CoercionShaman
Re: Is coil whine a serious issue with the ftw and sc cards?
2016/08/26 12:24:35
I was telling arokhantos that you had a new issue and you weren't saying RMA or refund over the whine, JONOX. I understood. 😉
What use is knowledge if there is no understanding?~Stobaeus Intel i5 4670K @ 4.2GHz, Corsiar H100i v2 AIO, 32GB G-Skill Trident X @ 2133 MHz, MSI 1080 Gaming X w/ 2139 MHz boost, ASUS Maximus VI Hero, Samsung 840 EVO 240GB, WD 750GB, CM V1000, Dell U3415W 21:9 @ 75Hz, Windows 10 Pro AE, CM Storm Trooper
DaoDib
2016/09/30 02:18:31
Is this thread still alive? I've got my 1080 FTW about 3 weeks ago, but I didn't want to stress it before I got it under water, and I only yesterday got the waterblock for it. When I turned on the heat, the coil whine is like nothing I've heard before. It sounds like there is a hair trimmer turned on inside my PC. What do I do? I'm running it with a Corsair AX860
post edited by DaoDib - 2016/09/30 02:24:00
raidflex
2016/09/30 07:13:22
I haven't had any coil whine for my 1080 FTW, in fact it seems to be the least of any card I have had in recent years. I had a good amount of whine with my MSI 780 Ti's. I do have a water block to put on this weekend, so I will see if this makes a difference. Limiting your FPS to 60 should help lower the whine or at least cap it to your monitors refresh. But if you have a monitor that has a high refresh rate, there is not much else you can do. I am still not sure if the PSU actually affects the whine, I would imagine less ripple in power delivery would prob help lessen the noise.
Gigabyte X99M-Gaming 5 i7 5820 (4.5GHz Vcore 1.27V) EVGA GTX 1080 FTW Samsung 850 Pro 120GB & 500 GB Corsair AX1200 Crucial Ballistix Sport 2400 4x4GB Caselabs Mercury S5 w/pedestal Windows 10 Pro x64 EK Supremacy Alphacool Nexxxos UT60 x2 Monsoon Series Two Premium DDC Reservoir Bitspower Compression Fittings Swiftech Helix Fans LG 34UM95 Monitor
DaoDib
2016/09/30 08:17:49
I would consider my Corsair AX860 to be a premium PSU :/ And im running a 100 Hz monitor :/
Do anyone know if it possible to get a replacement card from evga even after the 14 day period?
raidflex
2016/09/30 09:18:37
DaoDib I would consider my Corsair AX860 to be a premium PSU :/ And im running a 100 Hz monitor :/
Maybe try to get it replaced by the vendor if possible. I would call EVGA also, it can't hurt.
2016/09/30 12:23:55
GhostlyBG Update: I've switched from the Corsair PSU CX 750 back to SeaSonic XP2 860W Platinum, and the coil whine is absolutely gone. 0 coil whine even at 165 fps. So the issue was the PSU in my case for sure.
I agree that it can be multiple issues which ultimately cause coil whine, but it does seem that your PSU plays a huge factor. I've had cards with whine before in differing degrees, but on my current build I opted for a SeaSonic 860 watt Platinum XP2 power supply, and I haven't heard a peep of coil whine out of my current 1080 FTW. I don't think the importance of having a good solid quality PSU can be overstated.
i7 6700K, Corsair H80iGT, 16GB Corsair Vengeance DDR4 @3000MHz, EVGA GTX1080 FTW, MSI Z170A Gaming M7, Samsung 950 Pro 512GB, Samsung 840 EVO 250GB, WD 1TB, Creative SB Zx, Dell P2715Q 4K/UHD @60Hz, Samsung B2230HD 1080p @60Hz, Windows 10 Pro, Corsair Air 540, Seasonic 860watt XP2, Corsair K70 RGB, Razer Deathadder Chroma
irenicus785
2016/09/30 15:47:29
Guys, pardon my ignorance-- Is there a trusted vid on youtube of the proper *sound* of really bothersome *coil-whining* on GPU's? I don't think I ever had the bad-luck of purchasing a *bad* card out the gate from the few I own from EVGA over the years.
Next-week, I plan to finally purchase either a 1070 or 1080, and upgrade from my recently RMA'ed gtx 980 SC replacement.
CPU ~Intel Skylake 6700k OC 4.5GhzGPU ~EVGA SLI 2x gtx1070 SCPSU ~EVGA 1000 WATT Sli/ReadyMOBO ~ASUS Maximum Hero 8 [Z170]RAM ~G. Skill 16GB DDR4 3000I/O ~KB/M: Logitech g910 Orion Spark, Razor NAGA Epic Monitors ~SAMSUNG 24' monitor(s) 1920 x 1080 (2) OS ~ Windows 10 Pro {1607} [/
virtual81
2016/09/30 21:25:12
irenicus785 Guys, pardon my ignorance-- Is there a trusted vid on youtube of the proper *sound* of really bothersome *coil-whining* on GPU's?...
