maniacvvv
- Ribbons : 159
Re:MANIAC's BF3 -temporary- Quick Guide for users having issues
2011/10/31 11:09:23
I suggest setting IE as the default browser (IE 8 is best, if you havent updated to IE9 yet stick with 8) Then test again.... also it should be noted that EA/DICE is doing backend and game patching this morning and it might NOT be a good time to be testing. I suggest testing tonight after the changes have settled in
Wetdream
2011/10/31 11:11:01
bump n thnx again. i know im not alone. just trying to try any mixes of things to at least be able to play n than would post to hopefully help others. cheers all.
MydasDiablo
2011/10/31 11:31:01
If you have already updated to IE9 then you can uninstall it using Control Panel - Uninstall a Program - View Installed Updates, it is in the list under Windows Updates, right click and uninstall, it reverts back to IE8 after restart ; )
Lian Li PC-X2000F Full Tower + 5 x Noiseblocker NB-BlackSilentPRO PK3 140mm Corsair Professional HX1000 1000w PSU Asus X58 Sabertooth M/B OCZ Vertex 2E 120GB SSD Samsung Spinpoint F3 1TB HDD Samsung Storybook 1.5TB External USB HDD i7 950 @ 4.3Ghz Prolimatech Megahalems + 2 x Noiseblocker NB-Multiframe M12-P 120mm in Push-Pull 6GB Corsair Dominator Triple Channel 1866Mhz 8-8-8-24 1T EVGA Classified GTX 590 650Mhz / 3700Mhz NuForce Icon HDP DAC, Headphone Amp & Pre-Amp Cambridge Soundworks 250D 300Watt 2.1 Speaker & Subwoofer System Ultrasone Pro 900 Cans Benq XL2410T 24" 1080p 3D LED 120Hz Monitor
MajorTankz
2011/10/31 11:38:22
Why should raw mouse input be turned off?
2011/10/31 12:22:17
raw mouse input causes some control issues, for me , when Alt-Tabbing in & out of the game -> chat-> Origin -> etc...etc..
Intel Core i5-6600K SKYLAKE ~ MSI Z170A-G45 gaming board~ EVGA 1080 FTW ACX 3.0~ G.SKILL Ripjaws V series 16 GB DDR4 3200 ~ CORSAIR Vengeance C-70 Military Green case~ EVGA SuperNOVA 750 Platinum2 PSU~ CORSAIR Force GT 240 Gig SSD~ CORSAIR H80i V2 cooler~ Logitech G502 Proteus Core mouse~ CORSAIR K70 mech. keyboard~ HGST NAS -2TB Hd & 4TB Hd.~ Dell UltraSharp U2412M 24" LED @ 1920 X 1200~ Win 10 x64 STEAM
Wetdream
2011/10/31 12:31:45
thats it. blaghhhhh... i uninstalled Asus GPU boost. underclocked to 820mhz put gpu voltage @ 1.0 switched to IE 8 reinstalled realtek drivers for on board audio (even tried playing with no on board audio drivers). all this on top of everything ive already done and STILLLL cant play the game. i give up. hours and hours and hours of tweaking. f it. guess i gotta wait for nvidia to release something, ea to patch something, asus to update a bios, or evga to do something. just great.. oh and i find out my vet status for battlefield 2 and 2142 arent found some how from their support. umm.. bought bf2 when it launched and been playing ever since. what a fabulous day.
staypuft
- Ribbons : 19
2011/11/09 07:52:07
Still working good for me. Have been experimenting with settings and found I can crank everything back up to Ultra and On, except Deferred AA is Off... my test setup is dual 560 non-Ti OC to 900 on a 2600K OC to 4.4 Vsync still forced off
Wetdream
2011/11/11 05:55:20
i found a fix for my evga 560 ti and BF3.
oddly enough - switching from windows 7 32 bit to 64 bit did it.
it was the last and ONLY thing that differed from the system i built for my friend. i had to bite the bullet and just upgrade.. but it worked.
i ve only crashed once when i turned everything to ultra.
now im increasing things one by one and playing for 30 minutes to see what might cuase the crash. after i find a good stable settings - than ill OC the processor and ram etc and get this b*tch running the wayt it should. im gonna go post in some of the other forums and hopefully upgrading to 64bit might help someone else too. 20+ hours of reading forums and testing etc and thats all it was??? maybe it has to do with the memory.. going to 64bit im not using the full registered 8gb of ram instead of the 4gb of 8 gb it recognized. with msi afterburner @ 85% fan, 900mhz (stock) my in game gpu temp is @ a nice 60 degrees.. not too shabby. :0)
danno428cj
2011/11/11 06:22:17
I had crashing issues, I updated my Realtek drivers and have had no issues since
Gigabyte Z77 G1 Sniper3 LGA 1155 Intel Core i7-3770k @ 4.2 G.Skill Ripjaws X Series 8GB (2X4GB) PC3 14900 @ 1866 EVGA GTX 780 Classified ACX Western Digital Caviar Black 1TB RAID 0 Silverstone Strider Gold 1000w Coolermaster HAF-932 case.
