Mangix
I want to replace the molex fans that came with the case(my current motherboard has 5 fan headers, 2 of which are in use) and am looking for low noise options. I currently have the front fan disabled as it's starting to make a lot of noise. An issue with the bearing I guess. But this does mean that my hard drives are getting really hot(both are from 2007!!!). ASRock's A-Tuning is giving me red signs that 60 C is too hot for these drives. Any recommendations? edit: I believe that I have 2 3-pin and 1 4-pin headers free.
outhouse
Re: Looking for low noise 120 and 140mm fans.
2014/09/13 09:58:10
Do you need air flow? Your best bet is to get some decent fans and turn them down using the hardware monitor in bios I tried weak quiet fans, and when gaming it got too hot. Upgraded to better fans and turned them down in a profile for non gaming, then full speed for gaming. I went with coolermaster sycle flow because they were cheap, good performance and quite when needed.
I7 4790K @ 4.8, EVGA FTW, 16g Corsair vengance pro, 250 SSD sumsung evo, GTX 780ti SLI, Corsair HX1050, BENQ XL2720Z.
Grey_Beard
- Ribbons : 10
2014/09/13 17:13:49
My suggestion is Noctua. They are very quiet and provide excellent air flow. I have 28 120mm fans in my build. The air flow if great. My temps are great. They also have new colors, do you are not bound to the biege and brown of the older models. I could care less about color, as performance had always been my concern.
dakon
2014/09/13 20:10:07
12900kf, ROG Strix z690-a Gaming, 32gb Gskill DDR4 4000, EVGA RTX 3090 FTW3 Ultra, Ae-5, Seasonic 1000 Titanium, EK 360 AIO, Corsair 680, LG 38in, AKGK7XX, Samsung NVME 2tb
serrasalmuss
2014/09/15 13:06:44
corsair are great the af series for airflow. i been using a pair of the cooljag everflow on my front rad with 25mm spacer in pull for almost 2 years now and i like them because they move ALOT of air for all out benchmarking and if set to be balls out and very func at lower voltages when i set them to be silent at idle and ramp up with cpu temp...
||Maryjane v4.20|| ||EVGA x79 Dark||i7 4820k@4.5 HT||16G G.Skill Trident X 2400mhz||EVGA 980FTW||840 pro 256gb (OS) ||2x1 TB WD Black ||Corsair Air 540||EVGA 850G2 ||custom built water setup, Koolance cpu-380i, swifttech mcp 655 w ek top, primochill 1/2 tubbing,HWlabs 360gts 3xcorsair SP120 HP edition fans||
kougar
- Ribbons : 22
2014/09/17 16:05:35
Noctua are the best, but they definitely cost more for it. Haven't paid enough attention recently to recommend any cheaper brands for fans... Whatever you go with just avoid anything that uses a sleeve bearing as those wear out in 1-3 years max. Ball bearings are more durable but they tend to be a little louder... fluid bearings tend to be the way to go, there's lots of types out there now.
Have water, will cool.
RainStryke
The Advocate
- Ribbons : 60
2014/09/17 17:47:29
Cougar makes decent fans for reasonable prices. I was very happy with how quiet mine were.
Main PC | Secondary PC Intel i9 10900K | Intel i7 9700KMSI MEG Z490 ACE | Gigabyte Aorus Z390 MasterASUS TUF RTX 3090 | NVIDIA RTX 2070 Super32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17SuperFlower Platinum SE 1200w | Seasonic X-1250Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GBCougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5 3DMark Results:Time Spy|Port Royal
martinch
2014/09/18 04:04:55
My first suggestion would be Noctua - they are expensive, but very good (tend to be quiet, don't get louder with use, and don't break). They do a few - NF-A14 (140mm, balanced flow/pressure), NF-S12 (120mm, designed for air flow not pressure), and NF-P12 (120mm, balanced flow/pressure design) fans. They also have a "redux" range (P14 and S12B), where they are re-using older designs, packaged with fewer accessories, for about 2/3 the cost of the others. I'd also say have a look at Fractal Design's fans - they are standard 3-pin non-PWM fans, but they are silent at 5V, and very quiet at 7V. They're also not very expensive, although they don't produce very much pressure.
post edited by martinch - 2014/09/18 05:22:54
Current PC: Intel Core i7 4790K, Noctua NH-U12S, Asus Z97-Pro, 16GB Corsair Vengeance Pro 1866Mhz RAM, Samsung 850 Pro 256GB, Crucial MX100 512GB, Western Digital Black 2TB, EVGA GTX 970 SC (blower), Pioneer BDR-209DBK, Fractal Design Define R4 + Noctua NF-A14 FLX fans, Corsair AX760 PSU, Dell U2713HM
- Ribbons : 84
2014/09/18 04:15:10
knightsilver
- Ribbons : 14
2014/09/18 12:35:05
boredgunner
Over 9000!