It's often a difficult sound to pick up with a microphone, thus difficult to record and reproduce. My GTX1070 FTW is a bit noisy. Not real happy with the noise, but unless better quality properly potted inductors are used then it's here to stay. The first manufacturer to do this will likely win a few customers as it is a sign of better engineering and higher quality.
irenicus785
2016/09/30 21:43:57
virtual81
AHhhh, OK - Fair enough!
Triss
2016/10/01 19:56:27
Had my 1070 ftw about a week now happy to say no coil whine at all. Been a great upgrade over my 780 and so quiet i love it :)
raidflex
2016/10/03 07:08:01
irenicus785
virtual81
Usually the noise is more pronounced at a high FPS. Try running a benchmark or game at a very high FPS and you might hear a high pitch sound.
Enosoma
2016/10/03 15:42:17
I have a 1070 SC and my card does not produce any coil whine until I boost the GPU core to +120 or more. Which isn't a problem for me as I keep it a relatively mild +80/+200
matthewfarmery
2016/10/04 04:28:17
I get coil whine when I use the automatic fan control with a custom curve, but then again, there are times I don't get any coil whine, at this moment in time, Im not hearing any coil whine. So a bit odd, as it can come and go.
Sean1976
2016/10/04 09:52:11
Well there hasn't been many coil whine issues with the reference version F|E type cards, so I think you answered your own question.
Intel i5 4690K Devils Canyon@ 4.7Ghz @ 1.320Vcore Asus Sabertooth Mark 2 Z97 deck Hyper 212 Evo Air After-Cooler Evga 1080 GTX Founder's Edition@ 1987mhz core/5400mhz memory G-Skill Sniper 1866mhz memory 9-10-9-28 CAS latency(16GB)2x8GB sticks 1x Intel 540 series SSD 480GB 2x Intel 520 series SSD 240GB each(480GB) 2x Intel 535 series SSD 240GB each(480GB) Corsair HX850 Watt Gold Psu Antec Eleven Hundred v2 Carbon Fiber case w/ 9x 120mm fans BenQ XL2420TE 144hz 1ms Lightboost/MotionBlur/ Gaming panel(1080p)TN G15/G9 Logitech gear http://www.3dmark.com/3dm/12966736?
Brenex
2016/10/09 07:17:54
I just finished burning in my 1070 FTW (>10 hours) and it still has noticeable coil whine when at high FPS. I'm using a corsair 450SFX which got great reviews in regard to its ripple so I am really leaning away to it being a PSU issue. What is the process of RMA-ing the card?
2016/10/09 10:12:47
My 1080 SC has the worst coil whine I've ever encountered on an Nvidia GPU to date. I wonder if EVGA cheaped out on some of the components or something. It was so bad, I gave it to my best friend as a semi- free upgrade. He didn't care about the coil whine and I took his 980 Ti Hybrid. Win/Win.. now to sell this Hybrid...
HeatwareOS: W10 64 CPU: Intel Core i7-6700K @4.6GHz 1.35v Cooling: EK Blocks, AC Rads, D5, Pastel White Mobo: Asus Z170i Pro Gaming ITX RAM: G.Skill TridentZ 16GB 16-16-16-36 3200MHz SSD: Samsung 850 EVO 1TB M.2 GPU: EVGA GTX 1080 SC 2114MHz PSU: Corsair HX1000i Case: Gun Metal Mercury S3 ITX Display: Acer XB270HU 144Hz IPS GSync Mouse: Zowie EC2-A Keyboard: Max Keyboard Blackbird Audio: Yamaha RXA-1040, 2x KEF Q300, Polk Center
arestavo
- Ribbons : 8
2016/10/09 10:33:33
The SC and ACX base model are the same PCB right? The FTW is different for sure. My 1080 ACX 3.0 doesn't have coil whine - my Gigabyte 980 Ti did though. Brenex I just finished burning in my 1070 FTW (>10 hours) and it still has noticeable coil whine when at high FPS. I'm using a corsair 450SFX which got great reviews in regard to its ripple so I am really leaning away to it being a PSU issue. What is the process of RMA-ing the card?
Have you tried the card in a different PC that has a fairly powerful GPU/PSU that doesn't coil whine? That's a good way to check and see if it is your card. If you can't check that, register your card if you haven't - https://www.evga.com/support/register.asp Then call or email EVGA to start up a RMA - http://www.evga.com/about/contactus/
EVGA affiliate code: 9ZWDWFNW6A (Don't forget to upload your invoice or no credit is given!) FOLD ON
Brenex
2016/10/09 15:30:42
why does enabling vertical sync and locking the FPS make coil whine disappear?
arestavo
- Ribbons : 8
2016/10/09 15:40:26
Brenex why does enabling vertical sync and locking the FPS make coil whine disappear?
