Adger
Hi all first of all I'd like to say hello to everybody . Now I'd like to say that I'm very very tempted to get a ftw 1070 possibly within the next 2-3 days. I've heard lots of brilliant things about EVGA,s after sales support and their fantastic customer care. But..I'm also hearing a few stories regarding "coil whine" with some of the FTW and SC cards. Il hopefully be purchasing my card from overclockers uk,as I only live 10 minutes away from them. I know they offer a 14 day return (refund) but I hope I don't have to go down this route. So I'm basically asking if many of you have had problems regarding whine on the 1070 FTW cards in particular. Also if you have purchased a 1070 FTW are you more than happy with your purchase? If you had your choice over again would you still go for the EVGA FTW 1070? I'm sorry that my 1st post is a bit of a negative one,but I really want to get the best advice regarding my purchase. Thank you to anyone with any advice,it'd be most appreciated . Very best regards. Adger
post edited by Adger - 2016/08/07 14:43:26
My Affiliate Code: 0AXK9S2R5X My 1st EVGA product..it certainly wont be my last
Bosanac13
Re: Is coil whine a serious issue with the ftw and sc cards?
2016/08/07 14:48:33
Hey! I've got a 1070 SC and I will occasionally hear coil whine when it's under stress (for example, FIFA 16 opening intro with unlimited FPS). However, it's truly not that loud (I personally would never complain about it). If you are sensitive to noise and need everything to be at completely quiet then you'll have some issues when the card is under stress. If you're like me and have headphones / music / sound playing almost constantly, it won't bother you. I highly recommend these cards; they're really great! The coil whine should definitely not be a reason to not buy the card.
Adger
2016/08/07 14:53:26
Hi Bosanac13. Thanks for your reply,no I'm not really that sensitive to noise, if I heard it "whining" over my case fans then I'd be a bit unhappy but apart from that any noise below that level would be fine. Thanks again Adger
EVGATech_JosephL
EVGA Tech Support
2016/08/07 14:58:03
Hello Adger and welcome to the Forums! Any high powered electronics give off coil whine but it is typically outside of the audible range. Sometimes the whine is able to be heard and it can be quite annoying. This is regardless of brand or model (although with cards that operate at a higher frequency require more power which can increase the odds of coil whine). It also depends on the other components involved such as the power supply. If you find your card does have coil whine, I recommend the following:
1. Test the product another system or test the current system with another power supply unit. This can be the cause of the sound which can manifest itself through the graphics card or power supply. 2. If you are using a UPS (battery backup) or power strip try plugging directly into the wall outlet to see if this may resolve the issue. You should be able to know if your card will experience this within the 14 day window of testing. Run some benchmarks, play some games. Test thoroughly to make sure you are satisfied. If you miss the return window just contact us so we can look into options to assist you further.
2016/08/07 14:58:50
I have two 1070 FTW and no coil whine. I'm very happy with them.
Windows 10 64 Pro ROG Rampage V Edition I7 6850K @ 4.5 GSkill Ripjaws 3000 16GB Samsung 950 Pro M.2 WD 1T Black 2 EVGA GTX 1070 FTW's SLI EVGA Supernova 1000 G2 Raystorm EX240 HAF 932 Advanced 3 Benq 27 inch LCD's XL2720z
Adger
2016/08/07 15:08:34
Cheers for the reply Joseph. I now know why EVGA,s support is highly recommended,I'd have a problem testing it with another psu. But like you say I've got 14 days to try. Thanks again pal Regards Adger
Adger
2016/08/07 15:09:47
Thanks culater127 I think I'm gonna grab me a FTW tomorrow pal. Cheers Adger
smokinV8
2016/08/07 15:18:56
my gtx 1070sc only seems to coil whine really badly when playing doom on vulkan api during the initial loading of the game then stops strange it doesn't do it when playing on opengl, haven't really noticed it whining while playing anything else
i7 2600k @ 4.8ghz16gb 2133mhz G.skill DDR3Asrock z68 Extreme 4 Gen3EVGA GTX 1070 SCSamsung Evo 250gbWD Black 2TBThermaltake Tough Power 1200wCooler Master Nvidia Stacker 830Asus VG278HE 144hzRazer Taipan \ Razer Black WidowAstro A50Windows 10 (1607)
bdary
- Ribbons : 55
2016/08/07 15:22:02
No coil whine here with my 1080 FTW...
