MANIAC's BF3 -temporary- Quick Guide for users having issues
remidian
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/27 16:49:07 (permalink)
That's where I am at currently.  It is one sexy looking game.
Win 10 64bit, Titan X(Pascal), Asus Hero VII, I7 4790k, H100i,  16g 2400 RAMSamsung 850 PRO 1TB, Evga Supernova 1000w platinum,  XB270HU, Sound Blaster ZLogitech Z906, K70 keyboard.
Heatware
#31
binici
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/27 17:36:10 (permalink)
I'm going to try this right now! Wish me luck
HP Pavallion Elite 170f w/ Antec EarthWatts 650 PSU
i7-920, 12GB (3 x 4GB) G.Skill DDR3 1066, EVGA GTX 560 (SC), 1TB Hitachi 7200 HDD
#32
staypuft
  • Ribbons : 19
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/27 18:35:53 (permalink)
All settings changed as suggested...
Defaults in NVCP were different for the following: AA Transparency=OFF, Pre-Render Frames=3, Multi-Display=Multi-Display
Things are smoother now... thx
I tried just pre-render and it was also better, so my guess is this one...same issue as BFBC2
#33
maniacvvv
  • Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/27 19:54:00 (permalink)
Glad its running better
I expect all of this to be temporary until the next Nvidia driver and after the first serious patch.
EA/DICE was doing a "reporting cycle" today, where ORIGIN was sending gameplay data.
Lets hope they do something good with it
#34
geek32
  • Ribbons : 9
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/27 20:08:51 (permalink)
thanks for the settings maniac, but for the drivers i stick with the beta because it gives my card more fps and much smoother play.
                                    My Heatware  |  My FS Thread
#35
maniacvvv
  • Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/27 20:13:05 (permalink)
Yeah.. I did test each set (I liked the BETA's too) but I could not test any difference with my Dual 580's and 285.62 at least for my config gave the best results (about 15fps higher with high FXAA)...
Whatever works best, is what you should use... just trying to give users some ideas to try
#36
binici
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/27 21:11:43 (permalink)
The setttings are marvelous, but I experience the game locking/freezing even though I have well over 50fps.
I checked my Event View and there is an application error for bf3.exe closing unexpectedly. Sometimes I have to reboot or alt+ctrl+del to close BF3.
When I play in Windowed Mode the game does not crash...
#37
  • Ribbons : 92
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/27 22:10:26 (permalink)
   Another great guide Maniacvvv. Can't wait for the final version.
My Affiliate Code: 8WEQVXMCJL
#38
D3t0x
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/27 22:52:03 (permalink)
thanks for helping many people with your guides
i7-930 @ 4ghz with Noctua DH14
Asus P6X58D Premium
Corsair Dominator 6gb 1600mhz
EVGA GTX 580 SC SLI
Corsair AX1200
Intel x-25m 160gb (o/s) wd 1tb (data)
#39
binici
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/28 10:33:44 (permalink)
I actually took off the Adaptive setting and changed it to performance, which has made the game run smoother without crashes. Also, I read from another thread that changing your systems Power Plan to High performance would help? I'll have to do some more testing to see if the game is stable with the settings in this thread + the Power Plan option.
#40
robo78
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/28 19:46:09 (permalink)
Thanks Maniac....been playing for the last 2 hours with your settings in the NVCP and everything is running much smoother now.
Unchecking Raw Mouse Input seems to help as well.
Tried Hyperthreading both on and off and could not see any difference.
Had some weired green flashing bands across the screen on one map. Other than that....pretty good.
Where can I see my VRAM usage?