Because it locks FPS to 60, allowing the GPU to not work as hard/draw more power. Coil whine is caused when the power components (primarily the VRMs) vibrate really fast. Lower load, less vibration, less/no coil whine. Here's Linus telling us all about it - http://lifehacker.com/this-video-explains-what-coil-whine-is-and-how-to-avoid-1669522880
post edited by arestavo - 2016/10/09 15:44:49
jakeface1
2016/10/09 17:19:02
I have 2 1070 SC's and have no coil whine.
PHOENIXZERO
2016/10/10 04:10:34
I bought a 1070 FTW last week to replace my 970 SSC, no noticeable coil whine but if the "silicon lottery" refers to cards that are able to boost to 2+GHz without overclocking by the user well I lost that one. Also being this late I lost the VRAM "lottery" too. Hopefully the BIOS update actually improves things significantly on that end. Also the only time I ever heard coil whine on my 970 was in older games (or non-frame locked menus) where the frame rate would go into the hundreds if not thousands.
post edited by PHOENIXZERO - 2016/10/10 04:12:56
joseph305
2016/10/10 09:24:45
hey phoenixzero, I am thinking about upgrading my ssc+ to 1070ftw too , but waiting on that bios fix to see if it works. It's a shame NVidia switched many of the 1070s from Samsung to micron memory....
4790k, 16gig 9-9-9-24 ram, 970ssc+, win 7 , ssds
2016/10/10 17:05:25
joseph305 hey phoenixzero, I am thinking about upgrading my ssc+ to 1070ftw too , but waiting on that bios fix to see if it works. It's a shame NVidia switched many of the 1070s from Samsung to micron memory....
Again with the Micron issue... There is nothing wrong with Micron VRAM modules GDDR5 or GDDR5x. They are 100% on par with Samsung's. Samsung is not a flawless company making the best electronics as many people seem to think (heard of their recent troubles with the Galaxy Note 7 anyone?). As far as overclocking, it's a crap shoot, and not a guarantee. This is why they call it the silicon lottery. I have an EVGA FTW 1080 with Micron GDDR5x VRAM and it is awesome. I still also have an ASUS Matrix GTX 980 Ti and it has 6GB of Samsung GDDR5. Neither overclock very well. They're about the same actually.
Brenex
2016/10/18 06:56:35
arestavo Have you tried the card in a different PC that has a fairly powerful GPU/PSU that doesn't coil whine? That's a good way to check and see if it is your card. If you can't check that, register your card if you haven't - Then call or email EVGA to start up a RMA -
I just tried it with the corsair sf600 to see if it made any difference and the coil whine is exactly the same. I am only drawing 250-260 watts with burn-in benchmarking anyways so that shouldn't have been an issue. I will start the RMA process. I hope the next one I get doesn't have this coil whine :(
dilla69
2016/10/18 07:11:40
Got an 1070 SC lately, seems to clock very well. Stock core boost at exact 2GHz, OCs to ~2150MHz - RAM +675MHz offset. But sadly it got quite excessive coil whine, even at low framerates. Sometimes noticable through my headphones. :/
clone
2016/10/18 10:30:09
No coil whine on my 1070 FTW.
Sean1976
2016/10/18 11:17:01
dilla69 Got an 1070 SC lately, seems to clock very well. Stock core boost at exact 2GHz, OCs to ~2150MHz - RAM +675MHz offset. But sadly it got quite excessive coil whine, even at low framerates. Sometimes noticable through my headphones. :/
Send it back, I wouldn't accept any card coil whining out of the box. Unacceptable.When you RMA make sure you post a note in your RMA to make them test the card that they intend to replace it with, they will do this if you ask. I know they have to do it on an Advanced RMA, because its a 2nd time replacement, but all your trying to do is save them time and shipping. Doesn't hurt to send them a note asking them to test. I asked them to test a 2nd replacement 770 SC due to some issues I was having with stability at stock clocks, they did the testing and boom I got decent RMA replacements.
post edited by Sean1976 - 2016/10/18 11:21:33
dilla69
2016/10/18 13:23:08
Sean1976
Thanks for letting me know. I'm already in contact with the support. They asked me to do some hours of burn-in, so the coils will eventually be quiet enough. But I doubt that this will help. Had a 980 before for almost two years. The card also had (not such as loud) coil whine and the noise level never changed a bit, even after long periods of heavy load. But I will ask, if they can test the replacement that it has no coil whine. I'll see if it helps. :)
Brenex
2016/10/18 13:35:26
Now when I try to submit my RMA after being told to do so in a support ticket I get, "Your product is out of warranty. If you have any questions, please contact customer service. (E12)". This is such a drag. The ship date is 8/2016 so that makes no sense. *edit* must have been the cookies, works in incognito mode. Go figure.
post edited by Brenex - 2016/10/18 14:01:06
2016/10/18 17:10:43
Yes I would RMA that card. I have absolutely zero coil whine in my FTW 1080. And I have stressed it plenty just to be certain. I think my PSU helps too. Coil whine in a card this expensive is a no brainer. R.M.A. Try using a different internet browser and the RMA will likely go through.