- Ribbons : 79
2014/09/19 20:19:53
Noctua is the best, specifically the NF-F series (120mm) and NF-A series (140mm). The Scythe GentleTyphoons are also way better than pretty much any other fan, these are 120mm and you don't want to go above the 1850 RPM model (AP-15). Other worthy mentions are: - Thermalright FDB series, 1600 RPM and below models (Sony fluid dynamic bearing, tried and true) - Thermalright TY-140, TY-141, TY-147 are amazing and on par with Noctua, but have a strange shape (they use normal 140mm fan mounts though). - Silverstone AP141 (fluid bearing). You'll want to avoid sleeve bearing fans. Go with single ball bearing, dual ball bearing, or a proven fluid/magnetic fluid bearing fan.
woken
2014/09/28 06:01:48
boredgunner Noctua is the best, specifically the NF-F series (120mm) and NF-A series (140mm). The Scythe GentleTyphoons are also way better than pretty much any other fan, these are 120mm and you don't want to go above the 1850 RPM model (AP-15). Other worthy mentions are: - Thermalright FDB series, 1600 RPM and below models (Sony fluid dynamic bearing, tried and true) - Thermalright TY-140, TY-141, TY-147 are amazing and on par with Noctua, but have a strange shape (they use normal 140mm fan mounts though). - Silverstone AP141 (fluid bearing). You'll want to avoid sleeve bearing fans. Go with single ball bearing, dual ball bearing, or a proven fluid/magnetic fluid bearing fan.
I thought they stopped making scythe gentletyphoons AP-15?
boredgunner
Over 9000!
- Ribbons : 79
2014/09/28 09:56:19
woken I thought they stopped making scythe gentletyphoons AP-15?
Did they? How about the AP-14? It's also worth checking out places like newark.com, onlinecomponents.com, MPJA.com, and other large scale suppliers for OEM versions by Nidec.
woken
2014/09/28 14:45:12
boredgunner
When I was looking for fans sometime earlier in the summer I was reading that the people scythe worked with to make the gentletyphoons ended their contract with each other and were no longer to use the design that we see in the AP-15 and AP-14. I couldn't find any gentletyphoons on the webistes you suggested, maybe I didn't search correctly. So if scythe's gentletyphoons are completely out of the picture you would recommend Noctua? Have you used Corsair's latest Static pressure fans, boredgunner?
boredgunner
Over 9000!
- Ribbons : 79
2014/09/28 17:30:33
Noctua isn't even any worse than the GentleTyphoons, so I definitely recommend them. I haven't tried the Corsairs, the specs are far from impressive (3.1 mmH2O static pressure, 62.74 CFM, at 35 DBA???) and I'm not so sure about the build quality.
woken
2014/09/29 04:52:13
boredgunner Noctua isn't even any worse than the GentleTyphoons, so I definitely recommend them. I haven't tried the Corsairs, the specs are far from impressive (3.1 mmH2O static pressure, 62.74 CFM, at 35 DBA???) and I'm not so sure about the build quality.
Idk man, this video is making the Corsairs SP 120 look really good lol: https://www.youtube.com/watch?v=VUbpb23yTK8 This guy got his 3960x @ 4.6 ghz with 100% utilization to be as cool as -7c as his hottest core! His vcore is even at 1.4v!
boredgunner
Over 9000!
- Ribbons : 79
2014/09/29 10:44:51
woken Idk man, this video is making the Corsairs SP 120 look really good lol: https://www.youtube.com/watch?v=VUbpb23yTK8 This guy got his 3960x @ 4.6 ghz with 100% utilization to be as cool as -7c as his hottest core! His vcore is even at 1.4v!
LOL! I've never seen that one before. For anyone who somehow can't tell, that video is a joke. You're not gonna get far below room temperature without extreme cooling.