Intel Core i7-920 Bloomfield @ 3.4
Thermalright Ultra CPU Heatsink
EVGA E758-A1 3-Way SLI (x16/x16/x8)
2 x EVGA GTX 580's in SLI (Vanilla)
6 GB (3x2) Mushkin Tri Channel Memory
2 x Western Digital VelociRaptor 300 Gig
1 x Western Digital Caviar Blue WD6400AAKS 640GB 7200
Sound Blaster X-FI Platinum Fatalty Champion 7.1
Antec High Current Pro 1200W
LG Super Multi Blu-Ray Reader
Thermaltake Armor Case
Zalman MFC1 Fan Controller
58" Samsung Plasma 1080p
Windows 7 64 Bit
#41
maniacvvv
  • Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/28 19:52:52 (permalink)
use Afterburner or Precision's OSD and check GPU Memory for each card to be displayed.
*if you followed the "exact settings" I posted, VRAM is nominal at appox 1230mb loading/875mb running.
"Auto detect" works quite well for 580 vanilla's in SLI..
-->gives ULTRA/High and 1400mb running VRAM with "Post Processing AA" at x2
post edited by maniacvvv - 2011/10/28 19:57:47
#42
ikeyes
  • Ribbons : 9
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/28 20:03:06 (permalink)
I've read that at 1920x1200 or higher, a 3GB GTX-580 will actually use over 2GB of VRAM... any comment on this?
I am looking at possibly updating to the 580 and was thinking since I do play at that resolution, the 3GB card would be worth the few extra bucks...  specifically for BF3 of course.
3770K @ 4.5 (EVO)|EVGA GTX-670 FTW SLI|ASUS P8Z77-V Deluxe|16GB Vengeance DDR3-1600|830 Series 256GB SSD
2D Surround @ 6048x1080 on ASUS VH236H (x3) & Dell 2405FPW @ 1920x1200 Accessory Display
Q6700 @ 3.8 on Swiftech GTZ - EVGA GTX-280 SLI @ 756/1566/1350 on Swiftech MCW60r2 & GTX200 Heatsinks
EVGA 780i P08 & Zalman ZM-1000HP - HAF-932 - Dual Loop CPU/GPU each with MCR320 & D5 (7/16" Masterkleer) Pentosin G11 1:9 & PTNuke
Surround Gamer?  This is a must have!  https://www.flawlesswidescreen.org/index.php/Flawless_Widescreen
#43
maniacvvv
  • Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/28 20:06:08 (permalink)
I would NOT buy any 580 card that does not have 3gigs of Vram -period-
The screen res your using does not matter... get the 3gig model.
Yep, anything over 1920x1080 will push over 1.5g of VRAM easy
#44
ikeyes
  • Ribbons : 9
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/28 20:21:57 (permalink)
Thanks, I've only read a few comments on the 3GB cards for BF3 but the one that really struck me was from another member here on the forum who said during Beta his 3GB card was averaging between 2.2-2.4GB of VRAM playing on Ultra @ 1920x1200.
I was going to just get the Classified model, since it's only $10- more but that would mean new PSU and that brings the total $ way up... I can run a pair of the regular 3GB 580's with my current PSU saving me another few hundred dollars.
Thanks for the info.
#45
maniacvvv
  • Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/28 23:36:43 (permalink)
Your welcome
#46
Wetdream
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/30 10:36:39 (permalink)
ok.. thank you so much.
before - it would lock up or freeze after a few minutes. i stumble onto this post and take the settings to my pc and it WORKS!!!
i been playing for about 20 minutes now. no problems.
thanks maniac. u rock. i just wanna hold over until official fixes come and i can reap the awesome ness
UPDATE:
30 minutes of playing no problem,.
got a friend and started playing and boom - crashed after 6 min, crashed after 11, and crashed after 3..
DMAN ITTTTT
post edited by Wetdream - 2011/10/30 11:27:56
#47
splixx
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/30 10:55:14 (permalink)
Great work!!
