sethizftw
I am wanting to change the color of my LED's on my GPU but the tab is not selectable.
post edited by sethizftw - 2016/08/30 08:26:24
CoercionShaman
Re: LED Section not working in precisionX for EVGA GTX 1070 SC
2016/08/30 08:28:56
You can't change them on an SC. They are only RGB on the FTW. And you should be using Precision X OC on a Pascal Card. http://www.evga.com/software/
post edited by CoercionShaman - 2016/08/30 08:32:34
What use is knowledge if there is no understanding?~Stobaeus
BrandonS
- Ribbons : 5
2016/08/30 11:01:01
Hello sethizftw, and welcome to the forums! CoercionShaman is correct; with the release of Precision X OC 6.0.5, we have removed the option to adjust the LEDs on anything but RGB-capable cards such as the 1080 FTW or Classified.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2016/08/30 13:44:46
Use LED visualizer.
Go to C drive, Nvidia folder, your latest driver, and look for led visualizer. It is installed on your computer and controls the light through there.
CoercionShaman
2016/08/30 13:46:59
Scarlet-Tech Use LED visualizer.
That will only turn it off and on, right?
the_Scarlet_one
- Ribbons : 79
2016/08/30 13:49:38
CoercionShaman
I think it does breathing, audio response, slow pulse and heart beat. I only use it for the bridge currently, but I think it controls them all the same. I could definitely be wrong though.. Give it a try.
CoercionShaman
2016/08/30 13:53:11
I don't even have mine on. Closed case with no window. I just wanted to ask so that I knew for future reference. Hopefully the OP will report back what he finds.
the_Scarlet_one
- Ribbons : 79
2016/08/30 13:54:49
CoercionShaman I don't even have mine on. Closed case with no window. I just wanted to ask so that I knew for future reference. Hopefully the OP will report back what he finds.
Open the door, test, gimme results :-p I am in the wrong state to test anything :-( I'll be home next Saturday.
CoercionShaman
2016/08/30 13:58:08
the_Scarlet_one
- Ribbons : 79
2016/08/30 13:59:52
When you download and install a new driver, it pushes all components into that folder, but only the pieces you choose to install actually get installed. Technically GeForce Experience is on the computer, but it isn't installed.
CoercionShaman
2016/08/30 14:12:55
Can't find it anywhere on my system, but I do always clear the installer cache so that may be why.
- Ribbons : 135
2016/08/30 14:27:48
CoercionShaman Can't find it anywhere on my system, but I do always clear the installer cache so that may be why.
Usually located at C:\NVIDIA\DisplayDriver\372.54\Win10_64\International\LEDVisualizer
CoercionShaman
2016/08/30 14:39:05
Will check there when back at house. Thanks.