dawestsides
2011/11/11 11:49:37
Still no solution for my issue since Day One EVGA X58 758 i7 920 OC @ 3.4Ghz SLI EVGA GTX260 12GB 1600Mhz Issue: Freezing + looping sound requiring a hard reboot on PB servers only I'm having this problem since the begining .I did a fresh Windows 7 Ultimate 64 install on a new HDD,running the 285.62 Nvidia drivers - graphics driver only - after a clean installation.... I've tried the following: - Rolling back to previous Nvidia drivers - Installing the latest beta 285.79 drivers (only graphics driver) - Removing Realtek HD audio and installing generic Windows audio drivers - Installing the latest Realtek drivers from EVGA website - Installing the latest Realtek drivers from Realtek website - Running at stock settings without OC - Monitoring and logging GPU temps (normal) - Updating PB manually - Repairing BF3 from Origin - Disabling Anti-virus - Changing Windows 7 power management settings as suggested - Changing BF3 profile settings in Nvidia panel - Overclocking/downclocking my GPUs Disabling audio from bios ---> No freezing (but no sound too :)) Playing on PB-off servers ---> No freezing (but too many hackers :)) I purchased a 5.1 Logitech sound system especially for BF3...but for time being I'm using a USB Logitech headset. I will wait for the 1st patch,or maybe grab a cheap sound card.But it's clear that there is conflict between PB and Realtek drivers.
post edited by dawestsides - 2011/11/11 11:52:33
binici
2011/11/11 14:39:54
The only way I can get this game to work great is by down clocking the GTX 560 (SC) from 865Mhz ---> 825Mhz and the memory freq from 2002 ---> 1950. When I do this, I can play the game without the retrarded "Battlefield has stopped responding" message. The cards voltage is at 1.075 BTW (default).
HP Pavallion Elite 170f w/ Antec EarthWatts 650 PSU i7-920, 12GB (3 x 4GB) G.Skill DDR3 1066, EVGA GTX 560 (SC), 1TB Hitachi 7200 HDD
JoPineapplez
2011/11/15 09:40:50
Hmmmmmm ok i was having the dis-conn issue every 10-15 mins then i remembered Maniac's guide to BFBC 2 so tweaked everything, however the real clincher was dis-abling UPNP in my router. Had no problems since and been rampaging hard.
Randolla
2011/11/15 14:06:05
Wetdream, If you are still having problems try a different Virus scanner. Some of t5he guys I play with have had similar issues and was finaly able to fix it by changing their Virus protection. It might (not positive) have been AVG causing it but I think I have read somewhere there are others that cause problems as well.
Intel 5930K@ 4.4 Ghz ASUS Rampage 5 Extreme Motherboard 2-EVGA GeForce Titan X SC SLICase Labs Merlin Full Tower case NZXT Kraken X61 Liquid CPU cooler 32 Gbs G.Skill Ripjaws 4 DDR4 2666EVGA Supernova P1200 PSUAcer Predator X34 MonitorSamsung 512 Gb XP941 M2 SSD HT Omega eClaro Soundcard[/font
rapt0r
2011/11/16 17:42:35
Anyone know if there is a console command for gamma or even any other brightness/contrast settings? Even on max brightness via the menus its way too dark.
maniacvvv
- Ribbons : 159
rapt0r
2011/11/23 07:42:10
Hey sorry for delay, tottaly forgot. I sorted it in the NVCP anywyas. Another Question, why are the gfx so much better in co-op than in multiplayer? Take the last level in co-op for eg, the metro station has all sharp textures and true colors but in MP its all a blurry low-res blue-tinted mess.
jarrettsc87
2012/02/08 13:33:11
I use to have the same issues with crashing. I tried everything from tweaking voltage, re-installing drives, tweaking in game settings with no luck. I decided to reformat my computer and upgrade from windows vista to windows 7 ultimate and now it runs for hours on end with no crashes. On another note, I am having an issue with the quality of BF3. I have a 2.8 ghz quad core Q9550 with a single GTX 580 SC and I've been having some slight tearing issues when playing. When I say tearing, when I look around with my mouse, you can notice it skipping frames. (I don't know if its called tearing or not.) I know that BF3 is a much hardware dependent game than Bad Company 2, but is there anyway I can get it to run as smooth as BC2 with the specs that I have? I tried your settings but I'm getting the same results as I am with my previous stock settings. As I mentioned above, I just reformatted my computer. Specs: CPU: Q9550 2.8 ghz Quad Core Ram: 8 gb ddr2 Video Card: 580 gtx SC Power supply: 750 watts Windows 7 Ultimate 64 bit 650 SATA harddrive Please tell me if there is anything I need to post such as a video of what's happening or my startup programs, etc.
maniacvvv
- Ribbons : 159
2012/02/08 21:52:48
jarrettsc87
Specs:
This is a very old thread My -full- BF3 guide is posted http://forums.evga.com/fb.ashx?m=1323124 I belive the section you want to look at (for your description) is for your mouse settings