Fiius
- Ribbons : 25
2014/09/29 10:46:56
"Abyss v2" | Gigabyte GA-Z77MX-D3H | Core i5 3570k w/ XSPC Raystorm Waterblock | Corsair AX-650 | | 32GB (4x8GB) G.Skill RipJaws X PC3-1600 10-10-10-30 (BXL) | | EVGA GTX 670 w/ Heatkiller LT 13105 + Backplate | Crucial M4 240GB SSD | 2x HGST 4TB | | Fractal Design Arc Mini | 2x PULL AP-15s on Swiftech MCR240 | D5 w/ Koolance COV-PMP450A Top | | Win7 x64 | 2x Dell UltraSharp 2408WFPb | Dell UltraSharp 2407 WFPb |
boredgunner
Over 9000!
- Ribbons : 79
2014/09/29 12:02:22
Fiius I second the Cougar fans - they are quiet (they make a pleasant whoosh noise) enough. I've also had very good luck with Yate Loon's but they are a sleeve bearing and I kept them vertical orientation. PS - I found the spec sheet for the AP-15s. http://www.nidec-servo.com/en/digital/pdf/D1225C.pdf Maybe we can run searches on the official Nidec Servo part number? I also found this post on OC.net that has a suspiciously similar looking fan - http://www.overclock.net/t/1450370/fb-gentle-typhoon-fans-ending-production/20#post_21372587 ~Fus
Yeah definitely search for Nidec's part number. As for that similar looking fan, good find and very suspicious indeed. Specs are similar to the GentleTyphoon 2150. I wonder if it has the same OEM.
woken
2014/09/29 14:14:20
What do you guys suggest for case fans for intake and outtake? Noctua as well? I thought the NF-F and NF-A are meant for radiator only fans for push/pull
boredgunner
Over 9000!
- Ribbons : 79
2014/09/29 19:36:12
woken What do you guys suggest for case fans for intake and outtake? Noctua as well? I thought the NF-F and NF-A are meant for radiator only fans for push/pull
Fans that are designed for radiators are also fine as case fans, the thing is they're usually overkill. Noctua's NF-F and NF-A series however are all-rounders, designed for case usage and thin/low FPI radiators. For those on a budget, go for Yate Loons, preferably from Sidewinder computers since reports show they usually get the best batches.
kougar
- Ribbons : 22
2014/09/30 04:38:20
Noctua's radiator fans actually have a great static pressure rating and push a lot of air, so they're great for case fans too. Just be aware they do sell models at different RPM ratings. At 1500RPM the 140mm model I bought produces a considerable amount of airflow so I run them around 1,000RPM to keep things quiet, but they don't produce any actual motor sounds or transient noise that I've noticed. boredgunnerFans that are designed for radiators are also fine as case fans, the thing is they're usually overkill. Noctua's NF-F and NF-A series however are all-rounders, designed for case usage and thin/low FPI radiators. For those on a budget, go for Yate Loons, preferably from Sidewinder computers since reports show they usually get the best batches.
Yate Loon fans are good cheap fans, but they don't like undervolting at ALL. If you plan to buy Yate Loons you need to get the correct RPM model the first time or suffer the consequences. I wanted a little headroom to crank mine up (for the occasional heavy OC session) so I bought some 1400RPM 140mm Yate Loon fans figuring I could undervolt them. But when I tried to undervolt all of them would almost instantly start generating various types of clicking noises and wouldn't stop until they were running below 700RPM. The clicking drove me nuts and running them at less than half their rated speed killed a lot of the performance so I eventually replaced them with the Noctuas and have been happy since.
woken
2014/09/30 07:46:06
As you two menti boredgunner
Only reason why I asked is cause I came across a review on newegg for the NF-F12, where the guy was explaining the NF-F12 wasn't meant to be used as a case fan and he was told this by the Noctua support, he copies and pastes his e-mail from the Noctua support onto his review: NOT FOR CASE VENTILATION
Pros: Very Quiet High Quality Product Cons: I have RMA because it's not for case ventilation, long version explanation here :
NOT MADE FOR CASE VENTILATIONS. This Noctua FANS are ONLY for CPU Cooler and Radiator (Focused Flow system creates outstanding static pressure and focuses the airflow for superior performance on heatsinks and radiator)
I have contacted NOCTUA Support about it, and here is their answer :
=================================== Dear Epsilons,
First of all many thanks for choosing our products.
