike some other titles) appears to have no problems or issues running with the setting of "Adaptive" and Nvidia driver 285.62 So I am suggesting that setting
Baasha
2011/10/27 12:33:51
maniacvvv Baasha Can't wait for your full BF3 guide! Also, the power mode shows "Adaptive" in your screen but I thought that ALWAYS has to be on "Prefer Maximum Performance", no? BF3 (unlike some other titles) appears to have no problems or issues running with the setting of "Adaptive" and Nvidia driver 285.62 So I am suggesting that setting Any particular advantage in running "Adaptive" versus "Performance"?
maniacvvv
- Ribbons : 159
2011/10/27 12:37:23
Baasha
maniacvvv
Baasha
The videocard clock behavior is much better when using adaptive
heritage1550
2011/10/27 13:16:19
Thanks for the post, maniac. It's certainly timely for me since I had a couple of bsod's yesterday and a couple on opening day. I'm running 2560x1440 res with two GTX 580's in sli with 1.5gb of vram each. I started out at Ultra settings with 4xaa and my memory usage reached 1495 (with Aero turned off). So I've been back pedalling to see if I can find a good compromise between performance and stability. I'll give your settings a shot. Thanks again!!
- Ribbons : 57
2011/10/27 14:12:35
maniacvvv HeavyHemi staypuft HeavyHemi Whelp personally I just use the default NVCP settings... In game is all maxed except for I have reduced motion blur and turned off 'raw mouse input' of course. As an aside, 'ambient occlusion' is not supported so there is no way to change that in the NvCP game profile. The OP has posted Global profile changes but you are setting a program-specific profile for BF3. If one or the other is changed isn't it the same thing relative to BF3? (ignoring global effect on other games) Personally I would never change the Global Profile for a game as this would affect all the other games as well. Some titles are not compatible with multi-sampling for example. Agreed But since many users get into trouble with profiles, and profiles are deleted during a Clean intstall... My BFBC2 Guide and my BF3 guide will be suggesting changes in the Global settings tab. *if users have any problems using other games, all they need to do is hit the "RESET" button in the global tab and it bcomes a non-issue. My advice and posted information is for running BF3.... and nothing else Yes but installing drivers also changes the global profile back to default as well. Half dozen of one, six of the other. Using the game profiles IMO are better.
remidian
2011/10/27 15:37:07
Would you use the same settings you have listed in the NVCP for 580 sli? Certain tree and grass textures flicker, and everything is a little jerky in general. I am hoping new drivers n such will resolve it.
Win 10 64bit, Titan X(Pascal), Asus Hero VII, I7 4790k, H100i, 16g 2400 RAM, Samsung 850 PRO 1TB, Evga Supernova 1000w platinum, XB270HU, Sound Blaster Z, Logitech Z906, K70 keyboard. Heatware
- Ribbons : 57
2011/10/27 15:55:15
remidian Would you use the same settings you have listed in the NVCP for 580 sli? Certain tree and grass textures flicker, and everything is a little jerky in general. I am hoping new drivers n such will resolve it. I'm running 580 SLI. There's an issue with some textures that is supposed to be fixed with either a patch or a driver release. Might be a combination of both. As far as in game settings, the only things I changed from everything being on max, is turned 'raw mouse input' off. That seemed to eliminate the stutters and I reduced motion blur to about 25% just for appearance. All of my Nvidia control panel settings are on their default settings for the game profile and it runs very nice for me YMMV.