#48
xWetdreaMx
Re:MANIAC's BF3 -temporary- Quick Guide 2011/10/31 03:53:20 (permalink)
removed
post edited by xWetdreaMx - 2011/10/31 05:56:01
#49
Wetdream
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 06:03:23 (permalink)
anyone else have any ideas? im so confused..
i used Maniacs suggested settings, used windowed mode, and monitored MSI Afterburner (turned card fan up to 70% to give additional cooling) and it worked the first time after changing it all for 30 minutes before i had to leave.
i come back and bam. cant play longer than 2 - 8 minutes. same "battlefield 3 has stopped working". my rig is the same as my buddy because i built them both. he can play his with NO problems at all except for weird artifacts once in a while AND he can play it on ultra.
so what the hell? what is the difference between mine n his.. and why did mine "get fixed" for 30 minutes after making Maniacs suggested changes and than it revert again..
video card can play crysis 2 still on ultra.
card is about 45 days old and gone thru 40 hrs of gameplay between BFBC2 and crysis 2.
#50
maniacvvv
  • Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 07:12:53 (permalink)
You mention it started happening when playing with your friend...
Was this Multiplayer? were you using voice coms?
#51
xWetdreaMx
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 07:16:45 (permalink)
Yes it was multiplayer. I didnt even think to try out SP and see..
We didnt like the quality of the voice in the game so we just use team speak.
i dislike my ht omega sound card so i have just been using onboard REALTEK audio for now.
#52
maniacvvv
  • Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 07:37:46 (permalink)
xWetdreaMx
Have you removed the HT sound card, and reinstalled the MB audio drivers?
In the browser you are using... can you "see" the pings for the servers you are playing on?
Do you use a TS3 server or is one of you hosting the server?
#53
xWetdreaMx
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 08:01:35 (permalink)
well i had problems with the ht omega (it wouldnt recognize certain speakers and i think the software was not so great) so i had removed it.
i reinstalled the realtek audio on board audio drivers and have been using the on board audio for some time (sorry if i was confusing).
i use a Logitech head set that plugs into the usb that has ear piece and mic.
On team speak, i dont host. we just find a random channel, ask if they mind if i create a sub-channel, and then me and my buddy go there and talk while gaming.
im thinking when i go home of:
playing single player (see if it crashes)
playing MP but no team speak or anything else. i usualy ALWAYS play with my friend.
any other suggestions?
thanks again everyone and especially Maniac for all the help.
it IS odd since you brought it up.. that i played the 30 minutes after your suggestions withOUT him on TS. and than he got on TS and i tried to play several times and thats when the trouble started again...
#54
Donwey
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 08:27:42 (permalink)
hello everyone iam new here :) and i want to solve my problem with BF3 .
I have GTX 570 SC , I7 920 2.6GHZ , 4gb ram @ 1600mhz , asus p6t deluxe v2 , Win 7 64bit , Enermax 625w psu .
 iam playing my bf3 at high settings + HBAO+NO AA and 70fov.
When i play bf3,  my fps are 60fps + thats ok but when i turn back or i go to new location where  my fps get down to 50fps( if i turn fast) and after 5 seconds its 60fps . Its pretty anoying these fps drops combined with stuttering . anyone have solution how to solve these fps drops? and yes i turned off HT   ( it helped but problem is still here) and iam using 285.62 nvidia driver version.
Than you for any help
#55
maniacvvv
  • Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 08:53:31 (permalink)
Donwey
Disabling HBAO will really help with the FPS instabilty...
Also running a I7 920 at 2.6 (stock) is crimping your videocard with a bottleneck. I suggest getting your I7 920 up to at least 3.6ghz for improved FPS performance
#56
Donwey
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 09:49:17 (permalink)
if i could i will overclock it to 3.6 but i cant , i have stock cooler so ...
#57
Wetdream
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 10:46:36 (permalink)
unisntalled realtek hd drivers, reinstalled fresh download from asus website for my mobo.
double checked all settings.. not on TS.. crashed after a few minutes @ stock 900 mhz
turned down to 820 mhz like some other forums said and same thing.
i just dont understand what allowed me to play for 30 minutes the other day.
and what is letting my buddy with same set up have no problems and i cant play more than 5 min...  ive even brought his rig over and looked at everything side by side.
#58
maniacvvv
  • Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 10:55:35 (permalink)
What browser are you using?
#59
Wetdream
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues 2011/10/31 11:05:14 (permalink)
FF 7.0.1
#60