EVGA X99 Classy ~ EVGA 1080 FTW ~ EVGA 970 SSC for PhysXi7-5930K @ 4.40GHz ~ Corsair H100i ~ 16GB G.Skill RipJaws 4 @ 2400MHzSamsung 840 Pro w/ W7 HP & W10 Pro 64bit (Dual Boot) ~ Samsung 840 256GBEVGA 1300W G2 ~ CM HafX ~ ASUS ROG Swift 144Hz Gsync ~ Acer 27" 120Hz 3D Firestrike >> http://www.3dmark.com/fs/9823006 TimeSpy >> http://www.3dmark.com/spy/297131EVGA Affiliate Code - M1D1QH1FTU
GCharly
2016/08/07 15:34:48
No coil whine with a standard 1070 ACX 3.0 overclocked or not. I had some before with a GTX 970. As said before it's just a matter of luck with the card and it's not linked with the brand or the model. Maybe cards more powered like the FTW are more exposed? As Pascal seems to overclock pretty easily I would go with a standard card like mine and overclock it yourself.
Adger
2016/08/07 15:50:17
Thanks all for your comments. GCharly that actually doesn't sound like a bad idea.. Cheers Adger
kb5266
2016/08/07 16:09:09
No coil whine on either of my 1080 FTW's
Intel Core i7-5820K CPU @ 4.4GHz || PNY Anarchy 64GB (8x8) DDR4 2133 || ASUS x99 Haswell-E Deluxe (BIOS 3101) || EVGA GTX 1080 FTW ACX 3.0 SLI || Corsair H110 || Corsair AX1200 || Corsair Carbide Air 540 ATX Cube Case || LG WH10LS30 & GH24NS50 Optical Drives || Samsung SSD 840 256GB || HGST 7200rpm 6TB & 4TB Internal(s) || Hitachi (2x) 500GB Internal || Western Digital Green 2TB External & 1TB External || Logitech K800 Illuminated Keyboard & MX Performance Mouse w/ 5.1 Surround X-530|| AMH 409u v2 || Windows 10 Education (build 10586), 64-bit
GCharly
2016/08/07 16:13:09
Also stick with EVGA, their customer service is the best and by no means their cards are inferior, on the contrary fans may be the most silent of the market. As stated mine is a standard ACX 3.0 and it overclocks over 2100 MHz without a sweat :)
dasa43
2016/08/07 16:24:15
my 1070sc only has coil whine at high fps gets rather loud when overclocked for benchmarking but at stock clocks with 60fps cap i dont hear it may be a problem if i had a 144hz monitor
Adger
2016/08/07 16:57:21
Thanks all,it seems like a real friendly supportive forum here. Also I can see already that the support EVGA offer is the best. People over on the OCUK forums rave about their support. 1 last question if I may...the FTW would cost me an extra £10 over the SC model. Would you go with the FTW model over the SC for such a little increase in price? They both look very similar in specs. @ Dasa 43 yep a Gsync 144mhz monitor would be next on my list possibly within a few months,but I'm sure if it was really loud over 60fps EVGA would look into it? Cheers Adger
harrykheepal
2016/08/07 20:28:54
I replaced my gtx 1070 ftw with new one and still have coil whine on this one too. I think coil whine can be eliminated with 850+ power supplies.
DarkStarchild
2016/08/07 21:06:02
Hi, not sure if you've seen my post in the forums. I got a new Evga 1070 ftw a couple of weeks ago and get an electric buzzing sound from where the two 8 pin pcie connectors connect on the graphics card even with vsync on and coil whine even at 60fps I can hear it from 3m away with my pc case closed. It gets louder with more fps. I'm using the Evga super nova G2 850w power supply. I was very happy when I got the card at first but after I started noticing the coil whine/ buzzing sound I wasn't so happy. Also I have a problem where some games the framerate will go from 60 to 59 to 61 with vsync on but I guess this is an nvidia driver problem (I've just moved over from using amd graphics cards for 12 years) I think coil whine can vary depending on which power supply you use but then I thought I brought a good one being the evga super nova g2 850w so I'm not so sure. I'm sorry that hearing this probably doesn't help but just thought I'd share my experience, I'm trying to decide what to do about my card at the moment.
post edited by DarkStarchild - 2016/08/08 00:13:30
harrykheepal
2016/08/08 01:21:17
But from my notice from different forums and reddit posts evga psu under 850w + evga 1070 = coil whine. This what i noticed from specs of people experiencing coil whine. I have evga 750 p2 evga psu still got coil whine on my second 1070 ftw too.
