AnsweredHot!Jacob and guys help with :Thermal Pads conductivity PLS
orlando2542
2016/11/15 20:17:01 (permalink)
Hello guys
I was wondering about the pads that EVGA is providing and the thermal conductivity that they have?
Is it like 6 W/MK like the Artic thermal pads? is like anyway close to the Fujipoly Extreme 11 W/MK ???
I can potentially purchase Fujipoly but idk if the ones from EVGA are close.
Also can you guys give me the measurements for the narrow , wide and vram pads in case that I decide to go for Fujipoly?
Thanks
QdotJ
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/15 21:27:50 (permalink)
This will make the 6th time you've inquired about pads... Simply wait for your shipment from EVGA.
orlando2542
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/15 22:04:09 (permalink)
If you look closely this is the first time I ask about thermal conductivity values
Something that is NOT on any of the previous post and I'm pretty sure it will not be on the pads when they are shipped, nor reddit nor the internet
post edited by orlando2542 - 2016/11/15 22:07:38
orlando2542
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/15 22:09:07 (permalink)
Now last time that I checked this was a forum not a dictatorship. If the people can't inquire as many questions as pleased without triggering any users or SOME MODERATORS please let me know
post edited by orlando2542 - 2016/11/15 22:11:17
ridesy
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/16 03:37:46 (permalink) ☄ Helpfulby orlando2542 2016/11/16 07:18:01
Hi Orlando
Your knowledge on this subject seems high, as not many would query the thermal conductivity of any pads.
Would therefore suggest you go with best you can source yourself, as EVGA keep reminding people these are not absolutely necessary anyway.
If you are going to change/add these pads, then as someone who understands how they work, just buy your own of best performance possible and tell everyone how it went.
Alas, I come from times long ago when anyone who overlocked anything would always spend hours polishing CPU's and stripping down graphics cards to replace TIM etc, even before we started.
So just go with best you can source/buy and don't wait for freebies from EVGA or anyone else.
Just my take, as I would be watercooling and therefore changing everything anyway.
Ridesy
X79 Dark (2.09), 4820K @4.5Ghz, 1.225 vCore, 4 x 8Gb Corsair Vengeance Pro 2133Mhz, 2 x GTX780 Classified Hydrocopper & HK3.0 CPU Watercool. DD5 Pump in XSPC bay Resevior.
orlando2542
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/16 04:43:41 (permalink)
Ty so much <3
DeathAngel74
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/16 07:55:37 (permalink) ☼ Best Answerby orlando2542 2016/11/16 11:23:06
I went with Fujipoly 17W/mK and 12.5W/mK paste
Corsair Carbide 300R Windowed ATX Mid Tower Case
ASUS ROG MAXIMUS VIII HERO Z170
Intel Core i7 6700k 4.6 GHz 1.35v-1.37v adaptive
32GB Corsair Vengeance LPX DDR4 DRAM 3200 MHz C16 16-18-18-36-2T
EVGA Geforce GTX 1070 SC ACX 3.0 2101MHz/8726MHz 1.075v-1.081v
Corsair H100i v2 Hydro w/2x SP120 and 2x Thermaltake RIING 12 Blue LEDs
7x Thermaltake RIING 12 Blue LEDs
EVGA SuperNOVA 1300 G2 1.3kW Fully Modular
ADATA 480GB (storage/games)
ADATA 960GB (Windows/Games-Origin/Steam/GoG)
Realtek ALC1150/SupremeFX 2015
Windows 7 SP1 Ultimate x64
http://www.3dmark.com/3dm/15307550
http://valid.x86.fr/ez4v5d
DSP1
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/16 08:33:52 (permalink) ☄ Helpfulby orlando2542 2016/11/16 10:29:45
I asked Tech Support twice to give me the thermal conductivity of the thermal pads they use and all they would ever tell is that they use ShinEtsu and that they did not have the thermal conductivity information available.
Get the 11w/mk ones or better and you will be good to go.
It is my belief that the Shin Etsu are only 6w/mk, if that.
xrav22
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/16 09:13:50 (permalink)
https://www.shinetsusilicone-global.com/products/function/heat/index.shtml
Interesting info if you are into it, but the Fujipoly pads would cost too much and likely be overkill for this application.
I am going to fit the free ones and see what happens.
GPU: EVGA GTX1070 FTW
MOBO: MSI MPower Z77 Big Bang
RAM: 32gb PNY Anarchy 1866
CPU: i2500K (4.0 turbo)
PSU: Corsair ax750 gold series
CPU COOLER: Zallman copper
HDD: 240gb Patriot Blaze ssd(OP)
     Corsair Nova  V128gb ssd
SND: XFI Titanium Fatality
OS:  W 10 Pro 64-Bit
DVD: Samsung Blu Ray Player
orlando2542
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/16 10:30:31 (permalink)
Thanks for the reply guys. Appreciate it
Cozmo85
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/17 18:59:48 (permalink)
Keep in mind the pads EK uses on all their blocks are only ~3.6w/mk. You really dont need super high end pads.
phoenixst
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/18 05:55:57 (permalink)
I think it all depends on what you are aiming for but any kind of thermal pads is better than a gap of hot air.
I'm hoping higher end thermal pads and paste can allow more applications to run without the fans kicking in. I like silence!
orlando2542
Re: Jacob and guys help with :Thermal Pads conductivity PLS 2016/11/18 06:12:56 (permalink)
For my understanding " I called EVGA support and they  have no idea" the thermal conductivity of the pads are around 6 W/mk.
I went to the Sin Etsu site and the pads that they have are 3.5 and 6 w/mk so is not as good as a Fujipoly or a Thermal Grizzly one.
For my understanding all the pads  should be fine with a  thickness of  1.5 mm  EXCEPT for the wide one " the one on the backplate " that is supposed to be at least 2mm thick.
My thermal grizzly thermal paste and Fujipolys should be arriving this weekend. I will post my results as soon as possible. Thank you everybody for the replies, as a side note I will keep buying EVGA because even when they made a mistake they are still really trying hard to make it right for us.
PS: I will ask girlfriend for a waterblock kit for my Christmas gift