The NF-F12 was designed for high-pressure applications like CPU coolers and radiators. The NF-S12A provides more airflow with a bigger spread after the outlet, which is better for case ventilation, where static pressure is usually not as important as on a cooler.
However, I just tried it out and yes, the NF-S12A moves noticeably more air in free-flow condition and you can feel it, so I doubt that your fans are defective. Once on a CPU cooler the situation will look different but for case ventilation the NF-F12 just isn't the best choice.
This overview explains the difference between the fan lines: http://www.noctua.at/main...ng=fr&products_id=
Kind regards, Andreas Karner Noctua support team
post edited by woken - 2014/09/30 07:51:48
boredgunner
Over 9000!
- Ribbons : 79
2014/09/30 09:42:42
kougar Yate Loon fans are good cheap fans, but they don't like undervolting at ALL. If you plan to buy Yate Loons you need to get the correct RPM model the first time or suffer the consequences. I wanted a little headroom to crank mine up (for the occasional heavy OC session) so I bought some 1400RPM 140mm Yate Loon fans figuring I could undervolt them. But when I tried to undervolt all of them would almost instantly start generating various types of clicking noises and wouldn't stop until they were running below 700RPM. The clicking drove me nuts and running them at less than half their rated speed killed a lot of the performance so I eventually replaced them with the Noctuas and have been happy since.
I've read that the better batches of Yate Loons (which Petrastechshop was known to sell before their demise) can undervolt better, but so far my experience has been like yours. All my Yates hate undervolting. woken Only reason why I asked is cause I came across a review on newegg for the NF-F12, where the guy was explaining the NF-F12 wasn't meant to be used as a case fan and he was told this by the Noctua support, he copies and pastes his e-mail from the Noctua support onto his review:
Noctua does have some fans designed to provide higher CFM and lower static pressure, but I doubt the difference would be large. So maybe go with whatever is cheaper?
martinch
2014/10/01 09:10:53
wokenOnly reason why I asked is cause I came across a review on newegg for the NF-F12, where the guy was explaining the NF-F12 wasn't meant to be used as a case fan and he was told this by the Noctua support, he copies and pastes his e-mail from the Noctua support onto his review: NF-F12 => aimed at heatsinks, projects a narrow beam of air NF-P12 => aimed at case ventilation where pressure is required (e.g. behind a tight mesh such as the Obisidian 550D) NF-S12 => aimed at maximum airflow, has low pressure (should not be used behind a tight mesh such as the Obisidian 550D) You can use an NF-F12 as a case fan, but it would be over-kill, wouldn't have much of a "spread" behind it (you kinda want a cone dispersion pattern), and it'd be louder than the NF-P12/S12.
woken
2014/10/01 10:28:29
Thanks all for the responses and information!
kougar
- Ribbons : 22
2014/10/02 04:18:28
martinch
Thanks for the information! Learned something new
woken
2014/10/03 07:00:49
What do you guys think about the Noctua Industrial NF-F12 compared to the Non Industrial line? What I'm really worried about is the sound, I just recently installed corsair SP120s that came with my h100i on a push config and they are unbearably loud. I'm really curious to know if the Noctua Industrial NF-F12 and non Industrial NF-F12 will emit the same amount of sound granted they ran at the same speed or similar. Or will I be better off getting a gentletyphoon AP-15 for sound/performance?
boredgunner
Over 9000!
- Ribbons : 79
2014/10/03 10:21:06
If they were running at the same speed, I think sound would be the same. Industrial is probably overkill for case fans though. Noctua and GentleTyphoons are on par in terms of sound/performance ratio.
woken
2014/10/03 11:19:02
boredgunner If they were running at the same speed, I think sound would be the same. Industrial is probably overkill for case fans though. Noctua and GentleTyphoons are on par in terms of sound/performance ratio.
I was just looking at this link a couple minutes ago: http://www.vortez.net/articles_pages/120mm_and_140mm_fan_comparison,17.html This guy's results showed for his setup: Gentle Typhoon AP-14 @ 1355 rpm: 22.5 dba and 46.8 degrees centigrade over ambient Gentle Typhoon AP-15 @ 1785 rpm: 26 dba and 44.5 degrees centigrade over ambient Noctua NF-F12 PWM @ 1427 rpm: 28 dba and 46.2 degrees centigrade over ambient I have never owned anyone of these fans, but would you agree with the results since it seems like you have owned tried these fans before?