dasa43
2016/08/08 02:23:45
whether a gpu has coil whine is fairly random although some models are more prone to it that others my pc overclocked uses ~250w gaming with a stupidly overkill seasonic xp 1050 i still get coil wine from my 1070 at times it was the same with the 290 out of the two 7970 i had one with coil whine and one without im just lucky that its not severe i have seen a lot of people rma there psu\gpu due to them being loud sometimes the replacement still makes noise sometimes it doesn't a high quality psu with good filtering may have an effect but going overkill with 850w+ wont solve it
Adger
2016/08/08 02:24:36
Thanks guys for all your advice and information. I only have a corsair tx650 psu,I've actually tried a friends 1080 in it (different brand than EVGA) and it was silent. I've been lucky I've used 3 different cards with this psu and every single one has been perfect. Does anybody have a lower psu like mine and NOT have any coil whine issues? I'm not going to replace my psu it's been perfect. I really really wanna go with this EVGA FTW 1070 card. I was actually going to pick 1 up today or definitely tomorrow But if I'm been honest ..I've noticed more postings regarding coil whine issues on the EVGA cards than any others on different forums. Thanks all Regards Adger Edit:@Darkstar child,just read your original post very interesting regarding your testing with different psu,s. Are you still within RMA range? Why not return your card mate. I think I'm going to hold fire for a day or 2 I've no qualms RMA ing a card if it's not what I'm expecting. I'd just rather avoid RMA ing if possible
post edited by Adger - 2016/08/08 02:56:30
Pr00f
2016/08/08 03:37:47
Hello and welcome! I had some very bad coil whine on my card, luckely the customer service helped me and I was able to send my EVGA FTW 1070 back to my store in holland. Now contemplating on what to buy for my new card, not sure if I will go with another EVGA because on some of the Dutch videocard forums there is also a very vocal majority with this card having coil whine issues. The card itself is beautiful, you can feel it has high quality materials and the rgb is perfect. If it wasnt for the coil whine problems I keep reading about I would 100% stick with this card.
On this forum I got the reply that my power supply was poor, this myth was busted when I tested it on two other machines now with differend psu's. On other help forums they say my power supply itself is perfectly fine aswell. also a 650 watt psu you have isnt realy a low power psu it should be more than enough for these cards since they arent that power hungry. I guess its a lotery with videocards but I have a vague believe that this card (sadly) has it more than other brands at the moment.
Adger
2016/08/08 04:00:36
Thanks for your input pr00f, it does seem that there's a fair few posts on different forums, where people are having issues on the EVGA cards. There's also a lot of people who are having coil whine issues on the Msi cards aswell though.
I don't know if it's the luck of the draw with GPUS or not but in my opinion if I'm paying upwards of £430 for a GPU I expect it to be nigh on perfect. Cheers Adger
Adger
2016/08/08 07:19:45
I think I'm going to take a chance on the FTW 1070. I have 14 days to RMA with my seller anyway. And seen what a friendly bunch your are on here,and hearing and reading stories about EVGA,s excellent support I'm going to give this card a chance. Il hopefully be picking one up in the next couple of days. Thanks all Adger
harrykheepal
2016/08/08 07:27:37
But you have to convince the tech support guy or the guy testing your gpu for rma. He may not count coil whine as defect in gpu. Prior discussion with retailers or sale rep is the best way to solve any problems or issues you might face.
Adger
2016/08/08 08:00:55
Hi Harry ..under the 14 day RMA with OCUK I could send it back as unwanted. I wouldn't even have to mention coil whine. Thanks mate
IronJupiter50
2016/08/08 08:48:14
Hi Adger, please post back on whether your new 1070 FTW has coil whine or not. I'm also interested in buying a 1070 FTW, but I am waiting a couple/few more weeks until the price drops a little more.
Adger
2016/08/08 08:57:20
Will do ironjupiter. I'm just waiting for my new motherboard to arrive as soon as that's in place il purchase the FTW ,and fingers crossed everything will be fine pal.
q2klepto
2016/08/08 10:53:43
I get terrible coil whine with my FTW at stock and overclocked :( Its a shame cuz its a decent overclocker ...hitting 2135mhz on default BIOS and maxed out power/temp limits...stable 2101mhz on Heaven loop. Tonight ill try the 2nd bios with 130% limit and a move aggressive frequency/voltage curve in Afterburner 3beta..hopefully get 2150mhz stable But the whine is pretty bad :( Not sure if i should RMA it
Adger
2016/08/08 11:56:23
Thanks for the information q2klepto if your not happy with the whine then I'd certainly be looking to RMA it. It certainly seems that there could be quite a few people who are having coil whine issues with this card. It's a shame because of what I've read about EVGA and the people I've had information from on this forum,you all deserve a great card. It seems like a 50/50 gamble on wether or not I get a good card without whine. Do I risk £430 on a gamble?? I'm not sure guys.
Adger
2016/08/08 15:22:29
I've been keeping a close eye on this forum for just over a day now and.. I must say I'm very impressed with the EVGA reps that are on here giving quick and sound advice Are they always this good? Anyway I'm 100% going to purchase a FTW 1070 card within the next few days. Just because I've seen how good EVGA are. And fingers crossed I get a great card (haven't had much luck lately,just had to purchase a new MB) I have 2 6+2 pin connectors on my PSU,I'm right in saying this is good enough to run this card? Thanks all
